Like Tree4Likes
Old 03-07-2013, 10:32 AM   #1411
Originally Posted by hacker07 View Post
You do not limit droop with the current setup for off road use. You actually give it extra droop by unscrewing the shock ends.
The lower caps are plastic and yes, you will mar them some by screwing them on but that does not affect performance at all as long as you dont crush them so bad you ruin the center hole. We have fixed the tool and new caps should be here shortly for all that want them. you can contact CS but I would wait until these corrected units come in.
If you grab the lower cap after it is threaded on by hand as far as you can get it on the lip that the shock boot normally goes over and hold straight, you can use a shock cap and the top cap tool and slowly thread the bottom cap up all the way. this is all explained in the build tips.
\Yes I understand, so what is the schlock extended measurement? Or 2 turns out front and 1 turn rear. Not using any droop screws.
bladeys is offline   Reply With Quote
Old 03-07-2013, 10:34 AM   #1412
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
are the 1.0 and 2.0 arms the same? if so does that mean the RPM arms will work on the scte 2.0?
agarabaghi is offline   Reply With Quote
Old 03-07-2013, 10:39 AM   #1413
Originally Posted by bladeys View Post
I need to clarify this. Use the shock end adjustment for droop? If so what is the total shock extension measurement? Thanks
The way Ryan explained this back on the SCTE thread is, fully thread the shock eyelet to the shock shaft, then back it out 1-2 full turns or .6-1.2mm.
Still waiting on confirmation regarding the turnbuckle length and their relationship to toe/camber measurement reference in the manual setup sheet. It's starting to sound like they are not the same....thanks!
| TLR SCTE 2.0 | TLR 8ight-E 3.0 | Associated TC5R |
RC-Rick is offline   Reply With Quote
Old 03-07-2013, 10:46 AM   #1414
Yes they are the same, ergo the RPM will too.
Old 03-07-2013, 10:48 AM   #1415
Grandturk's Avatar
Yeah but why?
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 03-07-2013, 10:48 AM   #1416
XRated SCT's Avatar
good to hear I could put some rpm on my turck
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-07-2013, 10:50 AM   #1417
Casper's Avatar
Trader Rating: 33 (100%+)
Just set the steering links the same length put them on the car and adjust both sides the same until you get the toe in you desire. Camber links just make sure you have the same amount of thread showing on each side and adjust on the car as well.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-07-2013, 10:55 AM   #1418
Grandturk's Avatar
Kind of silly for a race truck. The TLR arms are very good and stiff and they don't break.
Old 03-07-2013, 11:03 AM   #1419
Originally Posted by Blown up View Post
Also, Anyone have an inside on pro4HD's release? I'm undecided on a motor for this truck. I've been running the 4000pro4 in a Rango and like it for indoor but the 2.0 being a little heavier, I think I want more power but would like to keep it smooth. pro4 4600, HW4700 4XS 4800 or 7200, SC411? Bad words for any of these?
I am hearing through the grapevine that we should see something end of this month, beginning of next...on the HD's
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 03-07-2013, 11:09 AM   #1420
Heh, we will see about that. I break most things =)
Old 03-07-2013, 11:09 AM   #1421
Suspended
pablo040 is offline   Reply With Quote
Old 03-07-2013, 11:16 AM   #1422
ok lets not start guys. If me or someone else wants to use rpm arms then we will... nothing you can do or say about it.
Old 03-07-2013, 11:16 AM   #1423
back on track is the steering drag link alum? are the steering posts alum?
Old 03-07-2013, 11:17 AM   #1424
XRated SCT's Avatar
Well this is only my 2nd rc and maybe I'm just used to the slash a-arms, I don't know how durable the stock scte ones will be but I'll take your word for it we'll see what happens
Old 03-07-2013, 11:18 AM   #1425
Grandturk's Avatar
I already said it. I don't know why anyone would put suspension arms that bend like wet noodles on their race truck.
Nothing against RPM - I use their rear bumper mount - which is very breakable BTW.
