Old 05-12-2014, 05:27 PM   #1921
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
That is cool. But looks like its $200?
pimpedaccord is online now   Reply With Quote
Old 05-12-2014, 05:50 PM   #1922
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Potoczak View Post
Where did you purchase the scale system at??
We have a local distributor for skyrc. I'd does up to 2000grams per scale. I paid 120$ for it.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 05-12-2014, 05:54 PM   #1923
And the truggy, for those on the fence about converting the T 3.0
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 05-12-2014, 05:57 PM   #1924
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Salkin View Post
I don't know which Phend setup you tried, but did you notice the setup he posted here some pages back:
TLR 8IGHT E 3.0 THREAD
I copied this setup to my sons and mine E 3.0's, as we drive on somewhat similar tracks as the Fear Farm Raceway.
I can't see which kind of track you are running on, so don't know if this setup is relevant. Anyway:
We have changed the shock oils to 45F/40R, as this suits our particular track better.
I'm not a pro racer and I have just started experimenting with setup, so please take my advise with "caution".
I made another change to my car, because I think i did not have enough (or fast enough) initial steering going into tight 180 degree turns, which there are some of on our track.
There are probably tons of combinations of setup changes to gain more off power steering, but I didn't want to mess up the whole setup, so i tried to install the short ackerman link, which gives a more aggressive initial steering, so the car turns faster into the tight turns.
So for now, I have used the short ackerman link to gain some more off power steering, so that the car much more nimbly snaps around those 180 degree turns while still being sufficiently stable not to become "twitchy" in other parts.
Thanks for the link and input. I have seen that set up.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 05-12-2014, 05:59 PM   #1925
UN4RACING's Avatar
symmetricon dude you have those dialed. I haven't had a chance to scale mine yet. I will try to get around to it tomorrow and see where mine is at.
Old 05-12-2014, 06:02 PM   #1926
And the great part is that I hardly had to do anything. Losi has done there homework....
Having a balance car does wonder for stability and track consistency. I'm loving these cars.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 05-12-2014, 06:03 PM   #1927
Originally Posted by RC Geezer View Post
what size turnbuckle wrench is needed for the 3.0e and what size hex wrench's are needed to assemble the kit?
1.5, 2.0, 2.5, 3.0,
0.50, 1/16, 3/32
I use tlr turnbuckle wrench.
kahuna2793 is offline   Reply With Quote
Old 05-12-2014, 06:31 PM   #1928
UN4RACING's Avatar
The turn buckle wrench is 5mm
Old 05-13-2014, 12:48 PM   #1929
Originally Posted by symmetricon View Post
What didn't you like about the stock setup?
What was wrong with the shock boots?
I'm currently running the 3.0 truggy (rear) boots all the way around on my 3.0 buggy. Works like a charm! Make sure you use the rear boots all around as they are long enough to do the job. Slide the boot completely over the shock end and let it rest on the shock shaft. It will not tear or ever balloon up. The tips of the boots are made differently than the buggies and they are thicker.
***TLR 8ight-E 3.0***
Tekin 2050, Tekin RX8 Gen 2, Savox, Avid, Venom, Spektrum.
Tekin 1900, Savox, Spektrum (current build)
* both transmitted by a loose nut and a DX4R Pro *
8ighteRun is offline   Reply With Quote
Old 05-13-2014, 07:03 PM   #1930
They have new boots out for the buggy that are the same style as the truggy. They work great!
Old 05-13-2014, 07:18 PM   #1931
Holeshot114's Avatar
I just picked up one of these cars. What parts do i need to stock up on for racing?
Holeshot114 is offline   Reply With Quote
Old 05-13-2014, 07:23 PM   #1932
The upper aluminum servo saver half, front shock shafts, and shock shaft ends....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 05-13-2014, 07:45 PM   #1933
UN4RACING's Avatar
Well I got the CSI boots and I didn't like them either. I guess I will try the truggy ones. Do ya have a link?
I did 3 packs tonight and the set up is getting better. Like symmetricon posted. Same shock oils rock! Red csi pistons with TLR 32.5 were good on a dry dusty track. I'm looking forward to Friday night when the track is prep'd. And I am going to test the short akerman as well. Still chasing some off power steering. Some great input from you guys I appreciate it. Its been a nice short cut to get this baby dialed in.
Old 05-13-2014, 07:50 PM   #1934
Are you looking for off power turning in tight 180 sections? The roar nats layout had some and Dakota opted to run the front camber link shorter. I tried it and it definitely helped the car rotate more mid and exit steering. It did however make it push a little through the sweeper. However, I have not tried the short akerman, keep us posted on how it works for you....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 05-14-2014, 03:37 AM   #1935
maddog9's Avatar
Trader Rating: 29 (100%+)
Definitely get a set of bearings espesically the outter hub bearings nearest the wheel. Front caster blocks and spindles, rear hubs.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
