Old 04-27-2014, 04:40 PM   #1786
Trader Rating: 120 (100%+)
Well said and to the point. Find what works for you and run with it.
B6D
B64D
Tekno EB410
JoeC is offline   Reply With Quote
Old 04-27-2014, 06:24 PM   #1787
Any pics how you run 2s lipos side by side?
kahuna2793 is offline   Reply With Quote
Old 04-27-2014, 06:27 PM   #1788
Originally Posted by auto2 View Post
are the hinge pins supposed to bind in the arm and rotate in the plastic insert? or should the pins fit smooth in the arm and bind in the insert.
Ideally they should not bind in the arms or the inserts. Rear arms this is easily achievable. Front arms are a different story. The drop screws binds the hinge pin. I gave up trying to ream it with my crappy Turdigy reamer. Someone posted earlier in this thread that slightly drilling out the droop screw hole before inserting the screw fixed the issue.
BTW, the stock grey hinge pins do bend easily on this buggy.
kcobra is offline   Reply With Quote
Old 04-27-2014, 06:43 PM   #1789
i have a hudy reamer and a 4 MM drill bit. nothing works. ill check out the droop screw . thanks for the tip.
auto2 is offline   Reply With Quote
Old 04-27-2014, 06:47 PM   #1790
symmetricon's Avatar
Trader Rating: 27 (100%+)
Yeah, the stock hinge pins are not that strong. I ordered hardened tool steel drill blanks and cut them to size, bulletproof.........
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is online now   Reply With Quote
Old 04-27-2014, 07:09 PM   #1791
Trader Rating: 20 (100%+)
Pre-tap the droop screw holes with a 10/32 tap and pins will slide thru smoothly.
Randy
RandyJones is offline   Reply With Quote
Old 04-27-2014, 10:31 PM   #1792
thanks a lot for your answers.
@b_recliner: I fully agree with you. Anyway i don`t want to copy everything i see on the pro cars but i was curious of the reason why they change something drastically like that. I will have to buy at least another scale to see how the weight bias with my rather heavy 4S1P LiPos is (582gramms). As far as i can tell the additional little brass weight added to the front underneath the front diff pinion had a noticeable, positive impact so i guess the movement of the LiPo will have even more. If it turns out positively for me i don`t know.
Regarding the Hinge pins: I thought about getting spring steel in a high material grade, chrome them and put them in to see how long they last? To get those Mugen pins would be a much easier and cheaper way though. As i said lots of us have the same problem with binding suspensions on this car. Sometimes caused by something else but often by bended hinge pins.
Speaking of binded Suspension, i bought a ball miller for my dremel which is slightly smaller than the hole in the rod ends. Squeezing with pilers didn`t help very long. Now i don`t have axial movement but they turn very smoothly on the balls.
@Casper: Thanks for your answers too and specially the hint about the clutch. I never came to the idea that it basically works like a slipper. But it makes sense He probably can adjust the preload accoridng to the grip level. Once it exeeds a certain torque it slips.
Can you actually buy this clutch in the states or is it commonly used over there ?
Regards
Florian
ZeGerman is offline   Reply With Quote
Old 04-28-2014, 07:50 AM   #1793
ta_man's Avatar
Trader Rating: 151 (100%+)
Regards
Florian
You can buy the clutch from Tekno RC - it is called "Traktion Drive".
Commonly used? No. Some people use them but direct drive via a pinion/spur is more common.
ta_man is offline   Reply With Quote
Old 04-28-2014, 07:57 AM   #1794
Casper's Avatar
Trader Rating: 33 (100%+)
Regards
Florian
I know they are working on stuff.......
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-28-2014, 08:22 PM   #1795
Will the sensor wire that you get with a tekni t8 1900 work or is it to short?
Old 04-28-2014, 11:36 PM   #1796
No you will need a longer one i use 300mm
Old 04-28-2014, 11:38 PM   #1797
Thanks for the Information. I checked it on Amain. I don`t want to have the additional maintenance work to do.
Old 04-29-2014, 07:10 AM   #1798
SirWraithe's Avatar
Hello all, I have a question, I tried searching but cant find an answer, Can i run premounted AKA wheels or do I have to run the Losi stock wheels because of offset? I've been running stock wheels, but wanting to run some premounts. Anyone using premounts on 3.0 E? Please Advise, Thanks!!!
3 ET48
2 Losi 8ight 3.0 e
3 Sct410
1 EB48.2
and about 15 others....lol
SirWraithe is offline   Reply With Quote
Old 04-29-2014, 07:20 AM   #1799
maddog9's Avatar
Trader Rating: 29 (100%+)
Aka premounts work just fine.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 04-29-2014, 08:56 AM   #1800
What kind lipos everyone running?
What specs and runtime?
Tags
e-buggy, eight 3.0, losi, spur gear
