Old 09-14-2014, 04:17 AM   #2521
trixter91's Avatar
So whats the first upgrade I want, the eight t front spindles or casrer blocks or what do I want to get.
Steve Larson
Team Associated
Silky smooth driving techniques
With qualities that women respond to
Sexy since 1974
trixter91 is offline   Reply With Quote
Old 09-14-2014, 10:21 AM   #2522
Trader Rating: 15 (100%+)
Couple questions for everyone.
1. I notice on indoor setups the team runs 1.4 and 1.5 pistons. Do they run the regular or the tapered piston and what is the difference with the tapered piston vs regular?
2. How does kick up affect the car via the inserts in the front?
3. Does everyone use the red or blue loctite on critical areas like the drivecups?
thanks
dbracn is offline   Reply With Quote
Old 09-14-2014, 12:49 PM   #2523
Integra's Avatar
Originally Posted by InARush View Post
So my 8ight E finally arrived but I didn't realize pinion gear not included. I see losi has the 14t and 15t mod 1 gears but should I be looking elsewhere? Just wondering if choice of pinion brand is important. Also any hop ups recommended out the box? I have a pair of 8ight T spindle carriers that I see some team driver run. I've change the steering top brace plate to aluminum and a aluminum servo horn. Thinking about the alum servo saver? Also wonderig if the de racing mud guards and skid plates are worth it? Team driver told me mud guards just a wind drag and the skid plates just alters ride height so I'm better off without them. Would greatly appreciate the feed back, thanks!!
Brand wont matter on a pinion, they are for the most part All equal.
Lol Wind Drag, Not the first time ive heard it Nor the last. IMO these guys are FULL of it. We Radar our cars quite frequently at our track and If it IS a Drag, its Less than a single Mph, So IMHO its Moot and the time they save in cleaning your Rear shaft's and Shock's is WELL worth the loss 1/1000th A Mph.
Old 09-14-2014, 03:41 PM   #2524
InARush's Avatar
Thumbs up
Thanks for the info!! Still trying to decide on a 1900kv or 2050? What say you? Most been telling me 1900 is all I need.
Keep up or keepoff I'm in a rush!!
InARush is offline   Reply With Quote
Old 09-14-2014, 03:56 PM   #2525
trixter91's Avatar
Anyone else find a bent rear universal in their kit.
Steve Larson
Team Associated
Sexy since 1974
Old 09-14-2014, 05:27 PM   #2526
Integra's Avatar
Most are correct.
Old 09-14-2014, 07:10 PM   #2527
XXXDad's Avatar
Trader Rating: 195 (100%+)
Cool
No upgrades needed ... Alu top plate and servo saver are nice but not needed.
Taper up quicker reaction rebound
use 1's for bumpier track
Blue... never red
thanks
1900
You sir have alot of little things wrong with your kit. I would make a list call Horizon and get replacements. They are quick to make things right. I would just run it!
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 09-15-2014, 07:09 AM   #2528
WadexInducTion's Avatar
Hey guys, just picked up a kit over the weekend. I'm heading to a LHS to grab a few parts and I was going to get a few pinions. I am going to be running a 2100kv motor, any ideas on where I should start with pinion size? (Would be helpful to know for the 43t stock spur and the 45t metal spur as I plan to upgrade to the metal spur)
Any advice is appreciated!!
Futaba 4PX
Kyosho RB6 - Hobbywing Xerun v3.1/Killshot "Beast" 17.5T
Kyosho RT6 - Hobbywing Xtreme stock/Killshot 13.5T
Mugen Mbx7R Eco - Hobbywing SCT Pro/Tekin 1900kv
Mugen Mbx7T Eco - Hobbywing Xerun 150A/Tekin 2000kv
WadexInducTion is offline   Reply With Quote
Old 09-15-2014, 08:07 AM   #2529
symmetricon's Avatar
Trader Rating: 27 (100%+)
I'm running an LRP 2200kv motor and am geared 13/45
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 09-15-2014, 08:39 AM   #2530
cokemaster's Avatar
Trader Rating: 18 (100%+)
With the 43 spur you will not really get a perfect setup for a 2100KV motor. You would have to try either 13 or 14 pinion. However, with a 45 spur a 14 pinion would be a good match. I have based this on calculation of what the TLR factory drivers are using with 1950KV motor or 2200KV motor.
I have a 2050KV motor and will use 43/14 as a starting point, but a 44/14 would probably be a better choice.
cokemaster is offline   Reply With Quote
Old 09-15-2014, 04:07 PM   #2531
InARush's Avatar
Questions?? Front hinge pin inserts and caster
Not only do the front inserts affect kick up they adjust your total caster. I was told this by one of the top TLR drivers. What I was unable to find out is how each combination of inserts adjusts the caster. Does anyone know?
Old 09-15-2014, 08:01 PM   #2532
Yes, mine looked like a horseshoe!
I ran it for a bit until I did an order for parts and ended up replacing it. We must have got the ones that fell on the ground and got stepped on by the big guy in the factory.
-Kane
rcdepot.us
nxgraphics.ca
Kane-o is offline   Reply With Quote
Old 09-15-2014, 08:06 PM   #2533
Originally Posted by BenG477 View Post
So does that mean that the E 3.0 has inclined spindles? If it does I dont remember them saying that???
Sorry to bump this but does anyone have an answer for this?
BenG477 is offline   Reply With Quote
Old 09-15-2014, 08:35 PM   #2534
Integra's Avatar
-Kane
My front bone was a little "cock eyed" rubbing off the hard coating on the radio tray in a matter of 1 tank.
Fatty must have a grunt or something.
Old 09-16-2014, 12:44 PM   #2535
They are not inclined. There used to be an option for inclined, but they don't make it any more.
LAGuy is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
