Tekin Pro 4 HD Factory Thread
#646
Randy...What is the ideal current limit for rx8 g2 and pro4 HD 4300 with a losi SCTE 2.0?
#648
The most i usualy run is 50 with my pro4hd on indoor wet clay. Still seems to be more than enough.
#649
Alright so I'm picking up a new HD to run in my trophy truck (rwd). It's about 10 lbs all loaded up. I use a SC411 4600kv and a rx8 in it right now. (geared 40/12, run on 2s) Speed is great and temps aren't bad, but it has a bad cogging/shuttering issue at like 1/4 throttle. (tried many sensor plugs, and it has a glitch buster)
Really weird, I just need a pro4 HD...
So my question is, 3500 or 4300..?
Had a 4300 in my Tekno 4x4 a while ago and loved it, but like I said the tt is a RWD setup. Looking for efficiency mostly. I know both those kv's would be beast. Just looking for some opinions.
#651
But the TT is custom, full cage and everything. It uses parts from a bunch of different trucks. Here's my thread for it: http://www.rccrawler.com/forum/2-2-s...ml#post5040212
#653
Can't do 4s, it can only fit a 2s sized pack. I have all 2s packs now, but I may also consider the 3000kv on 3s..
#658
My rx8 data log is showing me reving to 60000rpm when im wide open down the back stright is that right. A 4300 should be closer to like the 35000rpm on 2s i thought is somthing wrong? Is this normal?
#659
Tekin Pro4hd 4300 Kv and Castle MMP esc lcok up
Ok guys I just bought a Tekin Pro4hd 4300 Kv motor and a Castle Mamba Max pro This weekend for my Losi Scte. I'm having problems with the power cutting off if I accel hard . If I accel slow seems like I have no issues, however when accel from dead stop it jerks bad and if in a turn wheels will go straight as if I've lost all power. I'm using a Hitec HS-7955TG Digital HT Titanium Gear Coreless Servo. Battery is a SMC 6500 with a 70c and 140c burst. Receiver is a sr300 and radio is a spectrum Dx3r. I've tried Different batteries different servo, I have solder the motor direct to the ESC elimitain the bullet plugs and I have soldered the bullet plugs to power so that esc plugs directly into battery without the need to deans or traxxas connector. Im stumped at this point. Castle sasy motor is to much for the esc however Tekin says it is not. I know others run this set up. any help would be nice
#660
Just doing a little follow-up. Ended up going with the 3500 on 2s, so happy I did. It's a monster. Handles the truck so well and it stays nice and cool. Couldn't be happier.
