Like Tree4Likes
Old 08-18-2015, 10:49 AM   #8596
Originally Posted by maddog9 View Post
I was skeptical at first as well. I ran a tenshock 4600 both sensored and non-sensored. Didn't really see a difference unless you were at a dead stop. It was way too torquey and i would get wheel spin big time even on high bite tracks. With the two pole i can just squeeze the throttle right out of the corner and not worry about wheel spin. I have had no issue indoors or outdoors clearing any jumps. Just like a 4 pole just way smoother. I would not suggest the 4300 as it is way too much motor for this truck. My buddy had one and sold it after a couple weeks even had it turned down to 35 percent in the esc.
http://www.teamorion.com/images/prod...etup_phend.pdf
That is pretty close to what i am running settings wise. I have more brake added. I have an associated heat sink on the motor and after 8-10 minutes comes off at 140 degrees.
Whelp you answered my question in a good way, i use every bit of my pro4 4600. Sounds like the pro4 hd 4300 is what i'm looking for.
Apexracing is offline   Reply With Quote
Old 08-18-2015, 05:52 PM   #8597
motoj550's Avatar
Trader Rating: 21 (100%+)
Well i went for the Hobbywing sct pro combo with the 4000kv motor, but i said hell with it could not resist the urge, had to find out for myself i ordered the SMC 4500 too, i can always use it on bigger outdoor tracks. plus i needed to order a couple more batteries anyways so it was a good excuse to order it.
XR10 A Higher Plane Of Existence
motoj550 is offline   Reply With Quote
Old 08-18-2015, 09:43 PM   #8598
Thats a great esc thats for sure. The 4000 might be a little underpowered on a outdoor track. But that 4500 should go pretty good. These things can handle gobs of power. If your having trouble putting it down then look into different tires or altering your setup. My truck gets around the track better then most 1/8 buggies at our local track.
Old 08-18-2015, 11:19 PM   #8599
hey guy what pinion would you used for the track star 2 pole 550 5100kv motor on a large out door track
coombes is offline   Reply With Quote
Old 08-18-2015, 11:26 PM   #8600
rcgod's Avatar
Trader Rating: 27 (100%+)
I've ran that motor with a 13t pinion on a small to med indoor track and it was good. You could probably do a 14t no problem. That's with no timing in the esc. If you want to run timing then a 12 or 13 would be a good place to start. The 2 pole motors respond better to timing than 4 poles in my experience. And they're much easier on batteries.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 08-18-2015, 11:41 PM   #8601
ive got a 14 pinion I wack on that instead
thanks mate
Old 08-19-2015, 10:37 AM   #8602
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Hi Guys - A few weeks ago I started a new group on FB for the SCTE and SCTE 2.0. It is called SCTE Territory. Check it out when you have a chance, and ask to be added.
https://www.facebook.com/groups/1620275444897495/
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-20-2015, 01:11 AM   #8603
Josh L's Avatar
You should be happy with that set. I don't know anything about the SMC motors, but I sure love my HW XERUN 4700.
Contrary to what people will tell you, the HW motors like taller gearing than what a lot of people tend to run. I have seen and read about people running upto 18T pinions and still maintaining cool temps. Some argue that it's due to not peaking out the RPMs for extended periods of time on long straits, but you do have to be more conscience of to much top end on real loose tracks. Lower gears are better for technical tracks with short jump entries after turns, but do experiment.
Sweet! I joined. What is your game plan with the new page? Are you planning on doing some personal write ups, setups, etc?
Josh L is offline   Reply With Quote
Old 08-20-2015, 08:12 AM   #8604
Bwadd2002's Avatar
Trader Rating: 8 (90%+)
Send a message via Yahoo to Bwadd2002
Awesome.. Joined!
Bwadd2002 is offline   Reply With Quote
Old 08-20-2015, 08:51 AM   #8605
TLRacing
Frank Root's Avatar
Originally Posted by Bwadd2002 View Post
Awesome.. Joined!
Old 08-20-2015, 11:52 PM   #8606
Josh L's Avatar
Expo and initial acceleration setting go a long way in taming this out.
However I don't understand why more radio companies don't introduce addressable curve points like you find in air radios.
I for one would love it if my radio could have a multi-point curve ability.
That would make it possible to have S curve with an initial negative to a positive line.
The level of dial-in would be very buttery and have impeccable feel
Like this>
Old 08-21-2015, 04:14 AM   #8607
maddog9's Avatar
Trader Rating: 29 (100%+)
Like this>
Yep I run expo for my ebuggy so I know all about it. I like to be smooth and consistent. Also, I figure if someone like Dakotah Phend is dominating with a 2 pole there must be some merit to it, mind you a pro could drive anything. A couple local TLR guys are the ones who introduced me to the two poles after they started dominating. One even TQed over Matt Olson at the CRCRC Midwest Race. One thing I will say it did not work well with an RX8, you need a 1/10 scale esc hence the reason for the orion R10 Pro.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 08-21-2015, 07:10 AM   #8608
xxfile's Avatar
Default servo...
Welll after two years the Savox 1258 packed it in the other day. this servo has been great but it is out of stock currently at my supplier.
any other recommendations for a good servo. i dont want anything chinese just good name brand stuff i dont mind paying for quality.
xxfile is offline   Reply With Quote
Old 08-21-2015, 07:31 AM   #8609
Casper's Avatar
Trader Rating: 33 (100%+)
Like this>
Tekin ESC with Hotwire and you can make that curve
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-21-2015, 09:11 AM   #8610
maddog9's Avatar
Hitec 7955
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
