Like Tree4Likes
Old 07-19-2016, 07:58 AM   #9181
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by raved007 View Post
OK i run last weekends to my local track but not happy either my Tekno 410.3 better to drive than SCTE 2.0. Anyway I didn't change anything set up from the previous owner i will change diff oil, also shock oil very soft. Previous owner said the shock pistons is m2c delrin but seems to soft with shock oil. Any recommendations shock oil for m2c delrin piston?
I would try the kit setup and tweak from there. You never quite know what you are getting when you buy used. I recommend resetting and trying it from there.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is online now   Reply With Quote
Old 07-19-2016, 02:29 PM   #9182
dtr
dtr's Avatar
Time for a new thread for speculation?
http://www.liverc.com/news/special_features/12544-BREAKING%3A_Team_Losi_Racing_TEN-SCTE_3.0_photo_leaked/
dtr is offline   Reply With Quote
Old 07-20-2016, 06:54 PM   #9183
Josh L's Avatar
You should do what Casper is saying. It's true that you can't really chase behind another's setup or generally improve from its base very easily.
As for the shock pistons, anything outside of stock TLR pistons nearly and universally fail to pack in those 2.0 12mm shocks.
I tested a set custom made just for me from VRP and used a set as low as 2 hole 1.2 pistons and still had to run my weight upto 40-50 weight depending on springs just to get them to pack similar to standard SCTE #4 pistons.
The SCTE pistons where .5mm thicker than most after market pistons as well. This significantly helps with side wall flex and changes the port flow volume that must effect pack more than you'd think. I messed with this ordeal so much I eventually just said the heck with it and had to go back to #3-#4 , or #2-#3 stock pistons on stock blue front/orange back springs before things became normalized again. Your best best is to just get the 22 shock if you want to play with different pistons and or gain a consistent tune.
Pick up the whole shock spring tuning kit as well.
Josh L is offline   Reply With Quote
Old 07-20-2016, 08:36 PM   #9184
Got to play with my new to me 2.0 a little. Donkey kicked bad first time out with it. Brought it home and put it back to almost kit setup and took out all drag brake. It still kicks, but manageable with some throttle.
Turn in on this thing is horrible, though. I dropped to 5k front and center trying to free it up, but, still doesn't want to dive in like I'm accustomed to driving. If I use a lot of throttle and drift through, it's okay, but that's just not as consistent as I like. Maybe I just need more wheel time and fine tuning.
CharlieHo is offline   Reply With Quote
Old 07-20-2016, 09:43 PM   #9185
Casper's Avatar
What kind of track do you run on? Some updated setups from kit can be found at www.casper-rc.com
Old 07-21-2016, 12:45 AM   #9186
sylv456's Avatar
Default woop
It's on!
http://www.tlracing.com/Products/Default.aspx?ProdID=TLR03008
Any reason why servo arm is reversed now?
sylv456 is offline   Reply With Quote
Old 07-21-2016, 02:27 AM   #9187
The wait begins ??? when is it coming
coombes is offline   Reply With Quote
Old 07-21-2016, 02:37 AM   #9188
sylv456's Avatar
It says early Sep so I suppose kits will be in production soon if not done already.
Nicolas Evens
TLR 22SCT 3.0 - TLR TEN-SCTE 3.0 - TLR 22 4.0
http://www.facebook.com/NicolasEvensRCDriver
Belgian SCT Cup : http://www.facebook.com/BelgianSCTCup
Old 07-21-2016, 08:02 AM   #9189
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by sylv456 View Post
It's on!
http://www.tlracing.com/Products/Def...rodID=TLR03008
More clearance, most us have run this way on the 2.0 for a little while.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 07-21-2016, 11:11 AM   #9190
Interesting. Will this work with the parts we have now? Or do we need the 3.0 steering rack?
decyph is offline   Reply With Quote
Old 07-21-2016, 11:11 AM   #9191
Outdoor, tight, med grip. Lots of tight turns on this layout.
Bottom pic is of previous latout, but, gives a better idea of size.
Old 07-21-2016, 11:35 AM   #9192
Casper's Avatar
http://casper-rc.com/images/TEN_SCTE...02_reduced.pdf
I would recommend this setup. You can put these pistons and oil in the 2.0 shocks but would have to run SCTE springs.
Old 07-21-2016, 01:22 PM   #9193
TLRacing
Frank Root's Avatar
It's close now, to the servo saver arm hitting the servo/servo mount. We moved the servo mount back 2mm on the 3.0 chassis to be sure this isn't an issue.
Old 07-21-2016, 01:54 PM   #9194
Josh L's Avatar
You will notice how I grooved the arm toward the inner side that would contact the servo mount. I also trimmed a little off the servo mount as well to get 100% clearance. About 5 minutes of dremel or file work and turning over the servo and bell-crank arm is all it is.
Old 07-21-2016, 02:22 PM   #9195
Awesome, i think i'm gonna try it out. Have you noticed much difference in steering throw or anything?
