Like Tree4Likes
Old 11-02-2015, 10:22 PM   #8746
Josh L's Avatar
Originally Posted by Casper View Post
I may have read those rates from my list of measured springs. We got hold of a spring rate tester and measured a bunch of springs. Rates will vary slightly batch to batch.
TEN Rear Spring Rates
2.7 Red
3.0 Orange
3.3 Silver
3.6 Green
TEN Front Spring Rates
3.6 Green
3.9 Blue
4.2 Black
4.5 Purple
Not too far off advertised rates.
So with this new setup I am supposed to run 22 springs?...
In the post you listed before, posted above (Ten Springs).
So I assumed I still needed to purchase those and bought both sets.
Are these not the right ones now? I really don't get this spring deal. What fits what exactly. The setup sheets shows a 22 t front and a 22 (buggy I assume) rear? How many spring sets do I need exactly to use the new shocks as they are intended?
Josh L is offline   Reply With Quote
Old 11-03-2015, 07:19 AM   #8747
Casper's Avatar
Trader Rating: 33 (100%+)
SCTE stock shocks are larger OD so you need special springs for those shocks. You can either run the original stock SCTE springs or run the racing spring set as I posed above.
If upgrade to the 22 shocks for the SCTE you open the door to a whole library of springs as the shock body OD is not a more standard size. You can use any of the 22 series springs as well springs from Avid, Durango, AE, Kyosho and many others who have "big bore" 12mm shock springs. However your SCTE specific springs will not longer work as they the diameter is too large to fit on the spring purches.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-08-2015, 08:45 AM   #8748
Pertaining to the SCTE, could someone give me an opinion on JC Barcode Gold vs PL Suburb MC?
MC is described as 'firm'. I really don't want to go much firmer than Gold.
I like my Gold Barcodes. Want to try the Suburbs, but never had any tires in the MC compound; don't know what they feel like. I have run Suburbs in other compounds, and like them.
gagagugu is offline   Reply With Quote
Old 11-08-2015, 02:28 PM   #8749
Every clay track around here gold barcodes or dirt webs worked better for me than MC suburbs. But tires are very track dependent so I would ask some local racers or bite the bullet and buy some. Just remember clay tires usually need to be broken in before they work their best.
I also tried silver dirt webs which are super soft clay but they were slower than gold so sometimes softer isn't better.
Homer723 is offline   Reply With Quote
Old 11-09-2015, 11:36 AM   #8750
Default ride hieght, 22 shocks.
I'm having trouble getting a ride height of 25mm with the new 22 shocks.
running the stock setup for them, hole positions 2-outside for front and 2, middle for rear(gonna try 2-inside for rear).
the shock collars are all the way down on the rear and I'm getting a ride height of 21mm. anyone else have this problem.
Jason Chafe
Skycraft Hobbies
jay_959 is offline   Reply With Quote
Old 11-09-2015, 11:53 AM   #8751
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Jason Chafe
Skycraft Hobbies
Are you not able to get the correct ride height front or rear?
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 11-09-2015, 12:06 PM   #8752
Nope, I could probably get the front close to 25mm but not really a point when my rear wont go any higher then 21mm. putting my rear shock tower to 2-inside instead of 2-middle might help a little but don't think t will give me the 4mm I need. running stock spring sent in 22 shock package.
-3 chassis, 5.11lbs, body off.
Old 11-09-2015, 12:35 PM   #8753
TLRacing
Frank Root's Avatar
Did you put the rear tower on that came in the kit? My car gets to 25mm ride height easily, they is something assembled improperly here.
Old 11-09-2015, 01:14 PM   #8754
yes I did install it. and its shorter then the original by quit a bit.
I will go over anything again tonight just to make sure I didn't do anything wrong. you run the rear at shocks at 2-inside?
Old 11-09-2015, 01:27 PM   #8755
TLRacing
Frank Root's Avatar
Yes sir, I do
Old 11-09-2015, 08:05 PM   #8756
Fader12's Avatar
I was going to ask the question and this could be your ride height problem. The kit comes with two different spring cups. One is taller so does that go on the front? Frank, Casper ????
Fader12 is offline   Reply With Quote
Old 11-10-2015, 05:46 AM   #8757
well that's one thing I did overlook ... dammit lol. at work now, I will take a look at lunch.
Old 11-10-2015, 09:48 AM   #8758
Casper's Avatar
Yes the tall spring cups would go on the front springs as shown in the photo for the kit on the TLR site.
http://www.tlracing.com/Products/Def...odID=TLR334029
Old 11-14-2015, 07:27 AM   #8759
Jack Bonhomme's Avatar
I've been running the stock long Ackermann steering rack bar on my SCTE since day 1. I'm about to switch to the short bar. What changes in steering performance /turn radius can I expect to gain or lose?
YouTube Page: JackBonhommeVideos
Sponsors: FTM Grip, Redline Hobbies, Garcia Graphix
Tracks:Barnstormers, 46RC, R/C Madness
Jack Bonhomme is offline   Reply With Quote
Old 11-14-2015, 09:25 AM   #8760
rcgod's Avatar
Trader Rating: 27 (100%+)
The steering will be more agressive especially off center. It may be too much but you can add some expo on the radio to calm it down.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
