Old 12-14-2014, 08:09 PM   #2656
maddog9's Avatar
Trader Rating: 29 (100%+)
I haven't broke one of these in a year. Broke 2 right side spindles in the same day landing a jump perfectly normal and snap. Are there any updates to fix this bad mold issue?
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 12-14-2014, 08:19 PM   #2657
Casper's Avatar
Trader Rating: 33 (100%+)
Odd. May just be a bad part? Is it cold where you are racing?
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-14-2014, 08:38 PM   #2658
maddog9's Avatar
Racing indoors at least 60 degrees.
Old 12-15-2014, 07:59 AM   #2659
0351's Avatar
Maddog, whats your setup for indoors? 1900?
0351 is offline   Reply With Quote
Old 12-15-2014, 10:06 AM   #2660
KOULLIT's Avatar
Hi tbullard,
I agree that all servos have not the same dimensions, but you can't say "bigger than the servos usually used". I have a servo usually used, a Futaba S9352HV, and dimensions are 41mm x 21mm x 37mm.
I can say it's a little bit hard to place this servo.
And I'm not talking about the servo wires...the way you have to bent them... I drilled the receiver/servo box with a dremel to fix it.
In my opinion, the servo/receiver box is not well designed, many servos are bigger than 40.3mm (because here the problem is the lenght).
But there are many "bizarre" parts on this Losi, the way they are designed is surprising.
Bye !
SYLVERIS RC - Option Racing Parts
LOSI 8IGHT-E 3.0 - Tekin RX8 GEN2 - Tekin T8 - Futaba 3GR 2.4Ghz
1/8 Off-Road Electric - Belt drive conversion : http://www.rctech.net/forum/electric-off-road/665377-1-8-offroad-electric-belt-drive-conversion-6.html
The French forum : RCMAG.COM
KOULLIT is offline   Reply With Quote
Old 12-15-2014, 10:44 AM   #2661
maddog9's Avatar
I run an agama 43t steel spur gear with a 14t pinion. Pretty close to this setup. Brass weight in and battery tray in front of the esc.
Old 12-15-2014, 10:58 AM   #2662
Brian C.'s Avatar
I agree I have never broke anything of that sorts, and I've cased my fair share of jumps lol!
Brian C. is offline   Reply With Quote
Old 12-15-2014, 02:10 PM   #2663
Casper's Avatar
Yeah that is not cold enough to cause any issues due to temps. That is just very odd. First one probably stress, second one I would call a bad part if you say you did not hit a wall hard.
Old 12-15-2014, 02:11 PM   #2664
I have one of these coming in by Friday .....
A couple questions...
..... What's a recommended top of the line servo??
..... Is the steel spur a direct fit??? Just asking cause on my friends converted 8t he had to do a lil mod in order to use the nitro gear.
...... N lastly....I wanna pimp the sumbich out....Any nice hop hops available for this thing?? I haven't seen too many in my searches..
NickTheGreek is offline   Reply With Quote
Old 12-15-2014, 03:38 PM   #2665
maddog9's Avatar
Ya the first one was on the car a year. The 2nd one literally had 30minutes on it. No hard wrecks just landed a triple and it snapped. Same landing that snapped the first one.
Old 12-15-2014, 03:45 PM   #2666
maddog9's Avatar
-Servo I run a hitec 7945.
-45t is a direct fit. The truggy your buddy probably used a 48t and yes that requires at least 2mm shims under the center uprights.
-essentials: agama 43t steel spur or 44t/45t losi steel gear, aluminum servo saver top, aluminum top plate, aluminum horn, x-ring orings if they do not come with the vehicle.
-nice to have: 8 hole 1.3 pistons(non-tapered), 8 hole splits 1.2/1.4(non-tapered).
Anything else is not needed.
Old 12-15-2014, 06:00 PM   #2667
To anyone who has used the Mamba + 2200KV combo...can ya tell me what pinion you settled on?
I ordered a 15T....is that a good starting point?....anyone?
Cabledawg is offline   Reply With Quote
Old 12-15-2014, 09:07 PM   #2668
I have a semi related question for you all. I am looking to purchase a new e 3.0. Do I take a chance and wait until after Xmas for any after holiday sales that may come up or just go ahead and take the 10% off that some sites have going right now?
drinkslinger55 is offline   Reply With Quote
Old 12-16-2014, 06:52 PM   #2669
TommyJoe's Avatar
I've got the 2200kv sidewinder and I run a 45t spur with a 13t pinion on a big outdoor track. On a tight indoor track I run an 11t pinion.
TommyJoe is offline   Reply With Quote
Old 12-17-2014, 09:25 AM   #2670
Brian Miskolczi's Avatar
Trader Rating: 156 (100%+)
Cabledog- I run a 2250kv and use 45/15 and it runs perfect. That's where I would start, keep an eye on temp and adjust accordingly if you need to.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
