Old 03-13-2014, 08:54 AM   #1531
Team Tekin
TY@TEAMTEKIN's Avatar
Originally Posted by maddog9 View Post
Many will say you need a high c rating, the truth is you don't. I will be running the ecopower 4100 4s with 35c rating. 12 minute run time and only 54 bucks at amain. 2-2s will fit if you lay them on there sides with the bullets parallel to the chassis. I ran nanotech 5600s with a tq side bullet as the jumper wire.
35C is about the bottom and some batteries will damage an ESC if the C rating is too low, or can't hold what it claims. It's just like putting 87 octane in a car that calls for 91, chances are it will knock and eventually blow up.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 03-13-2014, 09:28 AM   #1532
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
True i used those same 4100 35c packs in e-buggy all last season with no issues.
I don't think it's as necessary in e-buggy as it is in some classes (ie; 4wd sct). The efficiency is much higher with 4s setups than 2s so you can get by with lesser batteries. Just like i stated above how i did for a whole season and i am still using the same esc with no problems.
Originally Posted by hacker07 View Post
The diff fluids are great and what we normally use. The shock oil is different than what we package here in the US and so we typically tell people to use our regular packaged shock oils.
What shock oils would you reccomend for a good overall starting point? I only have ae oils and i've heard they differ a bit in viscosity compared to losi oils. Thanks.
TLR 8ight-E 3.0 ---tekin 1900---hobbywing sct pro
Traxxas 1/16 rally (for giggles)
TLR 8ight TE 2.0-----hobbywing 2250Kv-------hobbywing sct-pro
---------"Blessed are those who get to race year round"---------
Rockthecatbox21 is offline   Reply With Quote
Old 03-13-2014, 02:33 PM   #1533
Default Center Diff Play
What is the recommended center diff play (forward/rearward) not teeth mesh?
The total play is 1mm on mine. It is one month old. 3 days at the track. I built it to the book with shim/spacers. I am cleaning it and noticed alot for front to back play. No issue on the track yet, but wondering.
Thanks,
Turbo
Turbo911 is offline   Reply With Quote
Old 03-13-2014, 02:44 PM   #1534
Default Servo saver top
I have broken two of the plastic servo saver tops now. Will the aluminum one from the 2.0 work? The new TLR part number isn't due until late April.
Tekno SCT 410.3 rx8gen2/pro 4 4300HD 1267 savox servo
Tekno EB 48.3 rx8gen2/t8 1900kv 1267 savox servo
Tekno NB 48.3 Novarossi 5PXLT 1267 savox servos
all controlled with spektrum dX4R
skyler hays is offline   Reply With Quote
Old 03-13-2014, 03:40 PM   #1535
The one from the 2.0 works as long as you use the typical ackerman link which is the longer one.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 03-13-2014, 03:53 PM   #1536
maddog9's Avatar
Trader Rating: 29 (100%+)
You can run the 2.0 aluminum top and grind it out where the Ackerman would rub.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 03-14-2014, 05:27 PM   #1537
+1
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 03-15-2014, 04:28 PM   #1538
Deacon_8T's Avatar
Thanks,
Turbo
I've got at least 2mm of play in my center diff. It walks back and forth a bit and doesn't seem normal. How much play should there be? Should the center diff be shimmed at all?
EDIT: I just found TLR242008 - shim and spacer set
Also switched from the plastic to metal spur...totally different sound! I hope it grows on me.
TLR 8 3.0 - TLR 8T 3.0 - TLR 8E 3.0 - TLR 22T 1.5 -
TLR - Spektrum - Alpha - Tekin - Savox - AKA - BCE - JConcepts - Tonys Screws - Dialed Inc - Buku - SMC - St.Louis RC - Red Rock Hobby - Amain Hobbies -
Deacon_8T is offline   Reply With Quote
Old 03-15-2014, 04:44 PM   #1539
Trader Rating: 15 (100%+)
I recently had my center diff out. When I put it back together with no shims I noticed it had a bit of play. 1 shim took care of it. Figured 1 shim would make it too tight, but it was perfect. Try a shim or two if you have any. edit: I thought I was on the scte thread. My bad. 8ight is pretty similar though.
Tommygun1 is offline   Reply With Quote
Old 03-15-2014, 06:13 PM   #1540
Not nearly as much traffic on here as the tekno threads. It's weird not getting a response within an hour or so.
Old 03-15-2014, 07:49 PM   #1541
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
I swapped the stock pistons around from box set up. 1.5 front 40wt / 1.4 rear 25wt. (losi oil)
Here is a conversion chart:
KIK is offline   Reply With Quote
Old 03-17-2014, 04:22 AM   #1542
Trader Rating: 20 (100%+)
That's because my kid just cleaned house in Ohio with prolly 90% of the cars being the Hekno cars!! Lol!! Did it in Pro4 too!!
Randy
RandyJones is offline   Reply With Quote
Old 03-19-2014, 07:46 AM   #1543
Durocken's Avatar
I have a small issue/problem. My rear gear box is smooth until I get to a small section of the crown gear, it gets very rough and binds a tiny bit. Will this "wear" in or should I pull it apart? I ran it in my driveway, I still feel it when I free spin the drivetrain.
TLR
Airtronics / Savox / Tekin
Durocken is offline   Reply With Quote
Old 03-19-2014, 08:20 AM   #1544
Yeah, this will wear in some.
-Ryan Dunford
Old 03-19-2014, 10:27 AM   #1545
Durocken's Avatar
Ok thank you
TLR
Tags
e-buggy, eight 3.0, losi, spur gear
