Old 10-10-2014, 12:02 PM   #2566
InARush's Avatar
Questions??
Originally Posted by maddog9 View Post
I personally think the setup i run now would be good for someone new, but everyone has their opinion.
Since the smc he recommended is even lighter (by 10grams) and has the ability to move front or rear because it's a short pack, it sounds like a better tuning option don't you think? Plus I'll still get the brass weight that helps with steering.
Keep up or keepoff I'm in a rush!!
InARush is offline   Reply With Quote
Old 10-11-2014, 04:58 AM   #2567
maddog9's Avatar
Trader Rating: 29 (100%+)
You can give it a try. I had a similar pack made by spc and couldn't find the right position to run it in.
maddog9 is offline   Reply With Quote
Old 10-13-2014, 07:17 AM   #2568
Merse's Avatar
Hey guys, just finished my build and I didn't see anywhere in the manual where they have the recommended pinions like all the other kits. I'm running the tekkin 2050kv motor.
Thanks Merse
Sandy Mercer
TLR 22T----22 2.0----22-4----Eight-E-3.0
My biggest fear is that i die and my wife sells my RC collection for what i told her it was worth....
Merse is offline   Reply With Quote
Old 10-13-2014, 04:14 PM   #2569
KOULLIT's Avatar
Not only do the front inserts affect kick up they adjust your total caster. I was told this by one of the top TLR drivers. What I was unable to find out is how each combination of inserts adjusts the caster. Does anyone know?
Hi InARush,
I will try an answer, but I'm not sure it's all right.
It seems that the front arms are at 10 ( chassis plate and gearboxes / A and B plates)
If you had the front 15 hubs, we have a total of 25 for the front caster.
If you change the front and rear hinge pin bushings you will change from 23 to 27.
The set up in the manual shows 2 inserts "1" in front and rear, the front in up position and the rear in down position. This set up gives you the maximum of 27, and the other combinations are in the manual, page 16.
For example, if you reverse the "1" bushings positions, compare to the manual set up, you will have a total of 23, the minimum.
I hope you will understand my poor English.
Bye !
SYLVERIS RC - Option Racing Parts
LOSI 8IGHT-E 3.0 - Tekin RX8 GEN2 - Tekin T8 - Futaba 3GR 2.4Ghz
1/8 Off-Road Electric - Belt drive conversion : http://www.rctech.net/forum/electric-off-road/665377-1-8-offroad-electric-belt-drive-conversion-6.html
The French forum : RCMAG.COM
KOULLIT is offline   Reply With Quote
Old 10-13-2014, 08:34 PM   #2570
cokemaster's Avatar
Trader Rating: 18 (100%+)
Thanks Merse
44/14 is perfect for 2050kv
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 10-15-2014, 02:00 PM   #2571
InARush's Avatar
Thumbs up
Originally Posted by KOULLIT View Post
Hi InARush,
Bye !
You are absolutely right. Thanks for fiollowing up on that!!
Old 10-15-2014, 02:01 PM   #2572
InARush's Avatar
Does anyone know where I can purchase multicolored esc 10 or 12 guage wire set? Should I use 10 or 12?
Old 10-15-2014, 02:32 PM   #2573
TQWire has great wire!
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is online now   Reply With Quote
Old 10-15-2014, 03:26 PM   #2574
Bivens's Avatar
Amain hobbies has multi color wire sets by Tekin, viper, Novak, and others...in many different wire gauges, colors, and lengths.
www.amain.com
Bivens is offline   Reply With Quote
Old 10-15-2014, 06:30 PM   #2575
Trader Rating: 17 (100%+)
anybody know if there is a new body coming out like the nitro version
bkuff-losi is offline   Reply With Quote
Old 10-15-2014, 07:00 PM   #2576
Merse's Avatar
i second that, 10 or 12 gauge?
Sandy Mercer
Old 10-18-2014, 04:58 PM   #2577
SamuraiJack's Avatar
Trader Rating: 38 (100%+)
Hi friends,
Could someone do me a favor and measure the width of the losi 3.0e body?
❂ 8IGHT-E 3.0 ❂ 8IGHT 2.5 ❂ XXX-4 ❂ SRX4 ❂ SRX2 MM
SamuraiJack is offline   Reply With Quote
Old 10-19-2014, 12:04 PM   #2578
cokemaster's Avatar
Originally Posted by SamuraiJack View Post
Hi friends,
In the front: 149mm
In the rear 144mm
Old 10-19-2014, 06:06 PM   #2579
maddog9's Avatar
This is the body drake was running recently.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
Old 10-20-2014, 07:20 AM   #2580
Integra's Avatar
So basically no fin on the back and the side dams have a few different angles.
Tags
e-buggy, eight 3.0, losi, spur gear
