Like Tree4Likes
Old 06-26-2015, 09:12 PM   #8401
Originally Posted by Pstuebs View Post
Just received my Ten SCTE 2.0 kit. Opened the box to find the shock oil tube had broken an covered every inch of every component in oil. The body has oil under the protective cover and I cant get it to stop wicking oil at the edges. The decal sheets and other documents are hammered. Anyone ever seen this issue? Best course of action?
I would say contact Horizon about it. every kit I have built the oil was in a sealed bag. maybe TLR has changed this.
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 06-27-2015, 12:09 AM   #8402
Josh L's Avatar
Originally Posted by Whomper View Post
How is the SCTE 2.0... compared to a Slash 4x4 Platinum?
I guess I'll be the bad guy here.
Traxxas is plenty fast in speed. That is about it when it comes to actual racing.
I used to run the RC side of a hobby shop years back, around the time the nitro monster trucks was in full bloom. I always tried pushing the reliable HPI savage line, but the owner loved traxxas sales cause it always meant return customer with broken parts.
I know that is a bit harsh and distasteful in respect to a fellow RC company, and maybe they are getting better, but it's my honest experience and the reality.
Most in the know will probably agree with me on these statements, albeit silently.
If you plan on bashing and looking cool, Traxxas is great for that and everyone carries their stuff.
But honestly... If you want to race, your going to go with something else where the R&D is based completely on just that, such as Losi, Associated, or Tekno.
I personally have always loved my Losi's, and the SCTE 2.0 is easily a top contender in it's arena, as are all TLR chassis per class.
So to make a long answer short.
Do yourself a favor and go with the Losi if you plan to race with any seriousness.
Josh L is offline   Reply With Quote
Old 06-27-2015, 10:46 PM   #8403
Trader Rating: 15 (100%+)
You should really call Horizon customer service. They want you to be happy with your purchase. They would probably send you another body with decal sheet. Other stuff should be able to be cleaned up I would think. Personally, I would just clean the body (remove affected protective covering, then clean with dish soap?) to make it paint-able but that's just me.
Tommygun1 is offline   Reply With Quote
Old 06-28-2015, 11:52 AM   #8404
Casper's Avatar
Trader Rating: 33 (100%+)
Contact Horizon CS and let them know what happened.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-28-2015, 07:36 PM   #8405
BMOC's Avatar
ended up getting this kit and putting in a tekin rx8/ pro4 4600kv that i bought used from a guy on facebook. and tq'd and won my first club race with it today. thing drives awesome, stupid fast. wheels rub a little bit on the front lower control arm when turning with a less offset wheel. had to adjust EPA down a bit. told everyone i was running bypass shocks because it kept clicking in the corners lol
BMOC is offline   Reply With Quote
Old 06-28-2015, 09:15 PM   #8406
Does TLR (or anyone else) sell x-rings that will work well in these shocks? Just looking for a cheaper way to get x-rings than the 2 that come in the rebuild kit for $7.49
Old 06-29-2015, 07:38 AM   #8407
Casper's Avatar
The o-rings in the SCTE shocks are xrings. They are kind of expensive as you have to get it in the rebuild kit but by the time the x-rings wear out a complete shock rebuild is probably in order anyway.
Old 06-29-2015, 07:59 AM   #8408
rcus3r's Avatar
I am a big fan of MIP stuff. Everything from that delicious smelling sticky tape, to drive shafts for my basher.
While back got me them MIP chassis braces. They're great.
Latest addition has been the MIP center drive system. Besides being some 20g lighter than my previous mix of Losi and Tekno drive line, and spinning perfectly true, this thing is a work of art. Well engineered.
8 battery packs into it on fast, high bite track, so far no sign of any wear or any issues. Time will tell how well they hold up, but for now, I am impressed.
Anyways, thought I'd share...
rcus3r is offline   Reply With Quote
Old 06-29-2015, 12:40 PM   #8409
Definitely contact HH customer service. Use the callback function. They will get you all taken care of.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 06-30-2015, 06:00 PM   #8410
Does TLR have any plan to make plastic versions of the 15 degree front spindle carrier?
Bserious is offline   Reply With Quote
Old 06-30-2015, 09:28 PM   #8411
To follow up, I contacted Losi and all affected parts are being replaced free of charge. Also, after my original post i found a tube of gear oil had also failed in its package. Not a big deal but something they need to address.
Pstuebs is offline   Reply With Quote
Old 06-30-2015, 09:38 PM   #8412
Default Rear diff
I am having a problem with my rear diff. With the diff assembly in the housing half the unit spins freely. however when you turn the diff with the pinion gear there is a rough almost stepped feel. I have relieved a few areas of the case that were possibly running the ring gear but this has not helped. Any and all idea would be appreciated.
Old 07-01-2015, 07:53 AM   #8413
Casper's Avatar
The rear diff normally does not have any issues related to the case.
Are you shimming the diff? Is this a new ring and pinion? Check the bearings that support the pinion.
Old 07-01-2015, 08:42 AM   #8414
There is nothing in the near future if at all planned.
-Ryan Dunford
Old 07-01-2015, 01:22 PM   #8415
Yes its all brand new. Brand new kit going together, just received it a week ago. I have checked and rechecked assembly procedures and its as instructed. The pinion seems to have very little run out or horizontal play, maybe on half mm. When assembled it just seems as if you can feel the pinion and ring gear step on each tooth. Maybe this is normal Im just not sure. No shims were installed other than exactly what the instructions say. I used grease to check for whitness marks in the case and found just one tiny area which I dremeled away.
