Like Tree4Likes
Old 11-03-2014, 09:36 AM   #7336
Originally Posted by Grigz View Post
Anyone know of the size of the grub screw for the sway bars? Some how lost mine and can't find a replacement for just the grub screw without buying the whole tuning kit? Suggestions?
There are two different sized set screws in the SCTE sway bar set. So, both Casper and Frank are correct. If you want the little one that goes in the plastic holder to set the play correctly, that is the 4-40 one that Casper says. If you want the one that holds the sway bar ball end onto the sway bar, that is the 5-40 one Frank says.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 11-03-2014, 07:01 PM   #7337
Casper's Avatar
Trader Rating: 33 (100%+)
LOL. So is the one you need sliver or black?
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-05-2014, 04:37 AM   #7338
Default more info
Originally Posted by XXXDad View Post
I like 5/7/2 turns better and the back end is more stable
Running on large outdoor track with large jumps. Hard packed clay with loose dirt and sand. The 5/7/5 dunford set up is ok, but can be pretty loose in rear. Are you using different springs and shock locations on your 5/7/2 setup. Need to find better way to keep rear end planted for not the best throttle control guy. thanks
Russell 27 is offline   Reply With Quote
Old 11-06-2014, 08:57 AM   #7339
Braxamus's Avatar
will the MIP chassis braces or (what is called torque rods in the manual) work on a stock 2.0 chassis, or are the stock torque rods longer than the MIP ones?
Braxamus is offline   Reply With Quote
Old 11-06-2014, 11:16 AM   #7340
rcgod's Avatar
Trader Rating: 27 (100%+)
MIP13249 bolt up fine. Not sure if they're the same as the ones that come with the pro4mance chassis though if that's what you mean.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 11-06-2014, 11:34 AM   #7341
Braxamus's Avatar
yea I got a MIP chassis now and going back to the stock 2.0 so they are the ones that came with the chassis.
Old 11-06-2014, 12:21 PM   #7342
rcgod's Avatar
Different part numbers and the description in the ones you have says specifically for the mip chassis but I would call them and ask.
Dialed RC Hobbies
Old 11-07-2014, 06:39 AM   #7343
LosiRacer33's Avatar
Looking for rear outer hinge pins. TLR6080. Nobody local has them. Is there another part number for an earlier version or something else that may work?
www.gallimods.com
TLR SCTE 2.0, 22-4, 22 2.0
Tekin Motors and Speed, Orion Batteries
superty.org
LosiRacer33 is offline   Reply With Quote
Old 11-07-2014, 08:14 AM   #7344
LOSB4109 are the originals if you need something in a bind.
-Ryan Dunford
Old 11-07-2014, 08:14 AM   #7345
Braxamus's Avatar
In regards to my question on the chassis braces, is the front and rear one the same length? I only seen one part number in the book. TLR231010
Old 11-07-2014, 08:30 AM   #7346
Casper's Avatar
Yes on the 2.0 the chassis braces are the same.
Old 11-09-2014, 05:53 AM   #7347
maddog9's Avatar
Trader Rating: 29 (100%+)
The newest Ryan Dunford setup has this trucked dialed. I was able to TQ and Win at the CRCRC WRL 4.2 at the Ohio RC Factory. This was my first ever TQ and Win at a WRL event. TLR sweep of the podium.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 11-09-2014, 10:42 AM   #7348
Casper's Avatar
Nice job
Old 11-09-2014, 07:31 PM   #7349
Bivens's Avatar
I just picked up one of these...a used roller...
I've got all other current TLR 1/10's and an 8e3.0....have had a lot of success with the 1/10....just don't like the heavy 8th scales on our tight track...time to try this truck....
On the current setups, I see notes on the bottom of the page about spacing the rear hex's out...OK, I think I understand that.....but what's the note mean about witness marks and a dremel?
Team 3D Hobbyshop
www.3dhobbyshop.com
Bivens is offline   Reply With Quote
Old 11-09-2014, 07:39 PM   #7350
maddog9's Avatar
With the aluminum 15 degree casters the wheels will rub the arm and steering rod at full throw.
