Like Tree4Likes
Old 02-01-2017, 03:40 AM   #9331
Originally Posted by maddog9 View Post
balance the wheels
Brand new rig!
StinkyFoot is offline   Reply With Quote
Old 02-01-2017, 03:57 AM   #9332
Originally Posted by StinkyFoot View Post
Brand new rig!
Sorry I am new to 1/10 scale models. NOOB.
Yes you were right! Swap around tires and only one wheel is normal rest of them are crap. By the way is it covered by warranty?
Old 02-01-2017, 05:41 AM   #9333
Hi guys,
and sorry but I am going to ask a lot of questions in the coming days.
I have a feeling that my newly purchased Troy Lee RTR was assembled a little bit clumsy. The servolink is shorter an it is hitting the thingy. The Camber and Steering Tierod is shorter compared to SCTE 2.0 build manual.
My question is, can I re-build based on the 2.0 Kit guide will it work?
And of course tire problem they are off balance 3 out of 4.
Thank you for your input.
Old 02-01-2017, 09:57 AM   #9334
Casper's Avatar
Trader Rating: 33 (100%+)
Stinky-- These are not automotive tires that are balanced. If you are revving the tires on the bench and are wobbling it is likely they are just out of balance. They will not balance your tires on an RTR. I have never seen a balanced RC tire offered ever. This is something you would need to do. when running the car on the ground I doubt you would notice. I normally don't balance my tires for racing unless it is a big event
these are mass produced cars. Although they do a pretty good job setting camber, and toe and such it is not a bad idea to if you are familiar with the truck already to break it down and check proper parts are thread locked and to adjust a few things to make sure the truck is setup right. Check ride height, camber, toe in, steering links, adjust the radio for steering throw, I would look over the truck for sure. Again they do a pretty good job assembling these things from my experience but they definitely don't have the attention to the small details an experienced racer would put into assembling a car which is why we get kits!
Some different options for you to help balance tires
https://www.amainhobbies.com/rc-whee...rs-trucks/c282
I have the losi tire balance stand and it works awesome ( you need this adapter https://www.amainhobbies.com/losi-sh...a99181/p185871). AKA hand held tool works pretty well also. I use poster putty you can get at a $0.99 store ore staples type place when I balance tires. There are many other options as well.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-01-2017, 10:46 AM   #9335
Thank you. Casper for the input. The thing is when I rotate the tires by hand i see the following. Is this tires out of balance? I am not sure?
https://youtu.be/u55L3ctyBbE
Old 02-01-2017, 11:10 AM   #9336
Casper's Avatar
Wheels are warped a little. Have taken them off and on yet? Make sure they are seated against the hexes flat. It happens. I can't tell if the tires are glued on just right as well. Looks like there could be a little bit of that as well. I understand your concern but don't see anything that would result in a warranty issue or cause a failure for the car.
Old 02-02-2017, 12:49 AM   #9337
Sorry Casper for asking silly questions but, is it ok if I set up Tierods and other stuff as per SCTE 2.0 build manual? Will it work on Troy Lee since it is not the same rig?
Cheers
Old 02-02-2017, 07:45 AM   #9338
Casper's Avatar
Yes the geometry of the Troy lee and the SCTE 2.0 are the same. Tie rods and other adjustments should all be the same.
Remember however the kit settings (for the 2.0 kit) are a starting point. If you change the setup you will need to adjust the rods. For steering links I make sure they are the same length and adjust them the same to achieve the toe I want. For camber links I put the rod ends on the same distance and just adjust until I achieve the camber I want (~ neg 2 deg) using a camber gauge. I would do the same with the Troy Lee RTR but if you want to measure the tie rod lengths the 2.0 lengths should get you there. The only thing I don't know is if the Troy Lee out of the box setup is the same as the SCTE 2.0 kit setup so if the camber links are in different locations things may be a little off but I believe they should be the same.
Old 03-12-2017, 09:22 AM   #9339
I'm building a couple of these scts with hw sct pro esc and SHORTCOURSE MOTORS/TENSHOCK 411&VIPER VST 5.5 motors they both stock kits with 40t spur what a good all round pinion size to start with
teo1213 is offline   Reply With Quote
Old 03-12-2017, 04:56 PM   #9340
Trader Rating: 65 (100%+)
14T-15T pinion covers most motor combos on 2S lipos.
Thunder Trail is offline   Reply With Quote
Old 03-12-2017, 08:51 PM   #9341
Sweet thanks they are mod 1 pitch correct?
Old 03-12-2017, 08:57 PM   #9342
What servos are good to use in these trucks not looking to spend a ton though for newbs! Thanks
Old 03-12-2017, 09:44 PM   #9343
Mirkinator's Avatar
Yep, mod 1. And im currently using a savox 1258. Been working great
Mirkinator is offline   Reply With Quote
Old 03-12-2017, 10:30 PM   #9344
Hitec 7955 is bulletproof. I would not run anything less. Good servos start at $80 and anything worth having cost that or more.
maddog9 likes this.
Old 03-13-2017, 10:10 AM   #9345
Sweet thanks
