Old 05-27-2013, 04:50 PM   #136
Default Losi 3.0 shocks
I'm having a hard time building these shocks with no rebound. Is it possible? Also could some one explain the easiest way because the directions definitely don't cover it. Thanks
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
Old 05-28-2013, 07:12 PM   #137
Brian C.'s Avatar
Hey guys is anyone have problems with stripping the spur gear? I'm on my 5th one and its meshed correctly... I have other cars that are 3yrs or old and never stripped a gear...
T&L BOYZ
Trains and Lanes Racing
Team Kyosho
Brian C. is offline   Reply With Quote
Old 05-28-2013, 07:14 PM   #138
Brian C.'s Avatar
I would not say impossible, but I was not successful in getting zero rebound either.... I eventually gave up, so I would say it is more unlikely than likely to get zero rebound.
T&L BOYZ
Team Kyosho
Old 05-28-2013, 07:38 PM   #139
ChrisWolfson's Avatar
Send a message via AIM to ChrisWolfson Send a message via Yahoo to ChrisWolfson Send a message via Skype™ to ChrisWolfson
Originally Posted by XXXDad View Post
What setup did you start with chris>> Mine is
Front shock 32.5
Rear shock 27.5
5/5/3
the rest was Drake settings.
I ran 40 in the front, 30 in the back, and 5/7/3 for the diffs. Good place to start.
TLR / Horizon Hobby / Spektrum / Tekin / JConcepts / MIP / B-Fast RC / UpGrade RC
ChrisWolfson is offline   Reply With Quote
Old 05-28-2013, 07:40 PM   #140
I had a little bit of rebound in my shocks as well...
Old 05-28-2013, 07:57 PM   #141
Whats the best steering servo for the 8ight e 3.0?
JQuite is offline   Reply With Quote
Old 05-29-2013, 08:19 AM   #142
XXXDad's Avatar
Trader Rating: 195 (100%+)
I use Jr 9100 S or T
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 05-29-2013, 11:07 AM   #143
The overall quality of the new shocks are awesome. I guess I'll be the first to say "please come out with shock caps with the screw in them ".Makes setting the shocks so much easier.
Old 05-29-2013, 01:19 PM   #144
8th scale shock have historically always had bladders. I don't even know if anyone has built them without, meaning emulsion. For indoor circumstances, it may be worth trying. As tracks get bumpy, bladders serve to push the tire into some of the holes to give you more traction and truer tracking.
...and upon building the new shocks for the first time, they are kind of like WOW. As good or better than any K shocks I've built.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 05-30-2013, 06:04 AM   #145
I see. No tips on how to get zero rebound or is it not necessary.
Old 05-30-2013, 08:20 AM   #146
XXXDad's Avatar
Thumbs up The least possible
With a bladder just try and get the least possible.
Old 05-31-2013, 03:22 AM   #147
smy_dog's Avatar
i just stripped my first after running 4 batteries through it, i had this problem on my 2.0 but i was lucky to get one race meet with that car so soon changed to a metal spur.
every gear i have stripped happened when i land hard off a jump and it will brake a tooth off then it goes from there. i will be buying a metal spur gear as i did with my last buggy
smy_dog is offline   Reply With Quote
Old 05-31-2013, 03:41 AM   #148
XXXDad's Avatar
Exclamation Locktight evrything leading to Alu.
Originally Posted by Rawwolf View Post
I had read earlier in this thread that the plastic motor brace will cause the motor to flex and then you will shred the spur. If you run with out it the motor will only flex with the motor mount thus keeping the pinion and spur moving together.
I agree, I have found also that the motor mount needs locktite and recomend checking for loose screws every time your in the pits. The chasi flexes alot and anything under the motor( like the rear brace) just hits the motor like a hammer on big landings.
Old 06-08-2013, 08:00 PM   #149
I'm using this one...
http://www.spektrumrc.com/Products/D...odID=SPMSS6090
Old 06-09-2013, 06:34 AM   #150
kufman's Avatar
Agreed, ditch the brace. The problem is also partially caused by the use of Losi's cheap plastic spacer that goes under the motor mount. I ditched that as well (had to grind the chassis for spur clearance) and I have never had a problem with the motor mount coming loose from the chassis. I don't even use locktite anymore. An alternative would be to build a spacer out of something that isn't so soft like aluminum or carbon. Without the spacer, a 42mm motor sits very close to the chassis. With the 2.0 and 3.0 chassis, the flex may cause the motor to hit the chassis and you will have the same problem as the brace caused.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
