Old 04-10-2014, 10:05 PM   #1666
What is the smallest pinion I can use with the stock 43 tooth spur gear and still mesh up properly? What if I used the optional 45 tooth?
It will be on a Castle 1515 2200kv motor if that makes a difference.
Also, how is the ESC actually attached to the chassis on the new 8IGHT-E 3.0?
Art Henk is offline   Reply With Quote
Old 04-11-2014, 12:41 AM   #1667
Salkin's Avatar
Just out of curiosity, why "the smallest pinion" available. Guess you will be seriously under geared with that motor before you even reach the "physical" limit.
The ESC is mounted with adhesive tape directly on the chassis plate for low CG. Some are concerned with the lack of cushioning, but some attach the ESC with very thick tape etc. The issue have been asked before and some solutions have been given. Search for "esc", "shock", "chassis" etc. and you will find it.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 04-11-2014, 01:55 AM   #1668
Salkin's Avatar
Originally Posted by Dakotah Phend View Post
Here is a copy of my setup from the Nitro Challenge.
I have copied the setup that Dakotah Phend posted in post #1439, which fits me good for the type of tracks I run on.
The sheet have no tickmark in the "Wickerbill" option section.
Do you guys think he ran with no wickerbill?
Does any of you run without the wickerbill? If so, in which conditions?
Old 04-11-2014, 02:16 AM   #1669
maddog9's Avatar
Trader Rating: 29 (100%+)
Run a 14T with the 43t thats the smallest you can run.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 04-11-2014, 08:13 AM   #1670
TLRacing
Missed that. I run the .350 wicker bill.
TLR-Team Losi Racing, Team Orion, Pro-Line, Spektrum, Nitrotane, Horizon Hobby, Darkside Designs, StickIt1 Racing, Lunsford, OCRC, LiveRC, RC Scoring Pro, AMS, & Stateline
Dakotah Phend is offline   Reply With Quote
Old 04-11-2014, 09:09 AM   #1671
Salkin's Avatar
Super, many thanks
Old 04-11-2014, 12:28 PM   #1672
Thanks guys! I forgot to mention that the reason I was asking about the SMALLEST pinion was because I may run 6S at times because I already have eight 3S batteries. They are all matching pairs for my E-Revo that I bash around from time to time. I can always turn it down a little bit on my radio. I know I won't want or need full 6S power on the 8IGHT-E.
I asked about the ESC mounting because I will be using a MM2/2200 combo and was going to use the traxxas hold down for the ESC. It's actually a nice little mount, but there won't be any way to mount it unless I drill and countersink a couple holes in the chassis.
Does anyone have experience just running a buggy on 3S? That would certainly cut down on battery weight in my current situation! Cut it by half!
Old 04-11-2014, 12:34 PM   #1673
On 3s you will need a really high C rated battery or you will puff it. Not really enough voltage to push a 2200.
Smoothwon is offline   Reply With Quote
Old 04-11-2014, 12:49 PM   #1674
My 3S batteries are 60C constant 120C burst.
I broke down and ordered a couple 4S batteries with my 8IGHT-E 3.0 kit just a few minutes ago. They will get me by for now.
Old 04-13-2014, 11:26 AM   #1675
Trader Rating: 15 (100%+)
Could anyone recommend a servo that is good to use for racing? Coming from 1/10 2wd buggy so this is all new. How much torque and speed should I look for?
dbracn is offline   Reply With Quote
Old 04-13-2014, 12:22 PM   #1676
Casper's Avatar
Trader Rating: 33 (100%+)
With a some new ESC's allowing HV BEV (like the teking RX8 Gen 2) we like the S6090 for steering.
I would look for under .1sec and something in the 200in-oz range at a minimum.
http://www.spektrumrc.com/Products/D...odID=SPMSS6090
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-13-2014, 02:38 PM   #1677
Salkin's Avatar
Servo recommendation for 1/8 Buggy?
Old 04-14-2014, 06:38 AM   #1678
WORC1's Avatar
I use the Kyosho Zeal Vibration Absorption Gyro/Receiver Mounting Gel (KYOZ8006) for mounting my ESC. It is about 3-4 mm thick and sticky as heck. I ran it in my SCTE directly mounted to a King Headz without issue for 2 seasons now.
_________________________________________________________________________
8IGHT-T 3.0 ^^ WERKS B5 ^^ 8IGHT-E 3.0 ^^ Losi TEN-SCTE ^^ NOVAK ^^ HOBBYWING (laugh away, been good to me) ^^ SAVOX ^^ AIRTRONICS
WORC1 is offline   Reply With Quote
Old 04-14-2014, 10:44 AM   #1679
Team Tekin
TY@TEAMTEKIN's Avatar
6S 2200kV is a terrible track setup, you'll have to turn it down a ton. You need a motor in the 1700-2000kV range.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 04-14-2014, 11:54 AM   #1680
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Anyone tried the overdrive gear?
Matt Reinders
8ight E 3.0
Elite Performance
GMS_Racing is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
