Old 06-11-2014, 11:16 AM   #2116
Send a message via AIM to Brushless Corey
Originally Posted by skrichter View Post
Just purchased a used 3.0e.
Can someone confirm if the JConcepts Nitro Silencer body will fit? I like the shape/lines of it more than the eBuggy body.
If not, what other bodies will fit (other than the JC eBug)?
Thx!
I have the Silencer on my 3.0.
Brushless Corey is offline   Reply With Quote
Old 06-11-2014, 12:22 PM   #2117
skrichter's Avatar
Send a message via AIM to skrichter
Nitro Silencer, correct?
If so, do you have a gap between the body and the edge of the chassis/guard?
Could you post a couple pics (top/bottom)?
Thx!
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 06-11-2014, 04:00 PM   #2118
XXXDad's Avatar
Trader Rating: 195 (100%+)
Arrow Electric body
http://www.amain.com/product_info.ph...cer-Body-Clear
Thx!
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 06-11-2014, 05:46 PM   #2119
skrichter's Avatar
Originally Posted by XXXDad View Post
I actually like the lines of the Nitro body more than the box-like look of the eBuggy version.
Was hoping someone could post some body on pics with the 3.0e.
Old 06-11-2014, 06:45 PM   #2120
I'm pretty sure you will have a space between the lid and the chassis/guard due to the fact that the nitro chassis is wider than the electric chassis.
***TLR 8ight-E 3.0***
Tekin 2050, Tekin RX8 Gen 2, Savox, Avid, Venom, Spektrum.
Tekin 1900, Savox, Spektrum (current build)
* both transmitted by a loose nut and a DX4R Pro *
8ighteRun is offline   Reply With Quote
Old 06-12-2014, 02:46 AM   #2121
Salkin's Avatar
Anyone else thinking that the linkage/steering balls wears out very quickly?
I only run on dusty, blown out tracks, and get a lot of dirt in/on the car.
The linkage/steering balls are wearing to a small size extremely fast, feels like I'm changing the often on my two buggies.
Are there any other balls available made in a different material that will last longer?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 06-12-2014, 05:43 AM   #2122
Mine don't seem to. How are yours positioned, up or down? Just curious because I've never ran mine up.
Old 06-12-2014, 05:44 AM   #2123
symmetricon's Avatar
Trader Rating: 27 (100%+)
Mine are not wearing at all.....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 06-12-2014, 06:20 AM   #2124
Salkin's Avatar
Maybe it's because we race in very dusty conditions.
One of our best national drivers are racing both the nitro and E 3.0, and he have the same "problem", that the balls wears real quick.
I guess they are aluminium, and as soon as the darker coating wear off, the "bare" aluminium wears down quickly.
Old 06-12-2014, 06:21 AM   #2125
Salkin's Avatar
I run them all according to the assembly manual.
Old 06-12-2014, 06:40 AM   #2126
I race in all kinds of track conditions, I do however put some Teflon spray on all my pivot balls.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 06-12-2014, 07:40 AM   #2127
skrichter's Avatar
Has anyone figured out how to install other manufacturer springs on this car?
Due to the taper spring/15mm spring cup, sounds like we are limited to only TLR springs?
Has anyone tried to install a AE/KYO or other 16mm shock end/cup?
Its always nice to have options...
Old 06-12-2014, 08:40 AM   #2128
I think it's tapered for clearance purposes and to reduce the risk of the spring cup ejecting during a crash.
Old 06-12-2014, 08:55 AM   #2129
Salkin's Avatar
Some at our track are using the 15mm springs from their previous 2.0's, they just use the cups from a 2.0 and they fit nicely.
Old 06-12-2014, 09:16 AM   #2130
skrichter's Avatar
The 15mm springs fit over the shock bodies? Interesting.
I was hoping to use the more standard 16mm springs.
Tags
e-buggy, eight 3.0, losi, spur gear
