Like Tree4Likes
Old 11-25-2014, 01:54 PM   #7426
Bivens's Avatar
It is always fun looking at something like the Worlds to see the new cool stuff. But that release pressure sometimes means that the item does not get the time it should've taken to get things perfect.
I've never been disappointed by a TLR product....Keep on keep'n on....and I'll buy whatever new release comes out...when it's ready.
I was just joking around above with that time travel thing.....to anyone who's been around RC for a while, those guys asking about release dates and hurry to upgrade existing cars seem to become the running joke at any given time.
Team 3D Hobbyshop
www.3dhobbyshop.com
Bivens is offline   Reply With Quote
Old 11-25-2014, 03:06 PM   #7427
Default Astro Turf/Carpet setups for scte 2.0
Hello all,
Anyone have a link they could please post to a good setup sheet for astro turf/carpet for the scte 2.0?
Thx in advance,
Tharen
Duunga is offline   Reply With Quote
Old 11-25-2014, 04:03 PM   #7428
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Duunga View Post
Hello all,
Thx in advance,
Tharen
Not an astro setup but sugar is not too far.
http://casper-rc.com/TLR_Ten-SCTE.htm
Ref Dunford Sugar setup.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-25-2014, 04:35 PM   #7429
cttech455's Avatar
Hello all,
Thx in advance,
Tharen
Theres one on page 458 of this thread if your only doing carpet racing with your truck. The setup casper listed would be excellent as well especially if you are going to be racing on dirt surfaces as well. You might be able to get by with just ride height changes depending on where your at. You want to get a tire designed for carpet racing. A tire designed for a dirt or clay track won't grip as well and the sidewall will tend to fold under while cornering which can contribute to a rollover. As far as I know you have basically three choices:
1. The proline pinpoint. I liked this tire. The quality is very good. These tires come with the proline blue closed cell foams.
2. Dboots nanobyte. I've used these a few times. They don't come with foams and the fit around the bead of the wheel kind of has gaps. Also the tires tend to kind of "peak" in the middle when I used them with closed cell foams. Good grip though.
3. Schumacher mini pins and mini spikes. These are available in blue (harder) and yellow (softer) compounds. The quality is very good. They don't come with foams.
Of these I like yellow mini pins the best. Depending on the traction of the surface you run on you will most likely be trimming the outer rows of pins. Lately I've been trimming off the outer row on the rears and outer 3 on the fronts. Another trick you could try is wrapping a good electrical tape (like super 33) on the outer shoulder of the tire. This will help the vehicle keep from rolling over if it gets up on two wheels.
cttech455 is offline   Reply With Quote
Old 11-25-2014, 08:25 PM   #7430
thx Casper
Old 11-25-2014, 08:26 PM   #7431
thx cttech455
Old 11-26-2014, 02:34 AM   #7432
Originally Posted by Casper View Post
UM that is what MIP originally came out with and then rebranded the platform to try and start the Pro 8 class with light 2S 8th scale.
The weight balance of the MIP truck is slightly different then the SCTE 2.0 with battery placement and some other things in a little different location. TLR worked hard to optimise the placement of components for the SCTE 2.0 and feel it is better than the MIP but with all things like that, there is obviously different opinions as well as what people like for handling.
thanks casper I thought maybe it would change the handling to be a lil more agile like a Buggy or not .
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 11-26-2014, 09:42 AM   #7433
Casper's Avatar
The 8th scale tires are lighter and would help (if you local rules allow it) and the buggy body taking all the weight off the top of the car and the rear wing are all what make the buggy handle better.
The chassis layout really is not where the real handing benefit difference are between a SCT and a buggy.
Old 11-26-2014, 10:53 AM   #7434
Either config is outstanding when you get it tweeked to your driving style and tastes. Tekno (while a nice design) has nothing on this truck.
The MIP camber and steering link kits eliminate a majority of the slop, last longer than the stock, and take away some weight.
The (already mentioned) area I'd like to see improved is access to the center diff and dual screws in the motor mount slider (like the Tekno design). Big outdoor jumps can lead to motor movement and spur destruction.....
Both are minor, but would be nice to see.
www.bumpsandjumpsrc.com
www.lcrcraceway.com
www.miponline.com
www.serpentamerica.com
Lovell's Lids
wicker9 is offline   Reply With Quote
Old 11-26-2014, 03:23 PM   #7435
blade329's Avatar
Trader Rating: 114 (100%+)
That rather defeats the whole purpose of a short course truck. They are not supposed to be agile.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 11-26-2014, 04:54 PM   #7436
swalesy09's Avatar
Default MIP spring rates
Hi. I'm would like to know what the spring rates are for the MIP springs
B4.1 WE, T4.1 FT
Futaba 4PK-S Speed Passion Escs Fantom Brushless Motors
Tracks I race at: Chargers R/C GCRC Raceway
Member Of Chargers R/C
www.actionrc.com.au, www.amainhobbies.com, www.fantomracing.com
swalesy09 is offline   Reply With Quote
Old 11-26-2014, 07:28 PM   #7437
mojo 309's Avatar
whats a good 2s lipo that gives plenty of power and run time for either of the scte's
Schumacher MI3.5 us/vta,
Spektrum.
Speed Passion ESC.
Savox Servo's.
Midwest Kustomz.
mojo 309 is offline   Reply With Quote
Old 11-26-2014, 08:13 PM   #7438
Dan.J's Avatar
Trader Rating: 21 (100%+)
Look for pretty big mah and high C rate for these trucks from a quality vendor, I have been using the SMC 7200mah packs in mine for the last year.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 11-26-2014, 11:41 PM   #7439
whats the purpose then to drive like a brick ??? lol j/k everyone is always looking for that performance/handling edge.
TLR 22T 2.0
Old 11-27-2014, 05:02 AM   #7440
MD
MD's Avatar
Trader Rating: 118 (100%+)
http://www.maxamps.com
http://www.hobbypartz.com/geaceha.html
This place has a few higher "C" rating batteries and their inexpensive, but I have had very good luck with them. Their plug-ins on the battery are a little funky but they won't come out.
http://www.valuehobby.com/power-syst...0mah-2s-t.html
MD is offline   Reply With Quote
