Like Tree4Likes
Old 01-26-2015, 06:02 AM   #7636
Default Setup for high traction tight clay track
Hey Guys,
I just got my new to me 2.0. Took it out this weekend to the local track and struggling to get it to turn into the corner. I did find if I got my speed backed down early I could get it to turn in but my 1.0 I was able to drive into the corner a little harder.
I didn't to a complete breakdown of the truck before going so my hunch is that it's probably a combo of oil weights and setup but if anyone has specific suggestions for that style track I'll take them. Most guys at my track run Tekno but I'm a Losi guy and really believe if I can get the correct setup in the truck I can compete with the Teknos once I have enough wheel time.
brucestyves is offline   Reply With Quote
Old 01-26-2015, 06:20 AM   #7637
Default Alum Front Spindles?
Anyone else running these on their trucks? I had one break this weekend and am really baffled how or why it would break. Sucks to have a $40 upgrade piece break when the part is basically new.
Old 01-26-2015, 08:29 AM   #7638
How long ago did you buy these? Do you still happen to have the header card?
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 01-26-2015, 10:18 AM   #7639
rcgod's Avatar
Trader Rating: 27 (100%+)
Hey Guys,
What setup were you running?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-26-2015, 12:54 PM   #7640
Trader Rating: 23 (100%+)
Just bought a 2.0 Have a few questions...
1. Can someone post a link for a good starting setup. I will be running it at The Factory (Where the CRCRC Midwest race was just at) and at Sparks in Ohio. Id like to see a sheet from the race that was just there if possible.
2. What springs come stock in the kit?
3. I need to get a front drive shaft. The manual says LOSB3578, but when i go to purchase that....it says that is the rear shaft. Thoughts?
4. Which is the best body to run on the truck?
impson is offline   Reply With Quote
Old 01-26-2015, 01:13 PM   #7641
They are not very old, no header card though. I emailed Horizon a picture asking if they could replace the broken part...will have to wait and see I guess.
Old 01-26-2015, 01:17 PM   #7642
5-7-5 in the diffs, 30front, 27.5rear oils. No droop limiters and fairly stiff springs.
Stock rear toe and anti squat, stock front kick up.
Initial changes I am looking at is taking 0.5 deg of toe in away in the rear, softer springs and putting in droop limiting screws.
Thoughts on the diff fluids? My initial thought was 7k in front but wonder if that's going to prevent the front from turning?
Old 01-26-2015, 01:21 PM   #7643
hmmm, ok. Just depends how long the shop you got them from has had them. Can you send that pic to me as well...rdunford@horizonhobby.com?
Also, in regards to getting what you need from CS, call them and use the call back feature, takes like 2 minutes. That puts you in the queue and they will call you back and it will get taken care of right away.
-Ryan Dunford
Old 01-26-2015, 01:46 PM   #7644
rcgod's Avatar
What do you mean by stiff springs? What springs and shock positions are you using? 7k in the front is usually used on high bite tracks to make the truck more stable entering turns. Going thicker there won't help your issue. You need to give us your whole setup before we can help. Ride height, camber, link locations, caster blocks (stock or Losi alum), sway bars etc.
Fwiw I tried the aluminum caster blocks and went back to stock. Didn't fit my driving style.
Dialed RC Hobbies
Old 01-26-2015, 05:06 PM   #7645
I'm making some changes to set it up closer to my old 1.0 with a couple minor changes and use that as my baseline then come back to pick some brains of guys who obviously are more qualified than me lol. Thanks everyone!
Old 01-26-2015, 05:16 PM   #7646
Sent you an email, thanks for the heads up on CS though! I'm going to wait this time so i don't confuse them and have two open tickets for the same issue.
I appreciate the customer service since I've dropped a small fortune on my Losis the past couple years lol. I have had two 1.0 sctes (still have one for my son), a 2.0 nitro buggy (sold that), a mini 8 buggy (sold too), and i currently have the 2.0 scte, a 2.0 nitro truggy and a mini 8ight-t.
Old 01-26-2015, 05:23 PM   #7647
I was just going to post something for you in regards to "don't fear the wrath of God." Of course we don't know everything that's why we are here. Please don't let this stop you from coming here and asking, learning. Some questions get no replies, but I've found most of the time people are helpful.
Roken is offline   Reply With Quote
Old 01-26-2015, 05:32 PM   #7648
Duplicate
Old 01-26-2015, 05:32 PM   #7649
I'm a little disappointed with God. Seams he dropped to the dark side and got a X-ray 4x4 buggy. I'm starting to build the worlds car now, a 22-4.
Old 01-26-2015, 05:36 PM   #7650
hkrob's Avatar
Trader Rating: 18 (100%+)
Hey Guys,
Try running Ryan's OCRC setup works great on tight indoor tracks I've been running it for sometime on several different tracks.
hkrob is offline   Reply With Quote
