Like Tree4Likes
Old 07-01-2015, 02:06 PM   #8416
rcgod's Avatar
Trader Rating: 27 (100%+)
Make sure the inner bearing is seated on the pinion shaft. Mine was a little hard to seat all the way and the gears were too tight.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 07-01-2015, 03:03 PM   #8417
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Pstuebs View Post
Yes its all brand new. Brand new kit going together, just received it a week ago. I have checked and rechecked assembly procedures and its as instructed. The pinion seems to have very little run out or horizontal play, maybe on half mm. When assembled it just seems as if you can feel the pinion and ring gear step on each tooth. Maybe this is normal Im just not sure. No shims were installed other than exactly what the instructions say. I used grease to check for whitness marks in the case and found just one tiny area which I dremeled away.
The latest gears have worked pretty good but I would run them in and check it again. May just be some high spots that will break in quickly as you run in the gears.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-01-2015, 03:47 PM   #8418
Josh L's Avatar
Had the same issue with the rear diff catching. But after a run or two it went away and I haven't had any issues
Josh L is offline   Reply With Quote
Old 07-01-2015, 03:59 PM   #8419
I bet this is the issue. Mine did the same thing. Take something and tap the inner bearing further into the case. Should fix it.
Austin's dad is offline   Reply With Quote
Old 07-03-2015, 11:22 AM   #8420
Originally Posted by chihengxuan View Post
Does anyone know is it worth to upgrade SCTE 1.0 MIP version to SCTE 2.0? thx
I would say yes. My brother had the MIP 1.0 truck and switched to the 2.0 and likes it a lot better.
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 07-03-2015, 11:50 AM   #8421
Josh L's Avatar
Why not just keep the MIP truck and buy a new 2.0? The advantage of one over the other will be finding your ideal tune with each. Unless your a pro I doubt you'll find a significant flaw in either.
Old 07-03-2015, 02:12 PM   #8422
Could you explain it more specific? thx!
there is just more adjustability with the 2.0 camber link and shock position. and I believe battery position. He was just able to drive it harder and got faster and more laps with it.
TLR 22T 2.0
Old 07-05-2015, 02:40 PM   #8423
I've been running the Dunford OCRC setup on my truck except the 15 deg front spindles and the +5mm rear hex's and my diff oil is 5-7-5. And maybe I'm just not driving it fast enough but it just feels kinda tight in the turns if I went back to the lighter front sway bar and changed my front diff oil to 7k do you think that would "loosen" my truck up some ?? I don't get to race that often and race on a tight budget so I don't always have the money to run out and buy all the new parts and only have a set of Deja-Vu's and a set of Typos both in clay compound. any advice would be appreciated thanks in advance
Cory
TLR 22T 2.0
Old 07-05-2015, 06:49 PM   #8424
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
do you mean turn in?
I ran on a new fresh track that was low to absolute slick surface. I had to change the shock positions to near vertical and remove both sway bars to gain grip.
never had to do that before, but I could not get the truck to turn.
there are some hairpin 180's that have jumps so I need the acceleration as well.
Lost my front sway bar this weekend LOL.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 07-05-2015, 07:04 PM   #8425
I guess turning period lol seems like the other scte's that I run with has a tighter turning radius and rotate better thru the corners than my truck does.
TLR 22T 2.0
Old 07-06-2015, 04:18 AM   #8426
First thing I would suggest is talk to the guys that have the scte's that turn better than yours and see what they're doing different.
All the stuff I'm about to list is for an off throttle/low speed situation, if you're looking on throttle steering this stuff will be counter productive to backwards.
If you're looking for more rotation out of the rear you can try lighter rear diff fluid or soften the rear suspension (tip shocks in, softer springs, stuff like that), shortening the rear wheelbase will also add rotation.
If you're looking for more steering out of the front a lighter front sway bar (or no sway bar) will help, also softer front spring or more tipped in front shocks, shorter front camberlink.
Edit: Also make sure you're getting full steering throw https://www.youtube.com/watch?v=8mw4rkTeWbQ
anr211 is offline   Reply With Quote
Old 07-06-2015, 08:54 AM   #8427
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Cory
If you want more turn-in and rotation, then I'd go with a thinner front bar and maybe thinner oil front and rear. I run 5-5-3 usually at OCRC. Ryan's truck is easier to drive, and mine is a little more aggressive.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 07-06-2015, 10:26 AM   #8428
Thanks for the info. im going to make the adjustments and see what I get lol
TLR 22T 2.0
Old 07-06-2015, 10:59 AM   #8429
Braxamus's Avatar
I am going to wait to see what his truck does before I change mine...LOL let lil brother be the tester..........
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 07-06-2015, 11:16 AM   #8430
Are the setups you TLR guys are using today including the new -3mm chassis?
Bserious is offline   Reply With Quote
