Old 08-26-2014, 07:52 PM   #2461
Not trying to start an argument, but I'll have to agree with cement head on this one. I love using double sided tape. Never had an issue ever and if I need to remove it, I just pop it off and get a new piece! I personally don't like drilling into my beautiful chassis either. And, if a screw strips, I'll be cursing more than I would by popping it off with a flat head! Both ideas are great, I just like mine and cement heads better
Losi8ightfanty is offline   Reply With Quote
Old 08-27-2014, 05:32 AM   #2462
Originally Posted by cdraughon View Post
So after making sure my shock ends were screwed all the way in, I noticed the right front a arm falls lower than the left front a arm by about 2mm. I removed the shocks, all of the links and made sure the droop screws were backed all the way off. Still, the right arm falls further than the left. I confirmed the kick up pills were the same on both sides. Any ideas what would cause this?
I stripped everything down to the chassis and found the a arm to be tweaked causing the difference in droop measurements. Replaced the arm and now both measure the same.
Now, setting the front droop to 95mm as measured from top center to bottom center of the shock mount screws has very little droop. The a arms are nearly level when the car is elevated. This looks like less droop than Drakes car in his YouTube suspension video.
cdraughon is offline   Reply With Quote
Old 08-27-2014, 06:04 AM   #2463
ta_man's Avatar
Trader Rating: 151 (100%+)
Certainly each to his own. I have always used some kind of flexible mount on my 1/8th ESCs. The "servo" tape I use is the gray 3M stuff and my opinion is that it doesn't provide sufficient shock protection.
You really ought to come up with a better argument against mounting with screws: anyone who strips a screw going into 1/8" of plastic isn't competent to drive an RC car.
I can see the argument of not wanting to drill through your chassis - not everyone has the tools to do this without kluging it up.
ta_man is offline   Reply With Quote
Old 08-27-2014, 06:55 AM   #2464
Trader Rating: 20 (100%+)
Not sure where you got 95mm for droop but we run 103.5mm in front and 114.5mm in back. Put your front like ours and you will have the droop
Randy
RandyJones is offline   Reply With Quote
Old 08-27-2014, 01:20 PM   #2465
95mm is the droop setting on the 2.0 cars.
TPJ International
071crazy is online now   Reply With Quote
Old 08-27-2014, 05:29 PM   #2466
Thank you RandyJones and 071crazy. I suspected the 2.0 might be different but I had not been able to find any information to the contrary. This makes more sense.
Old 08-27-2014, 07:04 PM   #2467
No prob!! Anytime!!
Randy
Old 08-28-2014, 12:35 PM   #2468
Trader Rating: 81 (100%+)
Anybody running the jconcepts silencer body know whether it allows for more space for the wires and esc? Just a couple of fun days on the stock body and the paint is already rubbed off in some spots.
dpcardoza is offline   Reply With Quote
Old 08-28-2014, 01:17 PM   #2469
KingdomRacer's Avatar
Felt the same about 3M not having enough shock protection and started the drilling thing too to securely mounting my esc's (via my benchtop mill).
But then one day I tried doubling up the grey 3M double sided tape and that was over 2 years ago... and I don't plan on ever going back.
It's simple and I have experienced the same success with doubling up the tape just like when I mounted it securely via the chassis...
Like the old sayings goes 'more than one way...' and 'if it ain't broke'.
As long as your finishing races and your equipment keeps ticking then keep doing whatever works for you, so I agree 'to each his own'.
JESUS says, "Fix it B4 it Breaks, 'cuz a DNF is a SIN".
Alpha-RC.com/RcRenew.com/TritonRC.com
VPProUSA.com/UpGrade-RC.com/KalGard.com
Green-Gorilla.com
KingdomRacer is offline   Reply With Quote
Old 08-28-2014, 10:49 PM   #2470
TahoeDust's Avatar
What springs are you guys running in the front of your 3.0 E? I bought mine second hand and it has black springs in the front. Even with the collar fully cranked they do not seem stiff enough.
TLR 8ight E 3.0 - Tekin RX8 ESC - Tekin T8 2050KV - Hitec 7955TG
TLR 8ight-T E 1.5 - Hobbywing Xerun ESC - Hobbywing Xerun 1800KV - Hitec 7955TG
Sanwa MT-4
TahoeDust is offline   Reply With Quote
Old 08-29-2014, 02:44 AM   #2471
I use silver front and back.
For ESC sticking. I use two pieces of the tape. IT/Low Voltage Contractors have a foam two sided tape that sticks great.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 08-29-2014, 08:40 PM   #2472
I am wondering the same thing. How roomy are these bodies and how are they holding up?
fievel is offline   Reply With Quote
Old 08-29-2014, 08:58 PM   #2473
Trader Rating: 15 (100%+)
My front diff is more free than the rear using the same diff fluid, so I figure I didn't fill the front as much. Is it ok to fill them completely? That would make it easier to get them equal.
Tommygun1 is offline   Reply With Quote
Old 08-29-2014, 09:05 PM   #2474
Casper's Avatar
Trader Rating: 33 (100%+)
Yes fill them all the way.
Here is a great diff building video
https://www.youtube.com/watch?v=DbOfV5J5Z0k
Lube the ring and pinon gear with Casper-RC Extreme grease!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-30-2014, 01:09 AM   #2475
Nobody answered so I just went down to my lhs and got one. They do indeed provide more space albeit not a lot more. Haven't taken it to the track as I just painted it today but I do like the look.
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
