Like Tree4Likes
Old 03-03-2013, 04:42 PM   #1111
TCCustoms's Avatar
Originally Posted by arrtay View Post
Hey guys, I recently ordered this kit from my Lhs. Should have it in two weeks or so. I've had the 1.0 sence it came out; been running the castle 3800kv 4 pole and rx-8. That match has worked out fairly well for my use, which is mostly tearing up the woods, and occassionally racing. I woulden't mind having a little more power and control in the motor department. Thinking about the Tekin 4 pole or maby the revtech 4 pole. Which one is better for this car? Or is another motor out that is better?
Hobbywing 3656sd(sensored) 4000kv or the 4700kv
http://www.falconsekido.com/products/xrm3656sd
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 03-03-2013, 05:07 PM   #1112
Trader Rating: 20 (100%+)
can you get the wheel pins with out buy hexes
xxxtruck is offline   Reply With Quote
Old 03-03-2013, 05:25 PM   #1113
Trader Rating: 68 (100%+)
Default Sensor Wire Length
Okay so I ordered a 200mm sensor wire for this build, and its way too short. The perfect length to go from my RX8 to PRO4 was 275mm. I'll attach the pictures showing how the wires were routed.
Official TLR TEN-SCTE 2.0 Kit Thread-img_3408-medium-.jpg   Official TLR TEN-SCTE 2.0 Kit Thread-img_3409-medium-.jpg   Official TLR TEN-SCTE 2.0 Kit Thread-img_3410-medium-.jpg
Volcomstned is offline   Reply With Quote
Old 03-03-2013, 05:26 PM   #1114
Grandturk's Avatar
Little known fact the wheel pins are the same as the CVD coupler pins so you can use them interchangeably and swap out the wheel ones for the CVD axle pins when the axle pins start to wear.
http://www.amainhobbies.com/product_...uplers-4-Ten-T
http://www.amainhobbies.com/product_...x-Set-w-Pins-4
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 03-03-2013, 05:29 PM   #1115
Grandturk's Avatar
Looks like you have a lot of slack in the wire.
Old 03-03-2013, 05:31 PM   #1116
TCCustoms's Avatar
so is that the 275mm wire installed or the 200mm?
Also, is the alum steering arm included in the kit?
Old 03-03-2013, 05:34 PM   #1117
With the 275mm, there is slack. The 200mm won't reach my esc even if I didn't run it through that wire tunnel on top of the center diff. The rest of my wires only have about 1/2 inch or less of slack. If I run a 550 can motor, my "C" pole wire may be too short.
Old 03-03-2013, 05:36 PM   #1118
KC10Chief's Avatar
How much are you guys paying for your kits? I ordered one from my LHS, but they still weren't sure what the final price was going to be.
AE TC6.1 WC w/RDS 6.2 Chassis; AE TC4
AE RC8T w/Tekno V4 electric conversion
2ea SC10; 2ea Losi Mini 8ight
TLR Ten-SCTE 2.0 (On Order)
KC10Chief is offline   Reply With Quote
Old 03-03-2013, 05:50 PM   #1119
I picked mine up for $449
Old 03-03-2013, 05:50 PM   #1120
Sounds good! Will it work with the rx8??
arrtay is offline   Reply With Quote
Old 03-03-2013, 05:52 PM   #1121
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Yes.
Feint Motion is offline   Reply With Quote
Old 03-03-2013, 06:08 PM   #1122
Originally Posted by Feint Motion View Post
Yes.
Sweet. Price is right too!
Old 03-03-2013, 06:08 PM   #1123
TCCustoms's Avatar
+1...that was out the door price also
Yes.
+1...you'll love this motor on the RX8
Old 03-03-2013, 06:13 PM   #1124
T. Herwig's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to T. Herwig
So would a 250mm be a safe compromise for this truck?
Tyler Herwig
Tekno RC teknorc.com ∙ JConcepts jconcepts.net ∙ Spider Hobbies spiderhobbies.com ∙ SMC smc-racing.net ∙ Upgrade RC upgrade-rc.com ∙ Kustom RC Graphics kustomrcgraphics.com
T. Herwig is offline   Reply With Quote
Old 03-03-2013, 06:56 PM   #1125
And this is it for now..
Thinking about going to pick up an R10 PRO.. What do you guys think... stick with my RX8 or get an R10 pro?
I would ask Ryan or Casper about the r10 pro.I think one of them is sponsored by Orion.I know for awhile they were waiting for a update on the software before the r10 could handle the 4 poles correctly.I forget where I read this but I Definately came across it somewhere.So don't pull the trigger until u ask about it.
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
