Old 07-25-2014, 09:41 PM   #2311
KingdomRacer's Avatar
I use a #20 and have never needed to go bigger than that.
I wouldn't recommend going bigger than a #20 unless you want to introduce slop a whole lot faster...
JESUS says, "Fix it B4 it Breaks, 'cuz a DNF is a SIN".
Alpha-RC.com/RcRenew.com/TritonRC.com
VPProUSA.com/UpGrade-RC.com/KalGard.com
Green-Gorilla.com
KingdomRacer is offline   Reply With Quote
Old 07-25-2014, 10:11 PM   #2312
Trader Rating: 15 (100%+)
Originally Posted by dbracn View Post
Some help needed,
I just got this buggy and was wondering about servos. Would the xp1015 or the spectrum 6090 work well with this buggy? I run spectrum so I want to avoid savox but these two were the top of my list. The only thing I see for spectrum is that you can run 7.4 vs the xp only runs 6. I will be running a 4s pack.
Thanks,
Just wanted to see if anyone could offer some advice.
dbracn is offline   Reply With Quote
Old 07-26-2014, 12:37 AM   #2313
Send a message via AIM to Brushless Corey
Any particular reason you want to avoid running a Savox servo cause you run Spektrum? I run both Savox servos with Spektrum and don't have any issues.
Brushless Corey is offline   Reply With Quote
Old 07-26-2014, 07:23 AM   #2314
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by skrichter View Post
For everyone that was having a terrible time getting the front arms to be free, I ended up testing an #18 drill bit --works perfect.
I tried the 10-32 tap like someone suggested for the droop screw, with some new arms before I tried to screw in the droop screw -- did nothing. Still wasn't free.
The #18 drill bit makes it nice and free, with only a VERY SLIGHT amount of play.
Hope this helps.
I have the perfect solution, go to Lowes and find the chainsaw sharpening tool, looks like a long thin round file. It comes in a 2 pack. The smaller file is 4.2mm. Put the droop screw in the a arms, Chuck the file into a drill and ream out the a arms from both sides. It works perfectly, the hinge pin will be able to fall right through the a arms with very minimal slop..... Kcobra showed me this and I have used it. And best if all, the tool costs around 5$...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 07-26-2014, 09:56 PM   #2315
Just heard locally that the two don't mix well together and that you need an external cap to help regulate the power. I have an xp 1015 now just wondering if that would work? Im new to 8th scale, just a 2wd buggy guy.
Old 07-26-2014, 11:39 PM   #2316
I run a Savox 1256 in my 8E 2.0 and 3.0 buggies and a Savox 1267 in my 8T 2.0 truggy without a external cap and have zero issues.
Old 07-27-2014, 06:48 AM   #2317
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I would steer away from the XP, they have a plastic gear that is common to break in 1/8th scale applications. I run Spectrum with a Futaba servo. Matched with a Tekin RX8 Gen2 set on the 7.4 voltage option. Works great.
http://www.amain.com/product_info.ph...ium-Gear-Servo
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 07-27-2014, 08:23 AM   #2318
sunco1's Avatar
Never had this happen to me before.. Snapped a camber link end while I was making an on power left turn. Maybe it had a small stress crack in it. They were fresh too, this was the 3rd race on the whole set.
Note to self: Check rod ends more often
TJ Eller
Team Associated - Reedy - Jconcepts - Stickit1
sunco1 is offline   Reply With Quote
Old 07-27-2014, 03:25 PM   #2319
KOULLIT's Avatar
Hi,
Can you tell me what's about the Hudy reamer tool for the Losi arms ?
Did somebody try it ?
Is the 4mm one right, or we absolutely need ~4,2mm drill/tool/tap ?
Thanks,
Bye !
SYLVERIS RC - Option Racing Parts
LOSI 8IGHT-E 3.0 - Tekin RX8 GEN2 - Tekin T8 - Futaba 3GR 2.4Ghz
1/8 Off-Road Electric - Belt drive conversion : http://www.rctech.net/forum/electric-off-road/665377-1-8-offroad-electric-belt-drive-conversion-6.html
The French forum : RCMAG.COM
KOULLIT is offline   Reply With Quote
Old 07-27-2014, 06:40 PM   #2320
Integra's Avatar
FWIW most servo's have that dreaded "plastic" gear.
Old 07-30-2014, 02:58 PM   #2321
Default 8ight e 3.0 rear shock Bodys getting scratched
Hello,
my problem is that my rear shock Bodys are getting scratched more and more.
I have only driven this car 5 Trackdays long on an astroturf track, so Stones couldnt have scratched them up.
Even the thread is damaged a bit
Does someone have the Same Problems?
Sorry for my Language, im from Germany
lynakafaith is offline   Reply With Quote
Old 07-30-2014, 02:59 PM   #2322
Amorpher PIc from the right shock body
Old 07-30-2014, 03:08 PM   #2323
ThePanda's Avatar
Trader Rating: 64 (100%+)
Usually this happens when springs run the shock body. It can also happen in crashes where the springs hit the body.
ThePanda is offline   Reply With Quote
Old 07-31-2014, 12:51 AM   #2324
Can i Protect the shock Bodys somehow?
Old 07-31-2014, 11:36 PM   #2325
Another question regarding servos. I ran the xp1015 and it feels good but I think it needs a little more. What is a good amount of torque and speed that I should be looking for? Do you need more torque over speed? I was also looking at the spectrum 6090 or the futuba 9352 and was wondering which would be better for the buggy?
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jeb.
