Hobbyking 60A ESC >
Hobbyking 60A ESC
Hobbyking 60A ESC
Old 02-07-2013, 01:49 AM
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Default Hobbyking 60A ESC
A friend of mine told me about these. Has anyone tried one or heard anything about them? They appeared to be a copy of the Hobbywing Xerun 60amp ESC. I'm curious if they run the same Hobbywing Software by any chance?
If they do they look awesome for the price!
http://www.hobbyking.com/hobbyking/s...nsorless_.html
snowman_evil is offline
Old 02-07-2013, 02:02 AM
darcness's Avatar
I have a Turnigy clone that I got from HobbyKing and it works with my HW program LCD box. Not sure on the actual HobbyKing ones, but my guess would be that they would work.
darcness is offline
Old 02-07-2013, 02:05 AM
Ok cool thanks for the feedback. By the turnigy one I'm assuming you mean this one?
Anyone else know about the Hobbyking ESC?
Old 02-07-2013, 03:36 AM
alb
Trader Rating: 20 (100%+)
welp, I'll let you know. I just ordered one. For 25 bucks, why not.
alb is offline
Old 02-07-2013, 03:41 AM
My thoughts exactly! Was just curious to see if anyone had tried one that's all
Old 02-07-2013, 12:52 PM
If these are a good fit for a Tacon Sensored 10.5T motor then I will be ordering one tomorrow.
P.Hill is offline
Old 02-07-2013, 06:18 PM
Anyone else tried or heard anything about these ESC's?
Old 02-07-2013, 07:35 PM
trick25's Avatar
Trader Rating: 28 (100%+)
i got one of those on the way. im going to pair it to a novak ballistic 10.5 in my stadium truck. shoudl be here early next week.
i run the 120a hobbyking in my 4wd SC. good little esc. only problem i have with it is it occasionally looses throttle range calibration(like once every 2 months.) like this
http://www.hobbyking.com/hobbyking/s...s_Car_ESC.html
i also have this one in my 2wd SC mated to a tacon 8.5(really more like a 10.5)
http://www.hobbyking.com/hobbyking/s...ESC_1_10_.html
trackstar ones are good too.
avoid the quick ones liek these
http://www.hobbyking.com/hobbyking/s...w_Reverse.html
and these
trick25 is offline
Old 02-08-2013, 03:54 AM
and these
Cool thanks for the info. Ive also ordered one, apparently they do run the Hobbywing software fine so if they do you can go past them for price
Old 02-08-2013, 04:21 AM
I have two of them in my possesion, one in my B4, and I'm about to put the other in my ECX Boost. I'm guessing that if this isn't an actual hobbywing ESC, then it's certainly a copy.
The B4 is running a 17.5T Trackstar with a 69 spur and 29 pinion. The motor with this combination is barely warm 6min qual, and so is the ESC. I've got a 1257 servo in there, and the BEC seems up to the task. Keep in mind, however, that I am a beginner, so I don't know if I'm putting enough demand on my components yet.
It uses the same exact looking Hobbywing software. So much so that I went looking for the Hobbywing software to see if I could get the ESC to work with it (I'm using the USB dongle). I couldn't find it anywhere online. If anyone is willing to share it, I'd be more than willing to test it out for them.
girmann is offline
Old 02-08-2013, 04:44 AM
darcness's Avatar
You can go to www.falconsekido.com and download the HW software.
darcness is offline
Hi Mate,
Thanks for the feedback. I'm running a very similar setup with the same motor also. My motor has never gone over 41 degrees after a 10 minute final. I've found the naturally like a bit of boost and timing as they run very cool. I run 17.5 blinky in my b4.1 so I can't use boost but have the punch in my esc maxed out and the motor still runs cool.
Anyhow back on topic of the ESC. Here is a link to the Hobbywing software. This is what you will need: http://www.hobbywing.com/product_show.asp?id=218
If you want to try it out that would be fantastic. To me they are definitely a copy as you mentioned
Old 02-08-2013, 07:16 AM
Suspended
Trader Rating: 440 (99%+)
If you want a very nice powerful esc for a good price go to brushless hobbies.com and check out the lt4.
MattP is offline
Old 02-08-2013, 07:22 AM
I'll try it this afternoon and let you know how it goes! Thanks for the link! (my google fu is failing me!)
Hi Mate,
girmann is offline
Old 02-08-2013, 03:04 PM
Sounds good keep us posted
Thanks!
