Old 06-09-2013, 08:27 AM   #151
ChrisWolfson's Avatar
Send a message via AIM to ChrisWolfson Send a message via Yahoo to ChrisWolfson Send a message via Skype™ to ChrisWolfson
Originally Posted by kufman View Post
Agreed, ditch the brace. The problem is also partially caused by the use of Losi's cheap plastic spacer that goes under the motor mount. I ditched that as well (had to grind the chassis for spur clearance) and I have never had a problem with the motor mount coming loose from the chassis. I don't even use locktite anymore. An alternative would be to build a spacer out of something that isn't so soft like aluminum or carbon. Without the spacer, a 42mm motor sits very close to the chassis. With the 2.0 and 3.0 chassis, the flex may cause the motor to hit the chassis and you will have the same problem as the brace caused.
I'm also not running the brace under the motor. I am using the plastic under the motor mount, however...
TLR / Horizon Hobby / Spektrum / Tekin / JConcepts / MIP / B-Fast RC / UpGrade RC
ChrisWolfson is offline   Reply With Quote
Old 06-10-2013, 10:36 AM   #152
alport78's Avatar
I used my losi 3.0 first time this weekend. It was easier to drive than my old converted EU. I used pretty much std setup with 35wt oil in both front and rear and pleased with it on a blown out med traction euro style track. What about your shock setups ?
Schumacher KF2
alport78 is offline   Reply With Quote
Old 06-10-2013, 11:16 AM   #153
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up
37.5 front 27.5 rear
I got hit from behind and bent a shock shaft.... sigh.... im up and going now.
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 06-14-2013, 03:11 AM   #154
Hey guys, I would like to ask a favour, does anybody know the weight of the car as a roller, and ready to race I just want to do a few comparisons with my 2.0 scte buggy
Cheers
goldy is offline   Reply With Quote
Old 06-17-2013, 05:40 PM   #155
Sorry - don't have he weight.
Old 06-20-2013, 08:59 AM   #156
JasonR/C's Avatar
I sense a new 3.0 converted to electric in my future! Or today I should say. I'm pumped!
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 06-21-2013, 05:37 PM   #157
JasonR/C's Avatar
Anyone know what spur pin setup is good? Just got the car and converted to electric. 1950kv motor, stock electric spur is 45T. I have a 15pin so far seems really fast. Tracks are hard packed dusty some times blown out and pretty long straight. What do u guys recommend
Old 06-21-2013, 08:20 PM   #158
XXXDad's Avatar
Thumbs up Your good
Stay with that.
Old 06-22-2013, 05:01 AM   #159
JasonR/C's Avatar
OK thanks xxxdad. I have some nitro parts that came with the kit... I wonder if I could sell that stuff. I'll be racing car for the first time tomorrow. Anyone e have a good outdoor setup they would like to share? I just installed drake roar bats winning setup as a start. Same everything minus 7k center diff. I'm go name run 5-5-3. Tracks I run on are hard packed, with a decent dust layer on the outside of the groove. Very dry in the groove
Old 06-22-2013, 05:39 AM   #160
XXXDad's Avatar
Thumbs up Sell the nitro stuff
I got $110 for the nitro stuff...... Use the Drake setup and go.... Works great.
Old 06-22-2013, 09:42 AM   #161
JasonR/C's Avatar
What does that consist of. Meaning what parts did u post? And what was the thread name u used?
Old 06-24-2013, 09:25 AM   #162
JasonR/C's Avatar
Hey guys ran my new 3.0 yesterday and its pretty awesome, on a dry, dusty, bumpy, lots of jumps track, I noticed some front push on power and rear end swinging around on and off power with drake nats setup. Any tips? Or anyone have an outdoor setup they can share? Thanks!
Old 06-24-2013, 09:58 AM   #163
bigbadbasher's Avatar
Start here, i know the 10 or 12 degree spindle gave me a lot more on power, if you do go with those, make sure you do the 11mm mod.
Edit, my attachment isnt showing up.
If your using Drakes 2013 nats, it's for a smooth indoor track, you need a good outdoor track setup to start with.
What are you running in your diffs?
bigbadbasher is offline   Reply With Quote
Old 06-24-2013, 10:50 AM   #164
JasonR/C's Avatar
I'm running 5-5-3 and 37.5 front, 30 rear. Everything else is drakes exact setup. What's the 11mm mod?
Old 06-24-2013, 09:10 PM   #165
JasonR/C's Avatar
Nobody has any advice or outside setups for this car? Should I have bought a tekno? This thread is way to quiet.
Tags
e-buggy, eight 3.0, losi, spur gear
