Old 07-23-2014, 05:45 PM   #2296
drepus's Avatar
Originally Posted by akshayp14 View Post
what a fantastic answer, thanks buddy!
Glad to help!
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 07-24-2014, 09:12 AM   #2297
Default Measuring and running droop
How are you guys measuring droop? I have 30mm droop blocks and a gauge, but the front steering knuckles are basically touching my setup board. I have seen reference to measuring shock lengths while mounted. Is this the best way?
Also, how much droop is appropriate? I run on a high bite indoor clay track that is smooth.
cdraughon is offline   Reply With Quote
Old 07-24-2014, 12:16 PM   #2298
Salkin's Avatar
http://www.youtube.com/watch?v=H99PKqsUZjA
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 07-24-2014, 05:04 PM   #2299
Is measuring the shock affected by the position of the shock on the upper and lower mounts? For example, if I move to the top inside mount for the shock, will this change the droop?
Old 07-24-2014, 09:52 PM   #2300
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Nope, as long as the droop screws are bottoming out on the chassis "droop" will be the same but the stroke/travel of the shock will change. The leverage will change at the arm.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 07-24-2014, 09:58 PM   #2301
UN4RACING's Avatar
If its high bite I would start with lowering the roll center and set the droop at box stock settings and work less droop in from there as needed. The more droop the better for landings and jumping.
Old 07-24-2014, 11:18 PM   #2302
Salkin's Avatar
If you want to know the amount of droop (and other setup parameters) you can look at the team setup sheets:
http://www.tlracing.com/Products/Def...002#prodSetups
Or just use the standard droop from the stock setup.
Old 07-25-2014, 09:24 AM   #2303
Trader Rating: 15 (100%+)
Some help needed,
I just got this buggy and was wondering about servos. Would the xp1015 or the spectrum 6090 work well with this buggy? I run spectrum so I want to avoid savox but these two were the top of my list. The only thing I see for spectrum is that you can run 7.4 vs the xp only runs 6. I will be running a 4s pack.
Thanks,
dbracn is offline   Reply With Quote
Old 07-25-2014, 12:26 PM   #2304
Trader Rating: 6 (88%+)
If a fella has a 3.0 nitro but doesn't want to buy the conversion kit. Could he simply buy the 3.0 e chassis and battery layout and have the 3.0 e car? Meaning I don't want to have the conversion where the esc is in the back
Drip is offline   Reply With Quote
Old 07-25-2014, 12:54 PM   #2305
Salkin's Avatar
Just for your information, some with the E 3.0 have actually modded their battery/esc layout to have the esc in the back.
Old 07-25-2014, 12:57 PM   #2306
Salkin's Avatar
Another thing, if the goal really is a pure E 3.0, you would probably be better off, in the long run, buying an E 3.0 kit and use the nitro 3.0 as spares.
Old 07-25-2014, 12:57 PM   #2307
Casper's Avatar
Trader Rating: 33 (100%+)
The rear drive shaft is different and you need the Steering servo mount motor mount and diff cover (for the wires).
You basically replace everything in the middle of the chassis but the front and rear clips are the same.
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-25-2014, 01:00 PM   #2308
awesome thats what i needed to know!!
Reds racing USA
AKA
KO Propo USA
Sidewinder fuel
Upgrade Rc
Old 07-25-2014, 07:45 PM   #2309
skrichter's Avatar
Send a message via AIM to skrichter
For everyone that was having a terrible time getting the front arms to be free, I ended up testing an #18 drill bit --works perfect.
I tried the 10-32 tap like someone suggested for the droop screw, with some new arms before I tried to screw in the droop screw -- did nothing. Still wasn't free.
The #18 drill bit makes it nice and free, with only a VERY SLIGHT amount of play.
Hope this helps.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 07-25-2014, 08:56 PM   #2310
Integra's Avatar
Hope this helps.
I did mine recently with a 10-32 tap and they came out Smoooooth as butter.....
Tags
e-buggy, eight 3.0, losi, spur gear
