Old 05-09-2005, 09:44 AM   #1
Default Newbie Nitro question
I'm new to Nitro, but I really love 4wd and the buggy style, so I went with Ofna, it looked like a good firm, and the mags all seem to like them, so I hope I made a good choice.
Once I figured out how to set the engine to run right (I was running it way too rich, would stall every 5 seconds or so) it's been very fast, and so far, tough.
I noticed on the ultra MBX pro, it has electric on-board starting. Looks like that beats the heck out of pull start.
Can my Ofna engine be upgraded to support that, or do I need a new engine (or worse, a new buggy)?
Pros and cons (if any) of electric on-board starting?
Thanks gang.
AttackDonut is offline   Reply With Quote
Old 05-09-2005, 07:27 PM   #2
GReddy's Avatar
Send a message via AIM to GReddy
id stick with the pull starter because the electric starter is alot heavier
GReddy is offline   Reply With Quote
Old 05-09-2005, 08:19 PM   #3
maxxman101's Avatar
Send a message via MSN to maxxman101
i would just get a starter box. i tried the pullstart for a little while when i had my ultra lx pro and i hated it.
My stable:
Revo 3.3, Kyosho 777 SP2, Kyosho ZX5, Robitronics Scalpel, AE RC18T, TLT1.
Futaba 3PKS with Spektrum
maxxman101 is offline   Reply With Quote
Old 05-09-2005, 08:27 PM   #4
Joel Lagace's Avatar
Default starter
Yes you can upgrage to a better starter system.
Pull starts should be banned from the hobby.
Your options:
-Roto start(hpi,hotbodie and ofna make this)
It use the oneway bearing from your pull start. You simply remove the pull start install the 2 gear box to the end of the motor and start it with there drill starter(included)
by far the most reliable way to start an engine.
-ofna and others make boxes for your buggy. In most cases u can simply stop using your pull start and start with the box.
-if you want to reduce weight and seal your engine you can remove the pull start cut the nub off the crank and get a non-pull start back plate. This will give your engine a perfect seal.
PS you dont need ezstart system like traxxas uses. IT mounts electronics and a motor to the chassis and its heavy. The options above are the best
"Without Rules its just Backyard Bashing!"
Joel Lagace is offline   Reply With Quote
Old 05-09-2005, 09:50 PM   #5
Trader Rating: 24 (100%+)
Default Re: starter
jbrow1 is offline   Reply With Quote
Newbie Nitro Question zerotorc Malaysian R/C Racers 26 04-02-2014 04:05 AM
Grand Rapids flight areas to fly nitro: newbie question nfimich RC Flight 2 03-02-2008 03:38 PM
Nitro newbie with an embarrasing question Imperator Nitro Off-Road 41 10-20-2007 08:58 AM
newbie .21 nitro question downunder23 Electric Off-Road 8 07-06-2006 10:15 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
SEO by vBSEO 3.5.0
