Like Tree4Likes
Old 01-14-2015, 02:22 PM   #7621
Originally Posted by skyler hays View Post
Ryan,
What would you tweak on this setup if you wanted the truck to be more aggressive, more twitchy. My track is tigh with a lot of 180 turns. I drove a buddies Tekno and it felt more agressive and rotated better. I know how I want the truck to drive but not sure how to connect the dots. I have your setup referenced above under the truck now. Thanks
The first thing is to make sure you have full steering throw with the alum caster blocks. Place your vehicle on the ground under its own weight and adjust the end points to the end plus about 2 clicks. The Alum caster blocks have more throw to them and I often see people not get the extra throw out of them. From there, it all depends on if you want the steering from the front or the rear. You can go to lighter front diff fluid and lighter center, maybe 5/5/5. You can use a softer front spring. You can match the rear sway bar and go down to a 2.2.
Originally Posted by huzzler View Post
I went with the front Tekno driveshafts and Integy castor block/steering knuckles and it has a lot more steering then stock. Also Put the pivot block inserts in REAR as Front 1 up Rear .5 in. Then the FRONT block front 1 down rear 1 up. It can turn just as good as my EB48.
In all honesty and nothing to bash any other vendor for sure but the extra steering you are getting isnt form a tekno or integy part. You took toe out of the rear which makes for more rotation and then changed your front kick to only 8 degrees which is good for some flat tracks or non bumpy tracks, but that is where you got your steering from. The TLR alum caster block has more physical throw than the integy ones.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 01-14-2015, 02:33 PM   #7622
I have full steering throw. I set it with truck on the ground. I want the steering from the front. I don't want to have to drift it to make it turn. I am going to January jam next week. I will have plenty of practice time to tweak setup.
Tekno SCT 410.3 rx8gen2/pro 4 4300HD 1267 savox servo
Tekno EB 48.3 rx8gen2/t8 1900kv 1267 savox servo
Tekno NB 48.3 Novarossi 5PXLT 1267 savox servos
all controlled with spektrum dX4R
skyler hays is offline   Reply With Quote
Old 01-14-2015, 03:49 PM   #7623
Casper's Avatar
Trader Rating: 33 (100%+)
Yes Casper. I didn't put on the 2.3 from the 8ight but I used the 2 from the scte kit. I actually took the front one completely off after running several laps. Still not satisfied.
Softer front spring would be what I try first. You can go lighter on the front diff fluid as well.
A little more front camber.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-15-2015, 11:43 AM   #7624
Try a shorter front camber link. That gives a bit more steering for sure on this truck.
-Ryan Dunford
Old 01-15-2015, 12:08 PM   #7625
rcgod's Avatar
Trader Rating: 27 (100%+)
Sounds like your driving style is a lot like mine. More point and shoot. I want my truck to steer from the front. These worked for me.
Go to the original Dunford setup on Casper.-rc but use the #1 front camber link location. Use #3 pistons with 30/25 or 32.5/27.5 depending on temp and traction. If it still doesn't have enough entry steering go inside on rear camber link on hub. I also like a little drag brake usually about 5 percent. I tried the Losi alum caster blocks and went back to stock ones. The integy blocks are the same geometry as the plastic blocks so you're good there. Truck has tons of entry and mid corner steering and just enough exit steering to not push out. If the traction comes up go to 7k in the center or the truck will diff out under acceleration.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-15-2015, 12:25 PM   #7626
Braxamus's Avatar
maddog what gearing are you using for Sparks?
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 01-15-2015, 05:43 PM   #7627
Thanks guys
Old 01-15-2015, 06:23 PM   #7628
maddog9's Avatar
Trader Rating: 29 (100%+)
Keep in mind i am running a 4.5t 2 pole. 13 pinion, 41 mip spur. Or 13/40 would be fine.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 01-16-2015, 05:17 AM   #7629
#1 camber link location is for a long front camber link. Did you mean #2? I'm not being a smart*** just trying to clarify.
potatobed409 is offline   Reply With Quote
Old 01-16-2015, 08:02 PM   #7630
thebalance's Avatar
Default Shocks
On the OCRC setup sheet it says overall shock length 89.5mm. Does that mean to measure from center top hole to center bottom hole? Thanks.
thebalance is offline   Reply With Quote
Old 01-16-2015, 11:28 PM   #7631
yes from center of mounting to center of mounting.
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 01-21-2015, 03:36 PM   #7632
LosiRacer33's Avatar
SCTE 2.0 in stock at RCHR. Call them. 203-575-9757
www.gallimods.com
TLR SCTE 2.0, 22-4, 22 2.0
Tekin Motors and Speed, Orion Batteries
superty.org
LosiRacer33 is offline   Reply With Quote
Old 01-22-2015, 09:56 AM   #7633
Braxamus's Avatar
You guys need to keep this active so it don't drop so far and I got to go back a few pages to find it....................LOL
Team Raw Speed
Old 01-22-2015, 10:51 AM   #7634
I'll keep it going... They haven't raced 4WD SC at my track for months. Couldn't stand seeing the SCTE 2.0 sit on the shelf! Instead of selling it, I made myself an outdoor truggy. Gotta replace the 8ight e stickers on the side, but they'll do for now. Also replaced the hood sticker for the Ten SCTE sticker. This thing is so much fun. Even ran it around on the track last night and it was surprisingly good. SCTE 2.0, Proline 2.8 Trenchers, 8ight-t e 3.0 body and wing. Used the wing and body mounts from the 8ight as well.
Official TLR TEN-SCTE 2.0 Kit Thread-side-scte-t.jpg   Official TLR TEN-SCTE 2.0 Kit Thread-rear-mount.jpg
www.gallimods.com
superty.org
Old 01-23-2015, 04:00 AM   #7635
Braxamus's Avatar
that does look pretty cool......
Team Raw Speed
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
