Like Tree4Likes
Old 05-25-2015, 07:07 AM   #8281
Is Losi gonna come out with a new truck anytime soon?
Danny "Ricky Bobby" Reddish
Owner of The Onionpatch Raceway
Whooo Hoooo
reddishdsb is offline   Reply With Quote
Old 05-25-2015, 09:02 AM   #8282
I'd say no since they just went thru and updated the materials and some parts on this truck making it even better. and this truck is made by TLR not Losi .... (yes I know it's the same company ).
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 05-25-2015, 09:20 AM   #8283
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by claytrackstar View Post
Whats up with sauce? I've been trying to figure out how to get my truck setup but I'm also interested in getting tires hooked up as ive heard it's the first thing to get dialed in. What do I sauce with? how do I apply it? Does it need to soak in?
Sticky Kicks or RC1 sauce are most popular. I like Sticky Blue or RC1 most of the time. Clean your tires and and then apply the sauce and let it soak in for 10-15 min before a run. After a few applications traction should come up quite a bit but it does work with the first application.
RX8 setup.
http://casper-rc.com/images/RX8.JPG
You should not need to use both connector holes as with good connectors all this power is still going through the same wires.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-25-2015, 04:35 PM   #8284
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
My rear diff was completely empty and seems to not be sealing. Gasket looks ok, do I need to replace it ?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 05-25-2015, 04:43 PM   #8285
Casper's Avatar
That is odd. It can be tough to get the screws tight the first time. I am assuming this is a 2.0 truck? 1.0 diffs could leak over time. 2.0 with HD diffs tend to seal really well.
Old 05-25-2015, 04:53 PM   #8286
JEFFs SC10's Avatar
yes it's a 2.0. I'm baffled as well.
XRAY 2017 T4
Xray X12-17' GT12
Old 05-25-2015, 06:03 PM   #8287
DoogieLee's Avatar
Trader Rating: 42 (100%+)
Thinking about racing ROAR regionals this year... I don't follow the rules that closely but as I understand it, 4 pole motors are NOT legal, correct?
If thats the case, what are my choices in the 550 can/ 2 pole market?
Using a Hobbywing SCT ESC as well.
Thanks in advance
DoogieLee is offline   Reply With Quote
Old 05-25-2015, 07:09 PM   #8288
JEFFs SC10's Avatar
not legal? Doog you going to New Reds?
XRAY 2017 T4
Xray X12-17' GT12
Old 05-25-2015, 07:15 PM   #8289
DoogieLee's Avatar
Negative, thats the 10th scale regionals.
4x4SC is running with 8th scale down at Sundancers.
Thats all i'm going to run is ebug and SC.
Been doing some more reading and apparently some 540 4 poles are legal, figures the Hobbywing isnt.
I wonder what in the actual hell Orion is on thinking they have a 540 motor that costs $195!!
I can tell you that I won't be using that one.
Probably a Tekin Pro4
I was worried I was going to have to run a 2 pole motor and start messing with timing and boost and all that crap.
I've never used any boost in any of mine... I could already smell the burnt motors!
Kevin 'Doogie' Lee
\m/ SCTE 3.0*XB8e\m/
Qualifiers are just organized practice...
Old 05-25-2015, 07:18 PM   #8290
JEFFs SC10's Avatar
Is turnigy trackstar legal? 4.5 550? let me know when that race is, i would like to go.
XRAY 2017 T4
Xray X12-17' GT12
Old 05-25-2015, 07:21 PM   #8291
DoogieLee's Avatar
The race is like Oct 15th I think.
Only Turnigy Trackstar motor I see on the list is the 540 4 pole, and at $45 bucks, that might be my choice. For that price I could pick up a few if I melt one down during testing.
Kevin 'Doogie' Lee
Old 05-25-2015, 10:56 PM   #8292
Sweet! Thanks man!
RX8 setup.
claytrackstar is offline   Reply With Quote
Old 05-26-2015, 09:05 AM   #8293
Casper's Avatar
I would tear down the diffs and check the o-rings and then make sure you get them tight after a rebuild. Again it can be a little tough to get the screws all the way snug on the first go around.
Old 05-26-2015, 12:37 PM   #8294
Trader Rating: 65 (100%+)
Try better diff screws.
TRAC2523 Screws 2.5x10mm. If you strip the plastic treads try the longer TRA2526 SCREWS 2.5X12mm. Both use a larger hex wrench.
How to Build SCTE bulletproof Diffs
Thunder Trail is offline   Reply With Quote
Old 05-26-2015, 02:11 PM   #8295
JEFFs SC10's Avatar
Thank you, it must be the orings cause I feel like i'm snugging the screws down enough.
If there's a rebuild kit, with the orings I'll do that.
XRAY 2017 T4
Xray X12-17' GT12
