Associated SC10.2 Factory Team
#1546
Hey guys. I'm looking for some info on my sc10 2wd with speed passion pro esc(blue). Trinity maxzilla d3.5 17.5 motor. I have the motor timing set close to 10. Esc on the modified1 setting, level 9 and timming in the esc up to 22.5. Slipper is tightened almost all the way down. And the truck is just still slow as heck. It don't feel right. Won't even come close to pulling the wheels up or anything. Any ideas or help please.
#1547
setup question
I have an SC10.2 SC truck and I'm running stock 13.5 blinky class on a kinda small, tight indoor clay track. I have no idea what gearing I need to run. I burned up two motors last night and I'm on my last one.Please somebody give me an idea where I need to start on my gearing to keep this from happening again.
Thanks,
Cameron
Thanks,
Cameron
#1548
I have an SC8.2 SC truck and I'm running stock 13.5 blinky class on a kinda small, tight indoor clay track. I have no idea what gearing I need to run. I burned up two motors last night and I'm on my last one.Please somebody give me an idea where I need to start on my gearing to keep this from happening again.
Thanks,
Cameron
Thanks,
Cameron
#1549
ok, rebuilt my rear diff. it was noisey and shot.. also figured out on my speed passion esc settings was all jacked up and wasnt even set on the right turn motor! ( previous guy programmed it) Now it rips! my gearing is 25/75 and it was starting to get hott. im gonna throw my 29/75 back in it and check try that. thanks guys
#1551
ok, maybe i am going the wrong way then? yes kinda alot of wheel spin, we run on a loose dirt track....
#1552
Thanks,
Cameron
Thanks,
Cameron
If you can't make it Thursday I will have it figured out and can help you Friday.
Sc10.2 is what he meant BTW everyone. 13.5 blinky gearing.
#1553
anybody have suggestions on the setting is my esc. speed passion pro
i put it on the stock1 hybrid mode/boosted. and i love the way it performs with it
25/75 gearing. but it is just getting a little to hott after longer runs.
thanks
thanks
#1555
Are you guys mounting the diff adjusting bolt on the L or R side? Thought I read somewhere mounting it the wrong way may loosen the bolt
#1557
the screw head needs to be on the right hand side, under the spur gear thru the right outdrive...........
#1559
Cam come to the track with Ev and James Thursday and we'll figure it out. I need to do the same thing because I always have run my 13.5 boosted. This week though go through your truck and check for any binding. Just pull the pinion and spin it to make sure its smooth.
