Like Tree4Likes
Old 05-27-2016, 07:48 PM   #9091
Trader Rating: 17 (100%+)
No
deceit, you have a pm
(2) Tekno ET 48.3 truggys,Tekin power
CaptCarnage is offline   Reply With Quote
Old 05-30-2016, 09:37 PM   #9092
Trader Rating: 65 (100%+)
Originally Posted by deceit View Post
That's the only site that I've found that has it, and it's $275. All the sites that say discontinued are a fraction of that.. :/ I want the upgrade, but $275 seems steep, since I can get a used 2.0 roller for under $200.
If you can find a 2.0 in good shape for under $200 buy it. That's a giveaway price. Buy that 2.0 or pass that deal off to me
Thunder Trail is offline   Reply With Quote
Old 05-31-2016, 08:21 AM   #9093
Just ordered up some stiffer springs to try and race this thing on asphalt. Had a blast running it last week, just has some wicked lean in the corners haha
-Mike B.
Carnage9270 is online now   Reply With Quote
Old 05-31-2016, 01:15 PM   #9094
Casper's Avatar
Trader Rating: 33 (100%+)
Thicker swaybars.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-31-2016, 02:29 PM   #9095
Originally Posted by Casper View Post
Thicker swaybars.
I actually ordered those too. Hoping they can make a difference...she's pretty boaty with stock springs and swaybars
-Mike B.
Old 05-31-2016, 02:42 PM   #9096
Casper's Avatar
She is setup for dirt racing stock!
thicker sway bars (you can get away with 8ight front swaybars to go even higher!) will help quite a bit, as well as stiffer springs and smaller hole pistons and thicker oil.
22 shock pistons work in the stock shocks FYI.
Old 05-31-2016, 02:46 PM   #9097
Hmmm I didn't even think about the 22 pistons. Thank you!
-Mike B.
Old 06-01-2016, 10:44 AM   #9098
Casper's Avatar
Yes you can use blanks to custom make pistons as well.
Old 06-03-2016, 06:10 AM   #9099
Hello all,
This is my first post on here and I am over whelmed with the amount of info available. I have been flying Heli's and multirotors since 2004. I raced an RC10T in high school and a Tamiya mini cooper in 2006.
I just ordered the SCTE 2.0 kit. I'll be using a DX3R w/ SR3100 rx, a Savox 1210SG for steering, the Castle SCT Race Pro 3800kv combo w 13t pinion, and Lectron Pro 2s 5200 50C batteries.
Near as I can tell, this should be a solid set up. Any tips or trick for the build or set-up advice would be greatly appreciated. Thanks in advance.
Lou
TK421 is offline   Reply With Quote
Old 06-03-2016, 07:56 AM   #9100
Originally Posted by TK421 View Post
Hello all,
Lou
Great starting point. As for the kit, I recommend the stock setup to get started. Check out the setup sheets on TLR page when you want to try something different. In the near future buy some higher mah lipos. 7200-8000mah in highest C rating you can afford. lipos 70c to 100c have become the norm for higher power systems, but 50c works fine for the castle setup.
Might start out with Xray diff washers right now to extend diff service. Google "bulletproff SCTE diffs" for more info.
Ball bearing ackerman plate is a nice upgrade. http://visionracing.net/
Once you got your rig turning fast laps and need more steering consider the TLR aluminum front carriers.
Have fun with it!
Old 06-03-2016, 02:33 PM   #9101
Thank you sir! I like the Ackerman plate, what is the difference from the long to the short? How do they compare in size to the factory length? I will for sure be looking into the diffs, thank you again!
Lou
Old 06-03-2016, 03:20 PM   #9102
Phelps's Avatar
Hi TK421, our ball bearing ackerman plates are the same dimensions as the factory ones. We also have hardened diff washers you might try.
Jeff
Vision Racing, Lunsford Racing, Sick Graphics, 541 RC.
www.visionracing.net
Phelps is offline   Reply With Quote
Old 06-03-2016, 03:29 PM   #9103
Jeff
Send me q link to both items and I'll order them tonight. Thank you!
Lou
Old 06-03-2016, 03:52 PM   #9104
67GTA's Avatar
Hello all,
Lou
Pick up 2 packs of HPI Z449 screws and use them in place of the stock diff screws, which have a tendency to strip. They come in packs of 10 and you'll need 12.
Also, when you're putting the 2 chassis braces together, screw the threaded rod all the way into the plastic ends first (until it bottoms out) and then screw them into the aluminum pieces 2nd. Keeps the plastic ends from breaking. Other than that, the build is pretty straightforward and the truck is bulletproof.
67GTA is offline   Reply With Quote
Old 06-03-2016, 06:41 PM   #9105
Phelps's Avatar
Here you go TK421
http://visionracing.net/product/team...ag-link-combo/
http://visionracing.net/product/2mm-...ar-diff-shims/
