Like Tree4Likes
Old 03-11-2015, 09:59 AM   #7846
Originally Posted by ResultsRC View Post
We dont need to rehash the losi plastic ball ends and alum balls. The rest of the plastics are great ive seen them survive huge crashes. Our losi eight buggies and truggies that use the steel balls must also use a diff grade plastic,they far outlast the scte 2.0 and take a harder beating. I am deff a rc tinker kinda guy,I like to know what works and what doesnt and I dont like to do more maintenance than I have to.
I built the front diff with stock losi washer on one side,mip on the other,tekno out drive axle and cvd on one side stock losi on the other.In the back same thing but reversed sides and used a xray washer.Used a front tekno drive shaft and a rear losi.used stock losi motor carrier in rear and kinghdz front After few months of hard use. The stock losi washers were worn almost half way through no visible wear to mip or xray,The out drives looked about the same both sides,but the ends of losi cvds were almost completely worn through,The losi axle holes for the pins were wallowed out 3x larger. The tekno axles and cvds were very hard to see wear at all.The losi drive shaft had 3 x more slop than the tekno even with less load and angle used in the rear than the front tekno supported by the dual bearing kinghdz. So take it for what it is,if you use the scte alot,but these parts and perform less maintenance or encourage losi to make them better.In the scheme of the whole kit they are very minor parts to improve on.
That's some good info there thanks for sharing.
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
Old 03-11-2015, 10:43 AM   #7847
Trader Rating: 65 (100%+)
It is funny huh. you say this as if I am using another brand and down talking the losi. We all know and enjoy this sc well. I guess rather or not you see it as a critical mod or not just comes down to how often you want to be fixing something that is broken,or racing at less than 100% or dont mind breaking in a race. The motor support is just the first thing that shows itself as a issue with the out drives floppin and center diff wearing out and leaking. If you have not noticed massive slop in your axles and and drive shafts,you either havent ran enough packs in the scte or you already have tekno gear in it. We are just pleased to hear the revised kit has some things made better. It does help to heat treat all the steel parts in oil,but it would be nice to not have to do that.the motor support does not need to be alum at all,A plastic part recast with dual bearing support would save people 80 bucks on on the kghdz a/m mod
keep in mind we are talking about running MANY packs at the track with plenty of large jumps through these,not just casual use.
I'm impressed with all your testing and your efforts to get results that do make a difference. Its a tinkering level just beyond what most have done. Thanks for sharing your info. I have thoroughly enjoyed it. Gave me a few ideas I have not considered. Hope you keep posting stuff like this. I know I want more of it.
Thunder Trail is offline   Reply With Quote
Old 03-11-2015, 12:33 PM   #7848
Trader Rating: 52 (100%+)
will the new chasis stop the loose rear end in off power?
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
CarFanatic is offline   Reply With Quote
Old 03-11-2015, 02:08 PM   #7849
rcgod's Avatar
Trader Rating: 27 (100%+)
That's not a chassis length issue, it's a setup issue.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 03-11-2015, 03:07 PM   #7850
my rear gets loose at times, whats the best way to stop that?
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
Old 03-11-2015, 04:00 PM   #7851
rcgod's Avatar
When exiting turns the most common ways to help are move rear hubs forward or lighter center diff fluid. When entering turns move hubs back, stiffer front springs, move camber link up on tower, heavier front diff fluid. There are other ways to help like camber, ride height, sway bars, etc. What setup are you running?
Dialed RC Hobbies
Old 03-11-2015, 04:04 PM   #7852
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
agreed.
ride height could be off, put a Dunford setup on it to the T then test.
Could be as easy as tires too.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 03-11-2015, 04:07 PM   #7853
When exiting turns the most common ways to help are move rear hubs forward or lighter center diff fluid. When entering turns move hubs back, stiffer front springs, move camber link up on tower, heavier front diff fluid. What setup are you running?
diffs are 5-7-3
-2 on camber
eveything else was what the manual said when I built it.
27mm ride height
35 front oil 27.5 rear
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
Old 03-11-2015, 05:15 PM   #7854
Dan.J's Avatar
Trader Rating: 21 (100%+)
Dangit just freakin rebuilt the truck top to bottom and now I got to tear it right back down for the shorter chassis Thanks TLR for the new option chassis, think it will help on the smaller tracks a bunch.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 03-11-2015, 05:46 PM   #7855
rcgod's Avatar
diffs are 5-7-3
-2 on camber
27mm ride height
Did your kit come with blue or black front springs? Are you running drag brake? You're sure the tires are right for the track conditions?
Dialed RC Hobbies
Old 03-12-2015, 04:12 AM   #7856
Braxamus's Avatar
One thing I have an issue with is a push on corner entry, it comes out of the corners nice and settles down after the jumps and goes nice down the straights. I am running a modified setup from the manual, waiting on the new stuff from TLR to switch the sway bars and such.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 03-12-2015, 11:16 AM   #7857
Originally Posted by seabass17 View Post
I would encourage everyone to pick up one of the new BCE chassis's. I saw it in person and raced against Kevin (rcgod) last night, The usual BCE high quality. I can honestly say I saw a major improvement in his lap times. Seems to me you get the best of both worlds. Steering and jumping ability of the 2.0 combined with the ability to push the car as hard as the 1.0! I had the BCE on my 1.0 and it was awesome,never bent anything and made the car amazing. Can't wait to get mine!
I'd like hear updates on this. I have worked with the bce
chassis on the 1.0 and can't get the 2.0 to handle as well with stock chassis no matter what ever tried.
ResultsRC is offline   Reply With Quote
Old 03-12-2015, 11:52 AM   #7858
rcgod's Avatar
Unless you can find one at a hobby shop or used they're not available anymore. Bill passed away last year and no one else took over.
Dialed RC Hobbies
Old 03-12-2015, 06:35 PM   #7859
Not sure on the springs will have to look. Tires are right the hook up great
Old 03-12-2015, 06:51 PM   #7860
xyzracer's Avatar
I have a used bce 1.0 chassis im not using.
xyzracer is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
