Like Tree4Likes
Old 01-28-2015, 07:09 PM   #7666
ta_man's Avatar
Trader Rating: 151 (100%+)
Originally Posted by ResultsRC View Post
We have been putting alot of time on a few scte trucks,It seems impossible to set a reliable toe and camber with these losi ball ends,even with the hardened anodized ball ends,after very few runs its totally losi loose. Has anyone tried running xray or tekno ball ends on this model? They have a little angle built into them? They seem to last alot longer on those other models.
Not sure why, but my experience was that the inner balls of the camber links (the ones on the shock towers) wear faster than the outer ones. I replaced the inner ones with the equivalent parts from a Losi 8ight 2.0 and they are lasting a long time.
ta_man is offline   Reply With Quote
Old 01-29-2015, 06:04 AM   #7667
jmcelroy42's Avatar
Originally Posted by impson View Post
What's the best servo for the truck? 6030? 6040?
http://www.amain.com/protek-r-c-130t...oltage/p228476
For the price, ProTek servos are really nice.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is online now   Reply With Quote
Old 01-30-2015, 05:01 AM   #7668
XXXDad's Avatar
Trader Rating: 195 (100%+)
Exclamation I agree
But use this one>http://www.amain.com/protek-r-c-130s...oltage/p253592
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 01-30-2015, 06:18 AM   #7669
jmcelroy42's Avatar
Originally Posted by XXXDad View Post
Yea I suppose 260 oz-in is plenty for a 4x4 SC. I have the 130ss in my B5 lol, I like overkill!!!
Old 01-30-2015, 07:41 AM   #7670
rcgod's Avatar
Trader Rating: 27 (100%+)
+1 protek are great servos can't beat them for the price and amain will stand behind them if you have issues. I have the 130t and 130ss and both are great.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-02-2015, 11:28 AM   #7671
Braxamus's Avatar
Hey Maddog what shock setup, and springs do you run at Sparks park?
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 02-02-2015, 04:12 PM   #7672
Arknabbit's Avatar
Out of curiosity, how much does your 2.0 weigh, minus battery and tires?
Arknabbit is offline   Reply With Quote
Old 02-03-2015, 06:50 AM   #7673
Braxamus's Avatar
Is there any real advantage in running the RPM front bumper on this over the stock one does it protect it any better or is it any stronger?
Team Raw Speed
Old 02-03-2015, 11:32 AM   #7674
maddog9's Avatar
Trader Rating: 29 (100%+)
No take it off or any skid plates as the reduce your ground clearance.
2875g race ready with body on.
Blue springs up front, red in the rear, #3 pistons all around, tlr 30 up front, tlr 25 rear. Its the dunford setup.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 02-04-2015, 03:59 AM   #7675
Braxamus's Avatar
I currently run both the RPM front bumper and rear skid plate, and I understand that they both take away from ground clearance, but should the truck really be getting that close to the ground for them to matter I mean both are only an 1/8th inch or less in thickness. Let me say that I'm not questioning your comment just trying to understand and I like specific reasons as it helps me understand why something is done the way it is.
Team Raw Speed
Old 02-04-2015, 06:19 AM   #7676
jmcelroy42's Avatar
I've wondered this as well.
Old 02-04-2015, 07:05 AM   #7677
rcgod's Avatar
1/8" is 3mm. The difference in handling between running your truck at 25mm versus 28mm is noticeable.
Dialed RC Hobbies
Old 02-04-2015, 08:58 AM   #7678
Braxamus's Avatar
I understand that, and since it is a flat chassis, I have been setting my ride height to the center chassis right behind the front bumper and in front of the rear skid plate to what I have been running 26mm. so at that I am actually at 23mm with the 3mm of clearance loss.
Team Raw Speed
Old 02-04-2015, 09:09 AM   #7679
rcgod's Avatar
Correct. And when you're driving around the track the bottom of the chassis is too low. The skid plates are hitting the ground and making your truck unsettled. Or they are hitting the ground on the face of the jump and causing nose up or (usually) nose down jumping. The bottom of the chassis should be smooth to allow the truck to slide when it hits. The chassis is a wear item like tires. If you're running skid plates or anything that hangs below the chassis you're hurting the handling of your truck. If it's worth it to you to save $ on chassis replacement then all good. The guys that are looking for the best performance are willing to make the trade off.
Even racing on abrasive outdoor tracks it takes a long time to wear out a chassis to where it affects performance. $100 every year or two is a drop in the bucket in the big picture.
Dialed RC Hobbies
Old 02-04-2015, 09:41 AM   #7680
Braxamus's Avatar
True, and thank you, and maddog for the explanations, I just don't like just doing something because someone says without understanding why. Both will be coming off before the next race. Also I know it's here somewhere but could not find it, is there a set of sway bars I can buy without modifications to set it up like the new Dunford setup.
Team Raw Speed
