Old 06-26-2014, 02:46 PM   #2221
Casper's Avatar
Trader Rating: 34 (100%+)
tlr243024 for o-rings.
Some guys like the alum front top brace and alum rear hubs. Aluminum servo arm.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-27-2014, 04:57 AM   #2222
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Also get the new shock boots!
pimpedaccord is offline   Reply With Quote
Old 06-27-2014, 06:47 AM   #2223
XXXDad's Avatar
Trader Rating: 195 (100%+)
Arrow POST a link
Please post a link to NEW shock boots
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 06-27-2014, 09:05 AM   #2224
tkge's Avatar
Trader Rating: 97 (100%+)
http://www.amain.com/product_info.ph...ock-Boot-Set-8
Tim Dunn
Tekno | Pro-Line | Maclan | DialedRCHobbies
tkge is offline   Reply With Quote
Old 06-27-2014, 01:42 PM   #2225
+1. They are much better. They are similar to the truggy boots which I was using until they released these.
8ighteRun is offline   Reply With Quote
Old 06-28-2014, 12:02 AM   #2226
I've set my 8ight-e 3.0 up as per manual
I've got 5000wt oil in the Front/Centre/Rear diffs but when i'm flat out my front wheels start to balloon, seems like my front wheels are spinning a lot more then the rear.
Feels like 65%front and 35%rear at the moment
If I was to put 7000wt oil in the front diff will this lessen the drive to the front wheels so I can have even drive front and rear???
8IGHT-E 3.0/MM2/2200kv 19t/43t 4pls 4s-6s
rotachoc is offline   Reply With Quote
Old 06-28-2014, 04:56 AM   #2227
drepus's Avatar
I've got 5000wt oil in the Front/Centre/Rear diffs but when i'm flat out my front wheels start to balloon, seems like my front wheels are spinning alot more then the rear.
If I was to put 7000wt oil in the front diff will this lessen the drive to the front wheels???
Increasing the thickness of the centre diff will help even out the power that is going to the front/rear. Your current setup with 5000 in the centre is allowing too much power to go to the front when the weight shifts back under acceleration and the front tires lose grip.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 06-28-2014, 07:19 AM   #2228
Default Weight Balance Question
Hi - I've finished my build of the 8ight e 3.0, but wanted to check the weight balance before taking my first run. With a 4S pack on the left side, I expected it to be heavier on that side and require a little bit of weight on the right side to compensate.
I was quite surprised to find that not only is the right side heavier - it's heavier by a fair margin (particularly in the front). You can see in the attached image the weights are:
FR - 839g
FL - 465g
RR - 893g
RL - 1009g
So the car is about 60/40 rear/front weight ratio, but about 65/35 R/L at the front. This seems really out to me and I'm concerned on the first jump the buggy will tilt to the right pretty hard.
Just wondering if others have seen this (I can't image my setup looks much different or that my motor is 2x the weight of anyone else).
I don't even own enough weight to make up that much imbalance.
Any thoughts / insight would be appreciated!
Thanks,
Ron
rtemske is offline   Reply With Quote
Old 06-28-2014, 07:52 AM   #2229
XXXDad's Avatar
Lightbulb Sway Bar disconect
Please make sure you disconnect the sway bar . Simply pop them off the ball. Then re measure the car .. The sway bars will give you false readings. When you re install the sway bars make sure they float side to side and do not bind!
FR - 839g
FL - 465g
RR - 893g
RL - 1009g
Thanks,
Ron
Old 06-28-2014, 08:15 AM   #2230
Sorry I should have mentioned in the post that I did disconnect the sway bars to remove that issue. The weight imbalance is with no sway bars installed.
Old 06-28-2014, 05:35 PM   #2231
UN4RACING's Avatar
Trader Rating: 22 (100%+)
FR - 839g
FL - 465g
RR - 893g
RL - 1009g
Thanks,
Ron
Thanks for the info. By those numbers it would make sense if they would produce a battery tray that would move the battery forward.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 06-29-2014, 07:21 AM   #2232
symmetricon's Avatar
Trader Rating: 27 (100%+)
FR - 839g
FL - 465g
RR - 893g
RL - 1009g
Thanks,
Ron
Something is definitely not right..... I balanced my cars on the same scales and got very different results.. There must be binding somewhere in the front end or something wrong with the scale....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 06-29-2014, 07:34 AM   #2233
UN4RACING's Avatar
I'll try to take the time to scale mine tonight. I'll do mine without springs and see what it is.
Old 06-29-2014, 07:36 AM   #2234
UN4RACING's Avatar
FYI I am running the 40g ballast up front and the battery forward. The kit has really been zooming for me with the silver springs.
Old 06-29-2014, 08:25 AM   #2235
Mine is bone stock (just built it), so no ballast anywhere. I put my B4.2 on the scale to make sure the scale seemed right and it balanced almost exactly L/R (the battery and motor are on the center line in that buggy so not surprising). I moved the battery as far forward as it would go (in the 8ight) in the holder but it didn't make much difference (I only have about 1/2" of play, so not much adjustment available there).
I did not remove the shock springs when measuring, only the sway bars. Should I? I could see the springs shifting Front/Rear balance, but wouldn't think they'd skew things Left/Right?
Tags
e-buggy, eight 3.0, losi, spur gear
