Like Tree4Likes
Old 03-20-2016, 12:53 PM   #9001
lowspark's Avatar
Round ones...
.... sorry couldn't resist
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 03-20-2016, 02:46 PM   #9002
dtr
dtr's Avatar
Originally Posted by fordohio View Post
What tires/compounds are you guys running on outdoor loose tracks.
Cityblocks or calibers. You could try gladiators or badlands as well if it is really loose.
dtr is offline   Reply With Quote
Old 03-20-2016, 02:51 PM   #9003
Casper's Avatar
Trader Rating: 33 (100%+)
Depends on how loose the track is. Could be M3/M4 holeshots to a S/SS Panther Raptor or M3/M4 blockade.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-20-2016, 07:30 PM   #9004
Trader Rating: 15 (100%+)
I've been holding off from buying a bunch of "upgrades" for a while, I hope there is a new scte coming soon. I really like the 4wd sct class.
Tommygun1 is offline   Reply With Quote
Old 03-22-2016, 07:26 AM   #9005
My go-to tire for SC 4X4 outdoors is AKA Enduro or City Block. If the track is in good shape and moist I'll go to Proline Sniper or Gridirons (the first version, not the Gridiron-II which is way different and much smaller pins).
In SC 2WD I can get away with super-soft/ M4 but in 4x4 I stay in the Soft/ M3 compound instead of super-soft/ M4 to save a bit of $$ (better tire life).
stelio279 is offline   Reply With Quote
Old 03-22-2016, 09:43 AM   #9006
Casper's Avatar
Originally Posted by rc_noob3 View Post
what run times do you see ? i know it varrys alot but im new to this , from what i heard is the 4700hw is harsh on batteries
Easy 10 min. Never really run a race much longer that that.
After a typical 5 min race and warm up I typically dump 3000-3500 out of the battery in that time. For reference a 2wd car for same races in mod are only about 1800mah so yes these rigs are hard on batteries so having something up to the task is important. Venom batteries have been amazing for me in taking this abuse.
Old 03-22-2016, 10:49 AM   #9007
67GTA's Avatar
Hey Casper, what chassis is used on the latest Dunford setup on your site? If it's the -3mm, any changes that you would recommend for a standard chassis running the 22 shocks?
67GTA is offline   Reply With Quote
Old 03-22-2016, 11:17 AM   #9008
Casper's Avatar
We have been running the -3 chassis for quite a while. We do like the STD chassis on extreme high bite or possibly a larger 8th scale style track but it is a tuning option.
Nothing I would really change to compensate for one over the other. The -3 rotates better on a typical 10th scale track with better exit corner traction however the longer chassis does allow the car to flow a little better on an open layout. I basically run the -3 everywhere though. I don't run on large 8th scale tracks but once a year maybe and for high bite stuff I just lower the truck take out some droop and stiffen up the shocks.
Old 03-22-2016, 07:17 PM   #9009
67GTA's Avatar
Most setups I've seen, including the one I'm running, have the rear hubs all the way back. Wouldn't a standard chassis with the rear hubs moved forward 3mm rotate similar to the shorter chassis?
Old 03-23-2016, 07:43 AM   #9010
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
No, you'd be changing the rear bone angle by a LOT.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 03-23-2016, 08:10 AM   #9011
Casper's Avatar
You are also moving the entire rear clip forward 3mm an not just changing the wheel base. The polar moment of inertia is smaller with a shorter chassis.
Old 03-23-2016, 09:20 AM   #9012
67GTA's Avatar
Just for my understanding, what effect does bone angle have on handling? I've never seen it referenced in tuning guides, only the wheelbase adjustment. Thanks for your help Frank & Casper - much appreciated.
Old 03-23-2016, 09:55 AM   #9013
TLRacing
Frank Root's Avatar
There is friction created in a CV joint, and also friction created at the bone/outdrive joints. Both frictional forces increase the further the bone is from being perfectly straight. If other words, when you accelerate, the bone wants to pull itself straight, and applies force to the suspension in an attempt to do so. More bone angle by moving the hubs forward = more force.
With the drive shaft straighter (hubs back), it reduces the lock-up force of the driveshaft and allows weight to transfer to the rear more easily under acceleration.
Old 03-23-2016, 07:54 PM   #9014
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
What ESC's and Motors is everyone running?
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 03-24-2016, 06:23 AM   #9015
Integra's Avatar
MN series ?
Tekin FTW!!!!!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
