Like Tree4Likes
Old 07-06-2015, 11:36 AM   #8431
Braxamus's Avatar
I'm not I am running the factory chassis, and I really like it so far only thing I wish I could improve is the damn driver.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 07-06-2015, 01:24 PM   #8432
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I know Ryan and Casper are. I am not 100% sure if Dakotah has before, but he will be for the Electric Nats this week. I do know that JR is running it.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 07-06-2015, 05:56 PM   #8433
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
I'd like to know as I am running a tight layout with switchbacks and need to turn and burn!
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 07-07-2015, 06:43 AM   #8434
TLRacing
Frank Root's Avatar
I just said that that 3 of 4 are running it...
And those 3 are the ones that really tune and dial in setups...Dakotah is a straight wheel and usually runs close to what Ryan runs since he doesn't race 4wd SC all the time...
Old 07-07-2015, 08:41 AM   #8435
JEFFs SC10's Avatar
Oh my bad I though they werent. Im a little slow Frank haha
XRAY 2017 T4
Xray X12-17' GT12
Old 07-07-2015, 10:47 AM   #8436
Originally Posted by Dirtraycer View Post
I've been running the Dunford OCRC setup on my truck except the 15 deg front spindles and the +5mm rear hex's and my diff oil is 5-7-5. And maybe I'm just not driving it fast enough but it just feels kinda tight in the turns if I went back to the lighter front sway bar and changed my front diff oil to 7k do you think that would "loosen" my truck up some ?? I don't get to race that often and race on a tight budget so I don't always have the money to run out and buy all the new parts and only have a set of Deja-Vu's and a set of Typos both in clay compound. any advice would be appreciated thanks in advance
Cory
Cory,
The two things you listed off are directly responsible for more steering as an FYI. The 15 degree carriers change the height of the spindle and thus the bone angle resulting in more on power steering while the carriers themselves have more overall steering through resulting in more steering everywhere. Also, the +.5mm rear hexes allow more overall truck stability but will make the rear a tinge looser on throttle typically.
the other thing I would be sure to always do with this truck is to set your steering end points with the tires on the ground. A lot set end points with the tires in the air but with bump steer and other things going on, you really want to do it with the truck on the ground. You might find you can get more throw.
Also, make sure your servo saver is tight and threadlocked as well. If your servo saver backs off or is loose, it can give you less steering.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 07-07-2015, 12:11 PM   #8437
Braxamus's Avatar
Ryan should the servo saver be locked down as tight as possible, what is a good rule of thumb on this? Also I have seen on here where some guys will grind some off the center drag link for clearance to get full throw on the steering, mine is all stock as far as suspension parts sway bars and such, I am runnin shock positions and springs like others at our track. I know I have 3k in center diff. but not sure whats in others as I got it used and never had them apart they seem smooth and no noise so I never worried about it.
Team Raw Speed
Old 07-07-2015, 12:22 PM   #8438
thanks for the reply ryan and Frank it's much appreciated.
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 07-08-2015, 07:58 AM   #8439
For me, I typically tighten mine down as far as I can get it and then back it off a half of a turn. Of course this is with putting threadlock in place as well.
-Ryan Dunford
Old 07-09-2015, 01:55 AM   #8440
Braxamus's Avatar
I have never had mine apart thanks
Team Raw Speed
Old 07-09-2015, 08:57 AM   #8441
mxking1712's Avatar
hey fellas, I tried doing some research last night but ill ask just to make sure. I ordered a new kit that should be here tomorrow with a rx8 gen 2 and a pro 4 HD 4300kv motor. Im planning on running 2S and am curious what gearing to start with. From what I gather 15T pinion would be a good start and a guaranteed no heat issue? One track we run on is very open and more of a 1/8 scale track and the other is a very tight 1/10 track. I know I will most likely have to gear different for each. Which do you recommend I start with? thanks alot
mxking1712 is offline   Reply With Quote
Old 07-09-2015, 09:33 AM   #8442
rcgod's Avatar
Trader Rating: 27 (100%+)
15 to 17 is where I gear my 4300 depending on track size. 14 works for tight tracks but doesn't give a lot of wheel speed to correct the truck if it noses down on a jump.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 07-09-2015, 06:00 PM   #8443
lowspark's Avatar
MX-king, i run 15/39 on an 1/8 scale track and the truck runs strong... 4300 is a beast, and it has very smooth braking.
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 07-09-2015, 06:15 PM   #8444
JEFFs SC10's Avatar
How are you guys doing against the Tekno's? They seem to be taking over.
XRAY 2017 T4
Xray X12-17' GT12
Old 07-09-2015, 07:08 PM   #8445
TLRacing
Frank Root's Avatar
Not when I am at the track
