Like Tree4Likes
Old 12-20-2014, 08:47 AM   #7516
chucko's Avatar
Originally Posted by LosiRacer33 View Post
Been having a nose dive issue for the longest time. Sporadic. Even sometimes down a long straight into a turn, it feels/looks like the truck is slamming on the brakes. I've tried everything to fix it. Rebuilt shocks, diffs, suspension pins... About everything. I even talked to the Tekin guys to make sure my ESC was setup right. Drag Brake is on zero. The truck used to be mint, now it's got this issue.
Today I found this (see picture). The "A" wire between the motor and ESC is partially broken, right next to the ESC. It's not hitting anything. Just partially broken. Could that cause things to short? I'm replacing, but wanted to get your opinions.
Hope this helps: re calibrate the radio to center trim the throttle to just before it starts to go . elect motors seem to work like a break causing the nose to dive.... if you stay on the throttle it wont dive ,,ITS a timing issue with your finger. you can also add push control in set ups like 25 or any thing that helps
Losi 22, XXX, SCTE 2.0, 8ight E.2.0, B44 and last but not the last a 44 .3, M11 X
rc scoring pro
Track owner & race director.
Crook County Race Course Prineville Oregon.
chucko is offline   Reply With Quote
Old 12-20-2014, 01:05 PM   #7517
Casper's Avatar
Trader Rating: 33 (100%+)
That is never good. It could cause quite a few different issues.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-21-2014, 06:52 AM   #7518
LosiRacer33's Avatar
I'm gonna replace and see what happens. It's not a driving style. Even going into a turn sometimes it drops the front end bad like the brakes are slamming on.
www.gallimods.com
TLR SCTE 2.0, 22-4, 22 2.0
Tekin Motors and Speed, Orion Batteries
superty.org
LosiRacer33 is offline   Reply With Quote
Old 12-21-2014, 06:19 PM   #7519
XXXDad's Avatar
Trader Rating: 195 (100%+)
I'm running Orion R10 Pro with Tekin 4600 geared 14/40 anyone run 15 tooth pinion , trying to get less wheel spin with more top end. Med./Large outdoor track 80* ambient temps. Hope I don't overheat. Only those who use this combo please comment.
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 12-21-2014, 06:36 PM   #7520
nexxus's Avatar
Trader Rating: 302 (100%+)
Just got my 2.0, any spares I should keep on me? I have done the RPM Front and rear arms and rear bumper, Electrics is a Hobbywing SCT Pro combo with 4000kv motor
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 12-21-2014, 07:10 PM   #7521
XXXDad's Avatar
For me its dogbones/cvd the pin comes out at the out
drive. They come loose , from a stress crack or just loose fit.
Old 12-21-2014, 11:39 PM   #7522
nexxus's Avatar
Tekno centre cvd's fix this?
Old 12-22-2014, 02:58 AM   #7523
maddog9's Avatar
Trader Rating: 29 (100%+)
Try turning the punch down on the esc and/or add expo to your radio.
maddog9 is offline   Reply With Quote
Old 12-22-2014, 08:23 AM   #7524
rcgod's Avatar
Trader Rating: 27 (100%+)
The only thing I've broken on this truck since I started racing it when the 1.0 came out is a rear hub and my 6 year old son broke a front arm running it full speed into a track barrier. It's a tank.
FYI the rpm rear arms limit droop quite a bit. Unless you're running on only super high bite I wouldn't use them. The stock arms are more than strong enough and work better unless you're bashing.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-22-2014, 06:47 PM   #7525
lowspark's Avatar
I am running 15/39 with the R10 and 4600 on a large indoor track. No issues with heat and plenty of power. I have my punch set at 5. No problem with 7 min qualifiers running a Venom 5800/70c and 10 min main using a 7200/100c.
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 12-23-2014, 05:15 AM   #7526
XXXDad's Avatar
Thumbs up
Thanks lowspark I will try it this weekend! So looking forward to the New Upgrade parts from TLR for this platform!!
Old 12-23-2014, 05:29 AM   #7527
Trader Rating: 20 (100%+)
Tyler loves his now and it's a missle. Ran it for a full year all stock parts with zero failures on any part. If the new upgrades make that big of a difference, look out cause he's usually as fast with it as his 1/8 cars. TLR is always helping us go faster and we love it!!
Randy
RandyJones is offline   Reply With Quote
Old 12-23-2014, 08:12 AM   #7528
I run mine 15/39 at most tracks. So 15/40 should be ok. Everyone uses throttle a bit different though so be sure to just watch the temps some until you know its good.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 12-23-2014, 08:13 AM   #7529
FYI. RCHR in Waterbury CT has a new one in stock. They are open tonight and they will ship.
www.gallimods.com
superty.org
Old 12-23-2014, 11:59 AM   #7530
Braxamus's Avatar
only thing I have ever broke on mine was the LF camber link when someone who doesn't look ahead or listen to the announcer say "watch the end of the straight way" he T-boned me. And I am pretty rough on the truck as I am still learning to drive.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
