17.5T Speed Help
#16
17.5 motor is fine to start off with, even in 4wd. ROAR even ran a 17.5 4wd buggy class last summer in the SuperNationals.
Your problem, plain and simple, is that you're gearing the car as if you're going to be driving a low turn mod motor.
For a 17.5 motor, grab yourself a 72 spur and like a 32 pinion and check temps after a few minutes of running, but you should be fine, and will likely end up something more like 72/34.
Your Orion ESC & motor is good equipment; no need to change it out.
Good luck.
Good luck.
