Measuring points on B4 and T4 to set ride heights
I was reviewing the Setup sheets on the Associated site.
I noticed the ride height on the http://www.rc10.com/racerhub/setup/r...assic_2005.pdf was set at a hard number for front and rear? Were are the measuring points? There is 10mm difference, I know the chassis does not site this low. Same with the B4 http://www.rc10.com/racerhub/setup/r...assic_2005.pdf what are the measuring points there as well? |
There is a 1mm differance in front to rear height if you set the car up level. This is due to the rear chassis plate being slightly sunk in when compared to the main chassis.
The measurements are taken just behind the front bumper and just in front of the tranny. |
