Old 08-17-2014, 08:03 PM   #2386
InARush's Avatar
Originally Posted by Cement head View Post
I'm running a trak power 6700mah 80c 4s and it has plenty of power,speed,and run time.
What motor and esc are you running?
InARush is offline   Reply With Quote
Old 08-18-2014, 01:24 AM   #2387
I am running a 5000 mah SMC 4s, 50c on a tekin 2050. It has been a great pack with plenty of juice for 10 minute mains. I have absolutely no problem clearing any of the jumps with the 2050 with room to spare most of the time.
Dagolf is offline   Reply With Quote
Old 08-18-2014, 08:52 AM   #2388
Cement head's Avatar
Tekin rx8 gen 2/2050 gen 2.
TLR 3.0 e buggy. RX8 gen 2/2050 gen 2
Losi xxx-scb TLR tuning kit. Castle mmp/3800 kv
Team Associated SC8-E castle mmp/2200 kv
RC Excitement Fitchburg Ma.
Cement head is offline   Reply With Quote
Old 08-18-2014, 08:54 AM   #2389
Should I stay away from hobbyking batteries? I know dudes go that route to save but I heard the nano specs are good and roar approved. If not I've been looking at track power, protek and venom as well. Also what's the least discharge rate I should go with?
I'm also running a gens ace 5000 mah 40 c 4s. Good battery for the money.
Old 08-18-2014, 08:57 AM   #2390
Also the weight difference between the gens ace and the trak power is around 100grams.
Most all battery company's list weights.
Old 08-18-2014, 09:02 AM   #2391
Thanks. I thought I needed 6000mah or more to make the 10min mains. If 5000mah is sufficient I'll go with that. Someone was also advising me I need to balance the battery weight with the motor and esc. Should this be a big concern? If so what weight parameters should I stay in if I'm running the set up you mentioned?
I use Thunder Power's 5300/65C 4S (Novak 1900, 14 pinion) and run 15 minute mains on a medium outdoor track. 10 minutes would be no problem, even with some warm up laps.
LAGuy is offline   Reply With Quote
Old 08-18-2014, 09:09 AM   #2392
TahoeDust's Avatar
How do you guys like the Tekin 2050 in your 3.0 E? What is your gearing? I am going to be running the same motor in mine.
TahoeDust is offline   Reply With Quote
Old 08-18-2014, 09:32 AM   #2393
InARush's Avatar
I see this battery also comes in 80C discharge rate. Will that make a difference on the car performance or affect the run time?
Old 08-18-2014, 10:16 PM   #2394
TahoeDust's Avatar
Anyone?
Old 08-18-2014, 10:22 PM   #2395
symmetricon's Avatar
Trader Rating: 27 (100%+)
Anyone?
You should be geared 14/45 with the 2050
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 08-19-2014, 06:39 AM   #2396
XXXDad's Avatar
Trader Rating: 195 (100%+)
The 2050 set at it's lowest is still too much motor.... get a 1900 Unless you drive on a Monster track
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 08-19-2014, 08:20 AM   #2397
TahoeDust's Avatar
It's pretty big...
I bought the buggy used and it came with the 2050. I have a 1800 in my 8ight-t I could try in my buggy if the 2050 is too much.
Old 08-19-2014, 08:45 AM   #2398
Seem to have some seeping from my top shock caps on my new kit and suggestions?
RevolutionM is offline   Reply With Quote
Old 08-19-2014, 04:54 PM   #2399
InARush's Avatar
Questions??
Anyone how important is the discharge rate C? How high a rating do I actually need? Does this affect how long the battery last?
Keep up or keepoff I'm in a rush!!
Old 08-19-2014, 06:44 PM   #2400
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Most likely it's just oil from putting the cap on. After filling and putting the cap on spray it off with motor spray and see if it still collects dirt on them.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
