Old 08-01-2014, 07:57 AM   #2326
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by dbracn View Post
Another question regarding servos. I ran the xp1015 and it feels good but I think it needs a little more. What is a good amount of torque and speed that I should be looking for? Do you need more torque over speed? I was also looking at the spectrum 6090 or the futuba 9352 and was wondering which would be better for the buggy?
I run the s6090 on HV in my 8ght and it works great. You need to value speed and torque in a good 8th scale steering servo. You want to look for torque numbers in the 200+ range and speed in the .1 range IMO for a good steering servo.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-01-2014, 08:23 AM   #2327
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up Speed> 6090s
Size Category:StandardTypeigitalApplication:1/8 Scale SurfaceTorque:181 oz-in (13 kg-cm) @ 6.0V; 292 oz-in (21 kg-cm) @ 7.4VSpeed:0.11 sec/60 @ 6.0V; 0.09 sec/60 @ 7.4VLength:1.57 in (40mm)Width:0.79 in (20mm)Height:1.24 in (32mm)Weight:2.2 oz (62g)Bushing Or Bearing:BearingConnector Type:Z-connectorGear Type:MetalGear Material:SteelVoltage:6.0V-7.4VMotor Type:CorelessBearingual
Originally Posted by dbracn;1343803[B
Size Category:StandardTypeigitalApplication:1/8 Scale SurfaceTorque:181 oz-in (13 kg-cm) @ 6.0V; 292 oz-in (21 kg-cm) @ 7.4VSpeed:0.11 sec/60 @ 6.0V; 0.09 sec/60 @ 7.4VLength:1.57 in (40mm)Width:0.79 in (20mm)Height:1.24 in (32mm)Weight:2.2 oz (62g)Bushing Or Bearing:BearingConnector Type:Z-connectorGear Type:MetalGear Material:SteelVoltage:6.0V-7.4VMotor Type:CorelessBearingual[/B]0]Another question regarding servos. I ran the xp1015 and it feels good but I think it needs a little more. What is a good amount of torque and speed that I should be looking for? Do you need more torque over speed? I was also looking at the spectrum 6090 or the futuba 9352 and was wondering which would be better for the buggy?
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 08-01-2014, 10:09 PM   #2328
Trader Rating: 15 (100%+)
Thanks casper and glen.
Do you run the rx8 on the 7.4 bec with that servo? Does that drain the battery any quicker or noticeably compared to 6.0v.
Also does anyone have a picture on how you run the two 2s packs instead of a 4s?
dbracn is offline   Reply With Quote
Old 08-02-2014, 05:26 AM   #2329
2 2s Packs:
lynakafaith is offline   Reply With Quote
Old 08-02-2014, 10:21 PM   #2330
Thanks for the picture. How are you running connectors to run both at once?
Thanks,
Old 08-03-2014, 12:11 AM   #2331
Thanks,
You can also see it in the picture at the left
Old 08-03-2014, 10:12 AM   #2332
Casper's Avatar
I was running 10 min mains on dual 3800mah shorties on the high voltage BEC.
No this should not drain your battery anymore as the BEC just lets through more voltage.
Here is picture of the shorty pack setup I run
http://www.petitrc.com/setup/losi/se...ctronicsSetup/
Old 08-03-2014, 11:11 AM   #2333
RcOneNitro's Avatar
Trader Rating: 61 (98%+)
I wonder if anyone has run a RC8.2e and 8ight-e 3.0? How is the driving characteristics vs the two buggies? I am thinking of selling my rc8.2e roller and getting a 8ight-e 3.0
RcOneNitro is offline   Reply With Quote
Old 08-03-2014, 12:03 PM   #2334
I'd go ahead and sell the 8.2! The 3.0-E is amazing compared to it. I had way mote corner speed than all the 8.2's last night and it is much better at just about everything else. Seems like the 8.2'ss couldn't push near as hard.
Dagolf is offline   Reply With Quote
Old 08-03-2014, 02:43 PM   #2335
easye's Avatar
Im getting ready to build my kit what is the o ring mod to the shocks that I heard about a while ago? Is it just a matter of leaving out the shim between the to orings? Is there any other tricks or mods to do during a build? Thanks..
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
leisure hours hobbies and raceway. Ez duz it customs.
Al Richards #1 fan Mr.Mellow #5 fan
easye is offline   Reply With Quote
Old 08-03-2014, 04:09 PM   #2336
Integra's Avatar
Xrings you mean ?
Old 08-03-2014, 05:42 PM   #2337
easye's Avatar
Im not sure. Had a guy telling me to leave the spacer or shim out between the 2 o rings in the shock to per vent stickshon and the shocks will move free once the orings start to swell. If there is a better shock oring can you give me the part #
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
Old 08-03-2014, 05:49 PM   #2338
XXXDad's Avatar
Exclamation Build it normal
Build them normal. Now the Dif you leave out the washes not the shocks.
Old 08-04-2014, 05:00 AM   #2339
UN4RACING's Avatar
Trader Rating: 22 (100%+)
When you first build them do them as the manual states. After a couple of times topping them off you may feel the o-rings getting tighter. Then take out the shim. They will be smooth as silk. As they get tight again from swelling take out an o-ring. Sounds crazy as hell but they don't leak and performance is like not even having an o-ring in there. Around here we have been running them with no shims for months and no leaking yet. These are by far the best o-rings I've ever seen. FYI around here the 3.0 has dominated the podium all year. The only real wear is the front center dog bone.
I highly recommend building the entire kit as the manual states to anyone building one the first time. The only thing is I would recommend buying an aluminum top saver arm. Truly the only thing after market this kit needs.
http://www.amain.com/Team-Losi-Racin...er-Top/p275038
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 08-05-2014, 06:56 AM   #2340
I took out the shim between the o-rings in my shocks and they haven't leaked once and they are waaaay smoother than before. The were smooth before and now they are even smoother. I will be leaving the shim out because I like how free the shocks are now. I also recommend getting the aluminum servo saver top and I also run a metal 45t spur gear when I go outdoor.
Losi8ightfanty is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
