Like Tree4Likes
Old 05-26-2015, 06:23 PM   #8296
Fader12's Avatar
Originally Posted by DoogieLee View Post
Thinking about racing ROAR regionals this year... I don't follow the rules that closely but as I understand it, 4 pole motors are NOT legal, correct?
If thats the case, what are my choices in the 550 can/ 2 pole market?
Using a Hobbywing SCT ESC as well.
Thanks in advance
I think what's banned are 550 4-pole motors. A 540 4-pole should be ok. I have run a Schuur Speed 540 in my SCTE 2.0 and have done very well with it.
Indoors it seemed to have no issues and had the added addition of being 55 grams lighter than a Tekin 4300kv HD motor.
When I went outdoors and had to run triple A-Main's it got too hot. I guess I could have run a fan but, didn't want to have the extra issues with that. And with it being light, if wind picked up I saw issue's with parachuting.
Fader12 is offline   Reply With Quote
Old 05-26-2015, 08:46 PM   #8297
rcgod's Avatar
Trader Rating: 27 (100%+)
http://www.roarracing.com/approvals/print_brushlessmotors.php
2 pole 550 and 4 pole 540 are approved. Check the list before you buy a motor to be roar legal.
rcgod is offline   Reply With Quote
Old 05-26-2015, 11:35 PM   #8298
what is every one running on there rx8 esc setting wiseo n a low traction track I am running a tekin rx8 and a hobbywing 4000kv
coombes is offline   Reply With Quote
Old 05-27-2015, 11:32 AM   #8299
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Can I get the orings for.the diffs separately? Anyone know the size? Can I get an.equivalent at a home depot or something? Lol
JEFFs SC10 is offline   Reply With Quote
Old 05-27-2015, 12:14 PM   #8300
Trader Rating: 65 (100%+)
The only way to get the stock seals would be to buy a new HD diff case or what I call spider or crown gear set. I'm sure others have found something that will work from McMaster Carr or other RC rigs. Maybe they will chime in.
With plenty of grease and the XRAY washers, my seals have lasted nearly long enough to need a new HD Diff case. It would be nice if they offered the diff and shock o-rings separately for those of us that rebuild and or take our trucks apart often.
Many have ask for the o-rings for diffs and shocks. The common answer we get is... They last long enough, so just buy the parts kit that contains the o-rings and be happy. That's a weak answer for those asking. If you find the diff seals that work, please share them here.
Thunder Trail is offline   Reply With Quote
Old 05-27-2015, 12:19 PM   #8301
JEFFs SC10's Avatar
Thanks Thunder.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
Old 05-27-2015, 12:41 PM   #8302
Casper's Avatar
Trader Rating: 33 (100%+)
With a few different parts sets but not separate.
http://losi.com/Products/Features.aspx?ProdId=LOSB3568
Is the lease expensive option.
They do not come with the gears. They do come as part of the std outdrives (not HD) and they come with the HD diff cases.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-28-2015, 04:50 AM   #8303
I've had really good luck with these orings in my diffs http://www.amain.com/rc-cars/protek-...ptk-1001/p2670
anr211 is offline   Reply With Quote
Old 05-28-2015, 09:48 AM   #8304
JEFFs SC10's Avatar
Thank you ANR you are the man!! Ordering now.
XRAY 2017 T4
Xray X12-17' GT12
Old 05-28-2015, 06:52 PM   #8305
JEFFs SC10's Avatar
Quick question,
drover truck on the track today, running great again. (still need those orings)
There's a real tight S section that I'd like to get more speed going thru. What helped turn in is moving the hubs forward. I couldn't test anything else. My battery is in the back position but I'm going to try center but I dont want the rear to step out.
I'm running Dunford setup with black front springs and silver rears with 30 wt oil all around.
I think if I decrease body roll I'll get thru that section a little quicker. (seems like I have too much)
Should I, go up in shock oil or put a beefier rear sway bar?
XRAY 2017 T4
Xray X12-17' GT12
Old 05-28-2015, 07:30 PM   #8306
rcgod's Avatar
Quick question,
Try reducing droop by a couple mm and see how it feels.
Old 05-28-2015, 08:11 PM   #8307
JEFFs SC10's Avatar
put limiters inside shocks or can I adjust that externally?
XRAY 2017 T4
Xray X12-17' GT12
Old 05-28-2015, 08:29 PM   #8308
Casper's Avatar
There are droop screws in the arms that you can use to limit shock travel so you do not have to take the shocks apart.
Old 05-29-2015, 05:57 AM   #8309
JEFFs SC10's Avatar
Had no idea droop affects body roll. I'll try it.
XRAY 2017 T4
Xray X12-17' GT12
Old 05-29-2015, 08:27 AM   #8310
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Quick question,
Oil could make it worse, the thicker bars would probably work better.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
