Old 03-19-2014, 09:22 PM   #1546
What gearing should I try for my 1900 motor with the 43t spur.
masin14 is offline   Reply With Quote
Old 03-19-2014, 10:01 PM   #1547
Salkin's Avatar
If you search this thread for the words "pinion", "spur", "gearing", "1900kv" etc. you will see that there is a lot of info on this.
Or check out the TLR setup sheets. It contains info on motor kv, spur and pinion. Most TLR drivers use a 1900kv motor, so there should be good info for you in the sheets.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 03-19-2014, 10:49 PM   #1548
1badgoat's Avatar
+1
Teach them to how to fish!
TLR/Futaba/Hitec/Tekin/Hyperion privateer
1badgoat is offline   Reply With Quote
Old 03-20-2014, 03:37 AM   #1549
The 13 pinion should be good for most tracks. You could try 14 or 15 for really big tracks (we don't have any big tracks around here).
Our local pro runs a 15/45 everywhere. The 45 spur with the 15 provides better mesh and provides a similar gearing to the 13/43--the 13 with the 43 tends to chew the spur up (this happened to us far too many times ... and YES we know how to properly set mesh, before you ask).
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 03-20-2014, 04:20 AM   #1550
Trader Rating: 20 (100%+)
Put a 15 on and race it!
Randy
RandyJones is offline   Reply With Quote
Old 03-20-2014, 09:58 PM   #1551
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Looking for info on 3.0 E-Truggy, Iknow as a kit it is not available but I will be converting the 3.0 Nitro Truggy. I have done a search with no results, any help would be great.
BLKNOTCH is offline   Reply With Quote
Old 03-20-2014, 10:49 PM   #1552
1badgoat's Avatar
Get a 3.0 truggy, losi conversion kit and electronics and your in business. Need any other info go to the 2.0 e truggy thread or pm me.
Old 03-20-2014, 11:27 PM   #1553
BLKNOTCH's Avatar
Perfect this is what I was going to do I am trying to figure out what body people are running?
Old 03-23-2014, 08:11 PM   #1554
Well I ran my new 3.0 e for the first time this week and man it is an awesome car...my only complaint is the battery straps....they are too long!!! Cept the one that goes front to back....the two shorter ones are still way long...any alternatives??? Also any good ideas for mounting the tekin esc switch?
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 03-23-2014, 08:53 PM   #1555
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
If anyone is selling a clean roller please let me know. I missed out on a sweet one last night.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 03-24-2014, 04:20 AM   #1556
maddog9's Avatar
Trader Rating: 29 (100%+)
Shoe goo or double side tape the switch to the inside of the side gaurd. Mount the "on" towards the front. I have the same issues with the straps. Im not sure if the scte 1.0 straps would be a better fit or not.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 03-24-2014, 07:33 AM   #1557
Use the 3M double sided tape (buy at Lowes etc.). It is killer, and a $5 roll will last a decade! Just MAKE SURE that you clean all surfaces with alcohol (and let it dry) before mounting or it will come loose.
Old 03-24-2014, 01:50 PM   #1558
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Buy the Losi straps from the original 8E conversion kit. They are identical, except a few inches shorter. P/N is: LOSA4463
Perfect for smaller packs.
pimpedaccord is offline   Reply With Quote
Old 03-24-2014, 02:29 PM   #1559
dtr
dtr's Avatar
There's about 10% difference between those two; I wouldn't call them similar.
dtr is offline   Reply With Quote
Old 03-24-2014, 06:35 PM   #1560
+1. I stole the straps from my 8e 2.0. They work fine with the lower profile 6s packs I run. The 3.0 left to right straps were way to long.
kcobra is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
