Like Tree4Likes
Old 01-21-2017, 05:42 PM   #9316
Casper's Avatar
Trader Rating: 33 (100%+)
Not sure what all it takes to make the conversion but the platform has the parts to make the conversion. Agian if you want a SCT, SCB or MT, Losi has the RTR for you. All the RTR come with AVC as well which is great for bashing in loose conditions.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-22-2017, 11:44 PM   #9317
Josh L's Avatar
Originally Posted by ASA View Post
I have just ordered the new HW Exerun XR8 SCT 1/8 esc for my 2.0 and will match it to the new HW 4300kv 550 motor, people I have talked to rekon this combo is a great combo for most sct's especially the losi!
I am currently borrowing a mates Teken setup at the mo(RX8, pro 4 4300kv) and running a 15t pinion on a mid to open track med grip, would this gearing still suit the HW?
Aaron
If you plan to race you will want the 4300 in the 3652 540 1/10 motor.
Running the 3660 motor will make the truck have an over abundantly right side weight bias that will unbalance the chassis and force you to run more preload on the springs on the right side of the truck to keep things leveled out. Besides, it's completely unnecessary to run anything more than a 540 4 pole on the super light SCTE platform.
Also the new 3652 G2 motor has now been ROAR approved making your truck completely legal for such events.
And yes, a 15t pinion will be a perfect starting point with that motor.
Here is the ROAR info I speak of>
http://roarracing.org/4rmb/showthrea...ted-11-15-2016
Josh L is offline   Reply With Quote
Old 01-22-2017, 11:57 PM   #9318
ASA
ASA's Avatar
Thanks mate, I have ordered the esc but was planning to get the motor in a week or two......you just saved me 10 buks...haha
TLR 8ight 4.0
Werks B7 Kortz Edition
Werks Race Blend Fuel
Sanwa-Savox-ASA Grafix
ASA is offline   Reply With Quote
Old 01-23-2017, 04:25 AM   #9319
Josh L's Avatar
Glad I could help. But if you want to spend that $10 wisely I recommend you get one of these> Super Capacitors #4 Module
Having that on-board will triple the amount of caps you have and further knock out voltage ripple and smooth out burst loads keeping your ESC and battery cooler and more efficient, especially on 2s SCT's.
I have seen cases where adding these cap packs has reduced temps by as much as 18f deg. No joke. I put them on everything running 2S with great results.
Old 01-23-2017, 12:36 PM   #9320
EJ2civic's Avatar
Says you...
LOSI TEN SCTE*TLR SCTE 2.0*2017 XRAY XB4*HOBBYWING*PRO-MATCH RACING*SMC*Wild Turbo Fans*BACH Racing*MRH Racing*AbsoluteHobbyz
EJ2civic is offline   Reply With Quote
Old 01-23-2017, 02:48 PM   #9321
Josh L's Avatar
Originally Posted by EJ2civic View Post
Says you...
Not everyone runs 2 pole 550 cans my friend! So....
Old 01-23-2017, 03:43 PM   #9322
ASA
ASA's Avatar
I only have the #2 capacitor available to me where I am at the mo....it should make a difference on the xr8 sct esc?
TLR 8ight 4.0
Old 01-23-2017, 06:20 PM   #9323
Josh L's Avatar
Yes, the only reason I suggested the 4 cap set was because I over kill everything. The 2 cap set will give you very similar results in my experience.
Old 01-23-2017, 11:34 PM   #9324
ASA
ASA's Avatar
Sweet, cheers bud
TLR 8ight 4.0
Old 01-24-2017, 06:00 PM   #9325
Is the billet aluminum steering bell crank set up from integy a worthy upgrade?
Bad6as is offline   Reply With Quote
Old 01-24-2017, 06:04 PM   #9326
And this just plugs in to the receiver?
Sorry never heard of these.
Old 01-24-2017, 10:05 PM   #9327
Josh L's Avatar
No sir, these are soldered right to the battery post just like your battery terminals on the ESC side.
The caps that hook into your reciever are for preventing brown outs. Not really an issue outside of older spektrum stuff. You shouldn't have an issue with this with the newer hobbywing ESC's since they are capable of running 7.4v output through the BEC.
Here is a diagram so you can see what I mean
Note that this a castle cap pack and it has pole mounts instead of flexible wires like the hobbywing cap packs. but you still get the point seeing how it is soldered inline with the battery input terminals.
Old 01-25-2017, 09:26 AM   #9328
Trader Rating: 65 (100%+)
Looks good, but doesn't perform any better. Buy the 3.0 unit off ebay instead. Good upgrade over V-1 and 2.0 truck. Rod ends also worthy upgrade when yours slop out.
Thunder Trail is offline   Reply With Quote
Old 02-01-2017, 03:19 AM   #9329
Hi guys,
Just bought a SCTE 2.0 Troy Lee and as I opened the box and span the wheels 3 out of 4 was wobbly as hell. Checked the wheels and none of them were deformed or broken. Checked the cvds and they seems to be all right. What can be the problem? Should I take it back to the hobby store?
StinkyFoot is offline   Reply With Quote
Old 02-01-2017, 03:34 AM   #9330
maddog9's Avatar
Trader Rating: 29 (100%+)
Originally Posted by StinkyFoot View Post
Hi guys,
balance the wheels
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
