Like Tree4Likes
Old 01-26-2015, 05:38 PM   #7651
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Roken View Post
I was just going to post something for you in regards to "don't fear the wrath of God." Of course we don't know everything that's why we are here. Please don't let this stop you from coming here and asking, learning. Some questions get no replies, but I've found most of the time people are helpful.
Sorry if I came off a little harsh. Wasn't meant that way. My point being there are plenty of guys that will steer you down the wrong path because they don't know enough about what's going on with your truck. Myself or Hacker or an one else can't give you any recommendations unless we know where you're at now. I was simply asking for more details. Everything matters when you're trying to get a car or truck working like you want it to.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-26-2015, 05:46 PM   #7652
Definitely appreciated...i screwed the pooch a little by not taking enough notes on my initial setup. I'm learning that one of my most critical tools needs to be a pencil lol
brucestyves is offline   Reply With Quote
Old 01-26-2015, 06:00 PM   #7653
Originally Posted by hkrob View Post
Try running Ryan's OCRC setup works great on tight indoor tracks I've been running it for sometime on several different tracks.
Where could I find Ryan's setup?
Austin's dad is offline   Reply With Quote
Old 01-26-2015, 06:06 PM   #7654
Trader Rating: 15 (100%+)
Originally Posted by impson View Post
I need to get a front drive shaft. The manual says LOSB3578, but when i go to purchase that....it says that is the rear shaft. Thoughts?
They swapped drive shafts front to back between the 1.0 and 2.0. On the bottom on A-Mains site it has a note about it.
Tommygun1 is offline   Reply With Quote
Old 01-26-2015, 06:12 PM   #7655
hkrob's Avatar
Trader Rating: 18 (100%+)
http://www.casper-rc.com/TLR_Ten-SCTE.htm
hkrob is offline   Reply With Quote
Old 01-27-2015, 05:30 AM   #7656
Thanks for that link! It gives me a good baseline to start with. All of the regular racers at our track regularly refer to the track as high bite so I suspect I might end up somewhere between the OCRC and the High Bite setup. Now I just have to make time to get back to the track when I have a weekend that isn't taken up by basketball tournaments for my son.
Thanks again to everyone!
Old 01-27-2015, 09:26 AM   #7657
We have been putting alot of time on a few scte trucks,It seems impossible to set a reliable toe and camber with these losi ball ends,even with the hardened anodized ball ends,after very few runs its totally losi loose. Has anyone tried running xray or tekno ball ends on this model? They have a little angle built into them? They seem to last alot longer on those other models.
ResultsRC is offline   Reply With Quote
Old 01-27-2015, 09:37 AM   #7658
rcgod's Avatar
Best fix I've found is running the mip kit that replaces the ends with dubro parts. If you shop around you can get ti turnbuckles and the ends for about $50. They last a long time. The mip kit uses the 4-40 ends but I used the 3mm ones.
Dialed RC Hobbies
Old 01-27-2015, 09:15 PM   #7659
All of these have lundsford ti turnbuckles. Mip uses dubro ends? whats stronger 4 40 or 3mm? can you post a link to the type ends your referring to
Old 01-27-2015, 09:59 PM   #7660
rcgod's Avatar
http://shop.dubro.com/products/produ...3.0.0.0?pp=12&
The mip kits use 4-40 size. They also make monster rod ends.
I think the regular ones would be fine for steering and the monster ones for camber links. We used to run the 4-40 ends on our gas trucks back in the day and they didn't have slop and lasted a long time. You can get good deals on ebay. I just picked up a 20 pack of the 3mm HD for less than $20 shipped. I'm going to use 3mm ti turnbuckles on the steering and drill them out and use 3.5 mm ti on camber links.
Dialed RC Hobbies
Old 01-28-2015, 04:01 AM   #7661
Braxamus's Avatar
As good a truck as this is I cannot believe TLR would not take the time to address this issue. I love the truck and am glad I decided to go with it, but man the slop drives me crazy.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 01-28-2015, 04:26 AM   #7662
Trader Rating: 23 (100%+)
What's the best servo for the truck? 6030? 6040?
impson is offline   Reply With Quote
Old 01-28-2015, 12:13 PM   #7663
Braxamus's Avatar
impson are you one of the guys who used to race at 42 in Mansfield?
Team Raw Speed
Old 01-28-2015, 12:22 PM   #7664
vito's Avatar
a main has them back order out 2 mounts
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 01-28-2015, 01:45 PM   #7665
dtr
dtr's Avatar
6040 out of those two; 6030 is not fast enough for most drivers. "The best" is always a question of budget and availability; a trackstar ts-900 is a good cheap solution if you have a lot of patience, as chinese new year will delay shipments to over a month. A KO bsx2 is better and you will get it quicker, for a price though. There are a lot of good ones in between, right now I would probably check out this Xpert or this Hitec.
dtr is offline   Reply With Quote
