Need some help. 8ighte 811be dex410
I wanna know what is the best and smoothest 1/8 electric out
In terms of weight
Durability
I'm stuck between losi Durango serpent and duratrax associated hb
Any input on what seems to work best with less setup and fine tuning
I wanna also know which could feel closest to a 1/10 4wd buggy
In terms of weight
Durability
R/C Tech Elite Member
In terms of weight
Durability
In terms of weight
Durability
If you are just bashing, it really isn't necessary to invest in a Serpent. It's a very expensive high-end race machine that would be overkill for just bashing. The Losi 8ight would be a better pick. Very durable, parts are cheaper and readily available.
While I am obviously a fan of the Serpent, it is not light. The DEX408 is the lightest of those 3 in my limited knowledge. All 3 are capable chassis' out of the box. The Serpent and DEX require dual 2s packs while the Losi as I understand it can also use a 4s block as well. The S811 and DEX are both much narrower and electronics are more tightly packed. Only haven driven a B44 as my only 10th scale 4wd, and the DEX and S811, I would not say either feel like a 10th scale.
Eb48 hands down :-)
