Arrma fury question
The gear diff that comes with the arrma is ok, you just have to replace the thick washers that go under the capture pin in the outdrive. Use an associated shim as a replacement and it'll run extremely well.
If you want to use the hpi, you just have to shim it since it will slide right/left without shims :-)
