Old 08-30-2014, 09:36 AM   #2476
TahoeDust's Avatar
Originally Posted by dpcardoza View Post
Nobody answered so I just went down to my lhs and got one. They do indeed provide more space albeit not a lot more. Haven't taken it to the track as I just painted it today but I do like the look.
Lets see it!
TLR 8ight E 3.0 - Tekin RX8 ESC - Tekin T8 2050KV - Hitec 7955TG
TLR 8ight-T E 1.5 - Hobbywing Xerun ESC - Hobbywing Xerun 1800KV - Hitec 7955TG
Sanwa MT-4
TahoeDust is offline   Reply With Quote
Old 08-31-2014, 09:55 AM   #2477
Trader Rating: 82 (100%+)
Originally Posted by TahoeDust View Post
Lets see it!
dpcardoza is offline   Reply With Quote
Old 08-31-2014, 02:52 PM   #2478
Trader Rating: 15 (100%+)
Where can I find how to do the battery mod to move it ahead?
Tommygun1 is offline   Reply With Quote
Old 08-31-2014, 08:37 PM   #2479
patrick lsp's Avatar
Trader Rating: 176 (100%+)
Default Wtb roller
.....roller found.
Eb48.4
Nb48.4
Nt48.3
Reds racing USA.
patrick lsp is offline   Reply With Quote
Old 09-01-2014, 03:04 PM   #2480
When you changed over to metal spur. What did you use to shim the braces up?
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 09-01-2014, 03:48 PM   #2481
SUPERLOOPER's Avatar
Steve,
I run the 45T metal spur and didn't need to do anything. Fit perfect.
Brian
2017 Sponsors:
Team SOARSEIKI * AKA * Reds * Sanwa * Nitro Pro fuel * LFR * On point graphics * Xpert * M2C * Daytona RC paint
Brian Looper
SUPERLOOPER is offline   Reply With Quote
Old 09-01-2014, 06:18 PM   #2482
TRADLER's Avatar
I found that the lid didn't provide the same side bite that the stock one did. I made a shark fine out of poly and mounted in the flat spot behind the cab, made a world a difference.
TRADLER is offline   Reply With Quote
Old 09-04-2014, 01:59 PM   #2483
Trader Rating: 6 (88%+)
who is running the nitro pistons in this car?
Reds racing USA
AKA
KO Propo USA
Sidewinder fuel
Upgrade Rc
Drip is offline   Reply With Quote
Old 09-04-2014, 06:10 PM   #2484
You talking about the 8hole pistons? If so. 37.5/ silver spring front. 35/ silver spring rear.
Steve Walter
Old 09-04-2014, 11:56 PM   #2485
oliv996's Avatar
Could someone tell me if the Losi Front Center Universal Driveshaft (LOSA3587) could be mounted on the 8ight-E 3.0 ?
www.mid44.com
oliv996 is offline   Reply With Quote
Old 09-05-2014, 12:29 AM   #2486
I have the 46 tooth Metal spur in mine and it was to Big, but i lifted the center diff with one shim under each hole. Can i do it so?
lynakafaith is offline   Reply With Quote
Old 09-05-2014, 02:21 AM   #2487
oliv996's Avatar
I don't think it would cause a problem as long as the shim used are thermally conductive (steel or aluminium). You must think about motor heat dissipation through the chassis is on of the main way
Why don't you dig locally the chassis under the spur gear instead?
www.mid44.com
Old 09-05-2014, 07:05 AM   #2488
XXXDad's Avatar
Trader Rating: 195 (100%+)
Arrow LFR has what you need
LFR is a local Florida company that offers this nice plate you put under the motor mount. I recommend this for all trying to run a bigger Sper Gear. >> http://shop.leadfingerrc.com/LFR-mot...y-LFR10092.htm
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 09-05-2014, 07:09 AM   #2489
XXXDad's Avatar
Thumbs up I would say YES
Yes it can but remember that they switched the drive shafts on the 3.0 so the short is in the rear now and long in the front. Drake actually runs that shaft so YES on the rear only... now i'm thinking the front might be longer on the 3.0 .... If you need to change the pin there are a few company's that make them.> http://www.amain.com/Mugen-Seiki-Dri...t-Tool/p221425
Old 09-05-2014, 07:26 AM   #2490
XXXDad's Avatar
Thumbs up I do
I run 37.5 front and 32.5 rear on my large outdoor track. I have the New Taper/ Splits I will try next
Tags
e-buggy, eight 3.0, losi, spur gear
