Simple Green
Simple Green
I have been searching for opinions on this, and not really turning anything up. I got in a discussion with a fellow racer about the use of SimpleGreen to clean tires. This is not your ordinary basher that sometimes races but rather someone who is qualified for worlds and is well respected in the RC community.
He was explaining to me about the chemical compound of the tires and the difference between Chemical traction and friction traction. He also was explaining how there is a petroleum product in the "pores" of the rubber tire, and that SimpleGreen (being it is a degreaser) actualy removes that product.
He said at a national event you would not see anybody using SimpleGreen on their tires.
I have seen many people use SimpleGreen on tires.. and even more recommend using it.... but I found his chemical analysis very intriguing .. I was hoping to start a conversation about this with a more in depth look at what SimpleGreen really does to your tires from people who actually know
Advise to never use the green on the tires , leaves a film that does not help traction.
Use green to clean the body , car parts , wash hands , ect ...
Tip
just use water , a wire brush when clay packs up the tires .
Suspended
Simple green contains oil of wintergreen. A lot of tire sauces contain oil of wintergreen. Get two sets of tires that are the same compound, and have the same inserts. Test to see if simple green has an effect on the way the tires perform. Cleaning tires with a wire brush would be much worse for them. Think what it would do to the tread.
just pick up some of the x-factory tire cleaner. it's part number 9202. it's described as "This spray effectively cleans tires without leaving residue or "slimy" feel. Cleans the dirt off without changing the handling characteristics of the tire" i started using this stuff instead of simple green and it's a subtle difference at first but then it gets more noticeable. and it's better bringing a small 8oz bottle than a big spray bottle. give it a try
R/C Tech Elite Member
I've used Simp[le green for about 6 years and love it!
Why it works? I don't have a clue, but it does...
I use it in a 60/40 or even 70/30 mix with water, never full strength.
My tires are always nice and sticky!
Wire brush... Never! I wouldn't even do that with a dirt bike tire!
I use to use SG all the time but have since quit. Main reason is the tires prepped with it change too much through a run. They start out clean and mad grip then half way through they start gripping more true which is less. Now I just knock off any clay with a med. brush and before I run spray with Kal-Guard motor spray if needed. It just softens the rubber but no residue is eft so it feels very consistent start to finish. Just my findings and everyone is different.
we use the plastic tub with an upside down brush and water easy and clean, no cleaner needed.
I don't think he was meaning a metal wire brush, but just a stiffer style plastic brush. But I usually only clean mine if i happened to be in the race recently after a over watering. I am a simple green user around the house and in automotive and it is some good stuff. But some of the things Ive seen it clean i would assume would be hard on a rubber tire.
Whaaat
Simple Green has it`s own thread? Swaite...I use spray bottle Goof off to clean the body and the suspension arms ,towers ETC.Have to spends some extra time wit thE air hose but the stuff cleans well!!Does any one know if this..is hurting my plastics????Come on You science Nerds ..TELL ME!!
goof off has a solvent in it (can't remember which one, toluene?) so there is a possibility it could do some damage to plastics.
Onoo Thread derail
A very good wire brush for cleaning of packed clay off the tires...
