Like Tree4Likes
Old 02-12-2015, 02:26 PM   #7711
Originally Posted by S.TRIPP77 View Post
Will the ring an pinnion gear be straight cut??? On the new revision??
nope, they are still spiral cut.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 02-12-2015, 03:39 PM   #7712
DoogieLee's Avatar
Trader Rating: 42 (100%+)
what gearing and esc settings do you guys run with Hobbywing SCT pro with 4000kv?
Kevin 'Doogie' Lee
\m/ SCTE 3.0*XB8e\m/
Qualifiers are just organized practice...
DoogieLee is offline   Reply With Quote
Old 02-12-2015, 04:19 PM   #7713
Razorbelly's Avatar
__________________________________________________ _____
ESC 1)Forward/Brake. 2) 0% Drag. 3) 2.6VCell. 4)Level 5 punch. 5) 75% brake
6)25%. 7) 0%. 8) 9%. 9) 5 timing. 10) enable. 14T or 15T pinion.
Razorbelly is offline   Reply With Quote
Old 02-12-2015, 04:31 PM   #7714
DoogieLee's Avatar
That basically what I have mine set at, i'm coming from a VTX8 and 4000kv HW motor, decided to freshen my electrics up, so I got a new SCT combo, and it just didnt seem to have the balls my old setup had. It was noticeably slower. I have it geared with a 15 and temps reasonable (120) i bumped my timing up to 7 and it kicked up more speed, and only temped 130. Guess I just need some more time with this setup to get it dialed in.
Kevin 'Doogie' Lee
Old 02-13-2015, 10:49 AM   #7715
Braxamus's Avatar
How important is the fluid in the diff's? and how does different weight affect handling? Trying to learn something, as I get more and more into it just like when racing the Custom Works sprints, even though someone says this is the setup to go with kind of like the newest Dunford setup, just because it works for him don't mean it is perfect for me. So more I can learn and understand it helps me tweak my own.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 02-13-2015, 11:13 AM   #7716
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Fluids in the diffs are very important. Most can feel going up in each weight increment such as 2k to 3k.
Start with a known good setup an adjust to your style and track. Dunfords' or Caspers are good places to start.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-13-2015, 01:01 PM   #7717
Casper's Avatar
Trader Rating: 33 (100%+)
http://www.tlracing.com/ProdInfo/Fil...uning_Tips.pdf
Great reading if you are new to the truck or 4wd.
+1 to Mr. Pike!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-16-2015, 04:06 AM   #7718
Braxamus's Avatar
Thanks Casper I already have that and have it on my tablet to take to the track with me. I just never considered changing the fluid at the track. would be nice if the diffs had a fill and drain plug so you didn't have to do a total disassemble to try different fluids.
Team Raw Speed
Old 02-16-2015, 08:33 AM   #7719
Casper's Avatar
Yeah it is a little bit of a process. The other option is to buy a spare diff.
Old 02-16-2015, 11:17 AM   #7720
Braxamus's Avatar
I was going to buy new ones this year after the indoor season was over, that may be a good idea. build and install new, then keep the old ones and rebuild them with different wt. oils.
Team Raw Speed
Old 02-16-2015, 11:23 AM   #7721
Trader Rating: 20 (100%+)
Default Shocks
Does anyone know if Losi 8 3.0 shock towers will fit on the Losi SCTE 2.0? I'm doing the MIP Conversion and wanted to use 8 shocks on it and aluminum towers front and rear...they seem like they will fit but not sure if I need longer shock or will the SCTE 2.0 shocks work...or will the shock towers of the Losi 8 fit?
YonkersRC is offline   Reply With Quote
Old 02-16-2015, 11:52 AM   #7722
Casper's Avatar
No the diff cases are smaller on the Ten series.
You should not need 8ight shocks. Being the 8th scale conversions acutally lighten up the truck the stock shocks should be good.
Old 02-16-2015, 01:34 PM   #7723
I'm trying to add weight to reach 7lbs so I can race it at Motorama...any suggestions?
Anthony
Old 02-16-2015, 01:41 PM   #7724
maddog9's Avatar
Trader Rating: 29 (100%+)
Anthony
Run a heavier battery, add stick weights to the chassis until your buggy is 7 pounds.
maddog9 is offline   Reply With Quote
Old 02-16-2015, 02:25 PM   #7725
Stupid question...newer to racing...where can I get stick weights?
Sorry
